Old 09-08-2017, 05:56 PM   #51
Texas240
Prius Owner
Texas240's Avatar
Originally Posted by Funkee View Post
Nice, I had XC90's in mind but the Caddy's seem to be an easy fit and pretty big as well. What disc size are you running?
330mm disk I believe from s60r/v70r
93 245 LS Engine Swap Project
Old 09-09-2017, 01:55 PM   #52
cosbySweater
cosbySweater's Avatar
That sounds right. Super cheap swap. The calipers are like 75 bucks on Amazon prime
1995 Porsche 993
2013 VW Passat TDI
cosbySweater is online now   Reply With Quote
Old 09-12-2017, 03:49 PM   #53
cosbySweater
I went with a little looser converter this time and it's a 10 inch single billet
Old 09-12-2017, 04:23 PM   #54
joedirt
joedirt's Avatar
Sick setup thanks for sharing
joedirt is offline   Reply With Quote
Old 09-12-2017, 10:56 PM   #55
cosbySweater
No problem, I like sharing all the trials and tribulations with car builds
Old 09-14-2017, 11:12 AM   #56
cosbySweater
Updated the 80e to the new internal harness and all new solenoids, weighed the stock converter last night and it came in at 89 lbs while the new 10 inch single billet came in at 29. So 60lbs of rotating mass off the engine. That's huge!
Old 09-14-2017, 11:17 AM   #57
122power
dude
122power's Avatar
Racecar!
Save the Volvo's.
Ring,ring,ring
"Hello"
"Do you work on Volvo ...
*Click - bzzzzzz*
Old 09-14-2017, 12:30 PM   #58
BillyMaysHere
BillyMaysHere's Avatar
Hot damn. Will this make it harsher on the diff and suspension? In other words does a heavier one provide more of a cushioning effect to the power delivery?
Old 09-14-2017, 12:34 PM   #59
cosbySweater
No it will make it easier on it. The stock converter is so tight with the transgo kit that it slams the gears so hard. The looser converter makes the shifts feel like a stock car with the hd2 kit
Old 09-14-2017, 01:10 PM   #60
BillyMaysHere
Sweet, I thought looser implied that but I'm still learning about autos.
Old 09-14-2017, 01:22 PM   #61
cosbySweater
Old 09-14-2017, 01:49 PM   #62
Jack
junkman
Jack's Avatar
one of my favorite volvo car stories.
NICE
I love you even more Jack.
Old 09-14-2017, 03:15 PM   #63
cosbySweater
NICE
Thank you, very much appreciated
Old 09-14-2017, 06:56 PM   #64
Texas240
Prius Owner
Texas240's Avatar
any idea what the stock 4l60e convert weighs? And how are you taking the trans out? Engine still in car or take the whole damn thing out?
Old 09-14-2017, 09:39 PM   #65
cosbySweater
I'm pulling the trans out from the bottom, it's easy, when I swapped converters in the trans that's in the car it took about 2 hours. And I have no idea about a 4l60e converter weight. I assume it's alot lighter then this early 80e hd unit
Old 09-15-2017, 08:09 PM   #66
Texas240
Prius Owner
Texas240's Avatar
interesting. I always wonder how much of a pain it would be to take out the 4l60e if I ever have to. I hope by that time I'll have a lift in the new garage. Carry on.
Old 09-16-2017, 04:43 PM   #67
cosbySweater
You probably will have to at some point. I mean it is a 4l60
Old 09-16-2017, 06:02 PM   #68
Texas240
Prius Owner
Texas240's Avatar
I'll be the judge of that
Old 09-17-2017, 12:30 PM   #69
cosbySweater
Old 09-18-2017, 03:45 PM   #70
cosbySweater
Welp the trans swap didn't go quite as planned, turns out the early model 80es have a different pan then the two late model pans I had. Oh well I ordered a higher capacity pan with cooling tubes going through it and I will probably fabricate some sort of skid plate under the car.
Old 09-18-2017, 03:48 PM   #71
toms_elleck
toms_elleck's Avatar
Speaking of 4L60Es, I broke mine.
Got any leads on good used 4L60Es? Or got any leads on a good used T56?
-Thomas
toms_elleck is offline   Reply With Quote
Old 09-18-2017, 03:53 PM   #72
cosbySweater
No way?! It broke??? :P
I have a buddy with one I believe let me call him and see if he still has it. Also t56s are stupid expensive and are usually hammered, I would do a 350z 6speed. Way cheaper even after you adapt it.
Old 09-20-2017, 12:49 AM   #73
cosbySweater
Got the trans in stalled with the deep sump pan and got everything together and filled the trans, it was only then I realized I have the wrong bracket for the shifter. I have a 4l80e with a neutral safety switch bracket on and the older 80e does not have that so I have to dig up the old bracket or buy a new one for 25 bucks. I'll probably choose the latter, also capacity is now at 18qts, hahaha
Old 09-20-2017, 05:21 AM   #74
2fast242gt
Do you have a cobalt?
Post some pictures of the cable and brackets for the shifter. I'm interested in switching to a 80e
1983 242dl
*6.0 lq4 swaped* Build thread
Old 09-20-2017, 07:34 PM   #75
77volvo245
77volvo245's Avatar
what is your budget on a t56 ?
STSmachining
