Old 02-06-2018, 11:41 PM   #201
cosbySweater
cosbySweater's Avatar
I made some overall adjustments when throwing the car back together. I verified tdc again and checked the piston protrusion on all 8 cylinders, they all matched perfectly. I threw the Corvette heads on and from what I gather the compression is about 10.2:1 on the engine now, the heads do not flow as well on the intake side but from what I can gather they flow a tad better on the exhaust. Also one thing to note from my research there are claims out there that the casting is better on the passenger car heads and they are less prone to cracking. I do not know if this is entirely true but I will say that the casting does look nicer. I also verified yet again that the timing offset is incorrect. When I checked it again the timing was off about 6 degrees advanced at idle. I have found with the past three times I've mechanically timed the engines and verified it that is has been anywhere between 5-6 degrees off when comparing it to the timing on tuner studio which was registering around 15 degrees at idle and the timing light was showing 21. So the car does feel a little happier with the timing set properly even without the meth kit triggering at around 10psi. I also switched to a ls9 map sensor located where the EGR tube used to go on my ls1 intake. I was noticing a issue where the watermeth would allow contamination on the map sensor when it was in the stock location at the back of the manifold. Either way the car is running and driving and hopefully I will be able to have it at the strip this weekend.
1995 Porsche 993
2013 VW Passat TDI
Old 02-07-2018, 12:29 AM   #202
122power
dude
122power's Avatar
In sacramento?
Save the Volvo's.
Ring,ring,ring
"Hello"
"Do you work on Volvo ...
*Click - bzzzzzz*
Old 02-07-2018, 12:35 AM   #203
cosbySweater
Yes
Old 02-07-2018, 10:39 PM   #204
cosbySweater
Verifying tdc
New ls9 map sensor location
My et streets 235/60r15
Old 02-09-2018, 01:54 PM   #205
t8fanning
8v are still cool, right?
t8fanning's Avatar
Can't wait to see how those tires do for you.
1982 242 Turbo.
Old 02-09-2018, 03:04 PM   #206
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
if they're radials, hope you're not using stock axles.
Megasquirt Tuning!
Old 02-09-2018, 04:01 PM   #207
cosbySweater
I have a 8.8 so I hope it will be fine
Old 02-09-2018, 04:14 PM   #208
JohnMc
JohnMc's Avatar
I'll be keeping tabs.
/8.8 and turbo LS going in soon
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 02-09-2018, 05:06 PM   #209
cosbySweater
Yea I will say this, convert to a solid pinion spacer instead of the crush sleeve. Mine has been slowly crushing and now my backlash is kinda messed up and the rear end is starting to howl
Old 02-09-2018, 06:09 PM   #210
linuxman51
linuxman51's Avatar
radial et streets are haaaard on the equipment
Old 02-09-2018, 06:56 PM   #211
cosbySweater
Yea they are radials, when I took the Fairmont to the strip and only got the one okay pass I didn't even really sit on the converter, just stabbed the throttle, lol. I will probably do the same with this one, I really don't want to break the volvo
Old 02-10-2018, 06:03 PM   #212
M.H. Yount
M.H. Yount's Avatar
"Breaking **** is part of the game"
"...I really don't want to break the volvo"
Eventually, breaking stuff gets old. But watching you persevere is inspiring. Look forward to seeing you get it back together for another go at it.
Old 02-10-2018, 09:46 PM   #213
cosbySweater
It's running and driving fine now, decided not to take it to the track this weekend and just have a relaxing weekend. But February 17th, I will leave the crankshaft on the track if that's what it takes
Old 02-19-2018, 03:49 PM   #214
cosbySweater
Ended up taking a nice relaxing weekend doing nothing. I have put about 600 miles on the Volvo since the head change and no issues. I'm finding that my aem watermeth controller is intermittently staying on. So I'm going to delete that whole aem controller and wire it up to Ms like I have done on my Fairmont which works extremely well. Speaking of which I brought the turd back home!
https://youtu.be/zKqi2swIDnM
Old 02-19-2018, 03:55 PM   #215
Tfrasca
Tfrasca's Avatar
One tire fire?
Old 02-19-2018, 04:05 PM   #216
cosbySweater
Super worn out lsd. To be honest I haven't even checked if there's fluid in it since I bought it on Craigslist. You can see the driverside delay and then lock
Old 02-27-2018, 04:32 PM   #217
cosbySweater
Got some work done this weekend on the Volvo and the Fairmont, I wired up the watermeth to trigger off the Ms and it works alot better now. I also rebuilt the whole rear end on the Fairmont. I swapped out the 2.73 gears on it and threw in a full strange spool kit. I converted to 3.55 gears and did a spool with 35spline strange hardened axles and c-clip eliminators. It should move out really good now!
Old 02-28-2018, 12:31 AM   #218
Xeroni
MPG?
Xeroni's Avatar
Bringing them both to Davis?
1990 765T; sent off
1989 744T; parted out
1985 245; The Battlewagon;+t, B21/AW71L, back at it again with the megasquirt
1994 940; it's 16v
2019 Fiesta ST; DD
Xeroni is offline   Reply With Quote
Old 02-28-2018, 12:58 AM   #219
t8fanning
t8fanning's Avatar
Have you launched on the radials yet in the Volvo?
Old 02-28-2018, 02:11 PM   #220
cosbySweater
I have not gone to the track with the Volvo yet. On the street it just boils the tires from a dead stab, lol. Im going to be cutting out the rear wheel wells on it in the near future and try to stuff a 275 at least in the back. The car is going to get painted so I'm going to mess with all the body work before hand obviously. And I may try and bring both cars to Davis, honestly I like cruising in the Fairmont better then the volvo cause of the comfy bench seat and stock suspension
Old 03-19-2018, 11:02 PM   #221
cosbySweater
So been daily driving the Volvo for a while and it hasn't burnt a drop of coolant! Perfect!!!!! Also I got some goodies for my Fairmont during that 20% off sale on eBay 228/230 cam and a billet 7875. Going to redo the hotside and slam the cam in and try to get some 10s out of it!!!
Old 03-20-2018, 02:05 AM   #222
122power
dude
122power's Avatar
an elgin cam?
Old 03-20-2018, 01:11 PM   #223
cosbySweater
Yep!
Old 04-01-2018, 01:46 PM   #224
cosbySweater
Got my Fairmont back together, now with a 7875 turbo and 228/230 cam shaft. I built a new hot side for it and moved all the accessories around as well
Also picked up some mustang turbine wheels for it as well
Old 04-01-2018, 01:47 PM   #225
cosbySweater
Oh and the 244 is doing great! Going to post it on BAT soon. As a whole that project is done for a while
