Old 05-29-2019, 10:35 AM   #101
Vol242vo
Keep it clean...
Vol242vo's Avatar
One of the rear wheels had a small bend that’s been repaired now and 1 lip is DONE. First time around polishing a set of two piece wheels, it’s a chore! Still haven’t found the gold paint color for the centers however, I have some fender work before I can mount the rears anyway.
Before:
After:
The grill and bezels are repaired and in need of some fresh SEM paint.
Derek
1 Owner - 85k mile 1980 242
-Project Thread-
Follow on IG: @vol242vo
Old 05-29-2019, 10:45 AM   #102
For reference, Goldtastic by Prismatic Powders comes pretty close to BBS gold. I had mine clear coated but it's not necessary if you don't want the extra gloss.
Old 05-29-2019, 03:48 PM   #103
Vol242vo
Keep it clean...
Vol242vo's Avatar
Right on, helpful info, thank you! How's your 242 coming along Harold?
Old 05-29-2019, 05:10 PM   #104
Been sick; haven't touched it in two weeks. It might be growing resentful, but I'm not totally sure.
Old 06-10-2019, 04:18 PM   #105
Vol242vo
Keep it clean...
Vol242vo's Avatar
This weekend while tinkering around in the garage, I did a basic mock up of the rear wheels to get an idea of what kind of spacer I’ll need to avoid rubbing on the inside. 22-25mm spacers and lug extensions will do it. I’m sure I’ll have to massage the outer fenders as well...but pretty excited about getting these mounted and moving on to the next headache.
Old 06-24-2019, 04:36 PM   #106
Vol242vo
Keep it clean...
Vol242vo's Avatar
Time to clean up the engine bay, tucking all wiring and moving what I can into the cabin. Wiring will get new looming and mount in between the fenders.
Old 06-24-2019, 05:24 PM   #107
Neat!
KEEP THE BIG BUMPERS
Old 06-26-2019, 04:32 PM   #108
Fast740fromSC
Fast740fromSC's Avatar
Awesome build!!!
Fast740fromSC is offline   Reply With Quote
Old 06-26-2019, 04:39 PM   #109
Vol242vo
Keep it clean...
Vol242vo's Avatar
Neat!
The only commando I like is that feeling of freedom down under!
Originally Posted by Fast740fromSC View Post
Awesome build!!!
Thanks man, lots to do to get the engine and bay the way I want it.
More progress this morning.
Old 06-27-2019, 03:55 PM   #110
Vol242vo
Keep it clean...
Vol242vo's Avatar
This morning I had a couple of hours to get the harness into the cabin, found a few ‘repaired’ wires that weren’t even soldered or with pinch connections, just a good twist and hardened electrical tape. One of the reasons I like to do this is to make sure everything is how it should be and no surprises down the road.
I ran into a few ends that aren’t connected to anything and I have no idea what they go to...see thread here:
http://forums.turbobricks.com/showth...69#post5966869
Now to sort through all this wiring, remove what won’t be used.
Old 07-24-2019, 05:51 PM   #111
Vol242vo
Keep it clean...
Vol242vo's Avatar
Tear down progress continues...Removed the intake manifold, fuel pressure distributor and injectors. I also shaved the battery tray and the mounts that were welded to the body.
Need to order:
Head Gasket
Valve Cover Gasket
Oil Seal Kit
Water Pump
Old 09-17-2019, 11:30 AM   #112
Vol242vo
Keep it clean...
Vol242vo's Avatar
Barrels are DONE! Still debating if I want to paint the centers Gold or Silver...kinda leaning towards Silver now.
Old 09-17-2019, 03:09 PM   #113
slow240
Home Schooled
slow240's Avatar
Wow those came out great!!! I need to get to work on my RS lol
Old 09-17-2019, 04:36 PM   #114
You want the centers in copper with flake and a medium gloss clear.
Old 09-18-2019, 12:13 AM   #115
Vol242vo
Keep it clean...
Vol242vo's Avatar
Thanks man, took awhile to get them the way I wanted them to look, the nice thing is it’s all just time and elbow grease.
Sounds cool but not sure about that contrast with teh beige...
Old 09-18-2019, 05:34 PM   #116
It's the perfect amount of contrast
Old 09-19-2019, 08:43 AM   #117
Vol242vo
Keep it clean...
Vol242vo's Avatar
Ha ha, ok maybe. I might mess around with plasti-dip a few times and colors before powder coating them. We’ll see, thanks for the compliments and opinions fellas!
Old 09-19-2019, 11:04 AM   #118
patrickstar
patrickstar's Avatar
The wheels are going to look great on there. I vote for BBS gold personally, very traditional but classy
patrickstar is online now   Reply With Quote
Old 09-20-2019, 11:58 PM   #119
Vol242vo
Keep it clean...
Vol242vo's Avatar
Thanks man, really enjoying watching the progress you’re making on your 242...definitely going to be a fun ride. We’ll see, they’ll be Gold or Silver centers, not black.
Old 09-21-2019, 02:29 AM   #120
patrickstar
I've definitely stalled out the past few weeks, I need a few hundred more dollars worth of stuff and it'll run. Aaand I just bought another Volvo.
We need to get pictures of our Eastern WA beige 242s once we're both running
Old 09-21-2019, 10:42 AM   #121
Vol242vo
Keep it clean...
Vol242vo's Avatar
Agreed! I’ll be there next spring to Summer, just a few tidying up bits on my end. Did you see the 1980 Brown 242 in Wenatchee for $350???!! Wish I had the room for it...
Old 09-21-2019, 12:23 PM   #122
patrickstar
I did, I contacted the guy. Said the body is perfect... No room here either
Old 09-30-2019, 11:06 PM   #123
Beige car, bronze wheels
Old 10-01-2019, 12:44 AM   #124
Vol242vo
Keep it clean...
Vol242vo's Avatar
Pearl white = Beige?
Nice looking Audi, your’s?
Old 10-01-2019, 01:00 AM   #125
adamdrives
Amazing attention to detail, giving me inspiration to tackle the multiple projects (blower motor/heater core, upholstery, sunroof crank, A/C etc) that my newly acquired 78 needs.
Feedback thread
78 242 DL 189k
83 245T+IC 136k
99 V70R 163k lazer blue
05 S60R 161k sapphire/nordkap
08 S80 V8 109k
adamdrives is offline   Reply With Quote
