Old 10-01-2019, 01:16 AM   #126
Originally Posted by Vol242vo View Post
Pearl white = Beige?
Nice looking Audi, yourís?
Neighbor's.
It looks beige in normal light. Sun was under the horizon at this point.
Beige and bronze go together. I insist.
Old 10-17-2019, 09:10 PM   #127
Vol242vo
Keep it clean...
Vol242vo's Avatar
Haha! They do, just not quite what I’m going for.
The 242 is tucked away for winter already. Didn’t remotely get done what I had hoped I would but she’ll be on the road next summer. This is my winter project/to do...clean, rebuild, replace everything in these boxes. I want to hit the ground running come next spring as far as the engine and engine bay go.
Derek
1 Owner - 85k mile 1980 242
-Project Thread-
Follow on IG: @vol242vo
Old 10-18-2019, 07:27 AM   #128
slow240
Home Schooled
slow240's Avatar
Sticking with Kjet?
Or maybe stealth install some injector bungs on the bottom of that intake and tuck everything real nice?
I'll polish your face
Old 10-18-2019, 02:59 PM   #129
Vol242vo
Keep it clean...
Vol242vo's Avatar
Originally Posted by slow240 View Post
Sticking with Kjet?
My first priority is getting it running and reliable with Kjet, just because itís what I have. I want to enjoy the car as a simple summer cruiser for now, in time Iíll look into a different engine management system along with better injectors and such.
I will keep as much as I physically can clean and tucked away as parts go back in. First, a good cleaning of everything and as Iím dismantling and rebuilding items Iíll take inventory of whatís needed for a smooth install and hope for minimal headaches next spring!
Old 10-18-2019, 03:00 PM   #130
Vol242vo
Keep it clean...
Vol242vo's Avatar
I will be spending a lot of time on the intake manifold. Inside and out, smooth and shiny is the plan!
Old 10-18-2019, 11:17 PM   #131
Duder
Comes with a free Frogurt
Duder's Avatar
Old 10-18-2019, 11:22 PM   #132
Vol242vo
Keep it clean...
Vol242vo's Avatar
Ok...I can get behind that ^
Old 10-30-2019, 10:12 PM   #133
Vol242vo
Keep it clean...
Vol242vo's Avatar
I’ve always wanted to try to smooth out all the casting marks and fully polish a B21 intake manifold, this is going to take a very long time but I think it’ll be worth it when it’s done. Today I spent about an hour hitting the high spots and taking down areas that can be smoothed out.
Once I’m happy with the results I’ll replace all the vacuum lines and hardware.
Old 11-07-2019, 08:50 AM   #134
slow240
Home Schooled
slow240's Avatar
You gonna put some clear powder coat on there? I'd hate a polished intake just from a maintenance standpoint lol
Old 11-07-2019, 11:12 AM   #135
Vol242vo
Keep it clean...
Vol242vo's Avatar
No, I don't think I will, I'll keep it clean. That stuff doesn't bother me at all when you're standing back and admiring the results.
Old 11-07-2019, 05:27 PM   #136
Stiggy Pop
Stiggy Pop's Avatar
Use Shine Seal. I like polishing aluminum so I have a lot of raw polished aluminum stuff, including the lips of my Epsilons. I bought a Shine Seal kit and the stuff is great. Easy clean with soap and water, lasts for quite a while. Really does a great job protecting the finish.
'79 242
943 pickup
Old 11-07-2019, 06:23 PM   #137
MikeJr.
Gloss Boss
MikeJr.'s Avatar
https://mirrorfinishpolishing.com/
Old 11-07-2019, 11:40 PM   #138
Vol242vo
Keep it clean...
Vol242vo's Avatar
Great! Thanks for the tip!
Originally Posted by MikeJr. View Post
Wow, some impressive shine in there, good stuff. Thank you.
Old 11-09-2019, 09:03 PM   #139
Vol242vo
Keep it clean...
Vol242vo's Avatar
Starting to get some promising results on the manifold, this is just down to 2500 grit sand paper...I’ll wet sand it all as a last step then buff and polish it. So far I’m happy to see what it’s going to look like, some of the tighter areas are going to be tough...
Old 11-11-2019, 01:51 AM   #140
slow240
Home Schooled
slow240's Avatar
I'm excited to see your results. You are one of few people I've seen on the forums that might actually pull this off.
I've always liked that manifold.
Old 11-11-2019, 04:38 PM   #141
Vol242vo
Keep it clean...
Vol242vo's Avatar
Thanks man! Iím excited too, Iíll get there, the goal is to make it something that helps set you engine bay off amongst other details but this one should be neat!
Old 11-12-2019, 09:15 PM   #142
Vol242vo
Keep it clean...
Vol242vo's Avatar
Small Victories...another couple of hours and I have the top pretty much ready to polish.
Old 11-23-2019, 04:59 PM   #143
Fast740fromSC
Fast740fromSC's Avatar
Looks DOOOOOPPPPPPPEEEE! Great job!!
Fast740fromSC is offline   Reply With Quote
Old 11-23-2019, 05:35 PM   #144
Vol242vo
Keep it clean...
Vol242vo's Avatar
Thanks man! Definitely a light at the end of this tunnel. I always appreciate putting in work with things I already have, with time and effort, you end up with something unique for free! More to come...
Old 12-01-2019, 09:51 PM   #145
Alan29
Alan29's Avatar
Amazing work so far. Curious what product(s) and techniques you are using to clean the doors.
Signature.
Alan29 is offline   Reply With Quote
Old 12-02-2019, 01:49 AM   #146
Vol242vo
Keep it clean...
Vol242vo's Avatar
Thank you Alan!
On the doors, to remove all the grime and old stickers I used Simple Green, Goo Gone, Laquer thinner, and soap and hot water. At times WD-40 works well while renewing some of the bare metal items like the door latch and handle mechanism.
Old 12-02-2019, 04:02 PM   #147
Alan29
Alan29's Avatar
Thank you Alan!
Awesome...thank you! Mine are pretty gross and wasn't sure the best way to tackle it, particularly the moving parts. Does the WD40 leave enough of a protective coat on those bare pieces? Are you using a white lithium or silicone within the mechanisms themselves? Growing up it was lithium in everything but reading more people favoring the silicone.
Old 12-02-2019, 06:17 PM   #148
Vol242vo
Keep it clean...
Vol242vo's Avatar
Yeah I use a heavy duty silicone spray by CRC.
https://www.walmart.com/ip/CRC-Heavy...caAjmqEALw_wcB
Old 12-03-2019, 01:38 AM   #149
LC4CARL
Aero challenged
LC4CARL's Avatar
Sweet ride.
@PDXvolvo on IG
LC4CARL is online now   Reply With Quote
Old 12-03-2019, 09:39 AM   #150
Vol242vo
Keep it clean...
Vol242vo's Avatar
Originally Posted by LC4CARL View Post
Sweet ride.
Thanks Carl, itís craving your suspension bits!
