Old 09-18-2018, 06:26 PM   #1
Fa182
Stage 1
Fa182's Avatar
Default Squeaky clutch in drive
97 945T w/ M90
My clutch always make a faint squeaky sound when idling or in drive. It sounds like a high pitched belt squeak or so and is not very loud. I just noticed it today when I had the radio off.
Thing is when I press on the clutch pedal, just a tiny bit like half an inch, the noise goes away.
I had my RMS replaced 4 weeks ago and asked the guy to look at the clutch too, he said it's perfectly fine. Also the clutch master cylinder was squeaking a little a few weeks ago but this completely went away. It only happened when it was very hot around here (95-100F), but it's significantly colder now, so that might be it...?
Anyway, any ideas what this could be? Throw out bearing?
Old 09-18-2018, 06:30 PM   #2
Jack
junkman
Jack's Avatar
did you install the clutch plate backwards ?
did you install the TO bearing clip in all the way ?
Old 09-18-2018, 06:33 PM   #3
Fa182
Stage 1
Fa182's Avatar
I didn't install anything, the shop did.
The clutch is working fine if it helps, just like it did before I brought it in to replace the RMS.
Old 09-18-2018, 06:35 PM   #4
Jack
junkman
Jack's Avatar
it will still work but make nose.. .meant did shop
take it back... noise should not be there
Old 09-18-2018, 06:46 PM   #5
Fa182
Stage 1
Fa182's Avatar
So I guess this is probably coming from the TO bearing then?
Old 09-18-2018, 08:14 PM   #6
Dual mass flywheel failing....
Old 09-19-2018, 02:25 AM   #7
Fa182
Stage 1
Fa182's Avatar
Sorry I have little to no idea about clutches, could you explain why the flywheel can fail?
Old 09-19-2018, 12:47 PM   #8
Fa182
Stage 1
Fa182's Avatar
Here's a quick video. I press on the clutch pedal just slightly (to the point where I feel resistance - like half an inch) repeatedly and quickly at the beginning. It sounds more like a chirping sound. Maybe this helps?
https://www.youtube.com/watch?v=nv2hEixgKD4
Old 09-19-2018, 01:31 PM   #9
lummert
lummert's Avatar
Throwout bearing? Another question: Does the M90 use a pilot bearing at the rear of the crankshaft? After some reading it appears that the cure for the dual mass flywheels is a swap to a single mass flywheel.
Old 09-19-2018, 01:35 PM   #10
Fa182
Stage 1
Fa182's Avatar
Sorry for the dumb question but like I said, I don't know a lot about the clutch, if it's the TO bearing, is this something that requires immediate attention or am I okay to drive like that? There is no different feel to the clutch and the bite point is all the same than before the RMS job.
Old 09-19-2018, 02:14 PM   #11
oldschoolvolvo
oldschoolvolvo's Avatar
Possible spots for a clutch squeak to occur:
-pedal pivot in pedal box under dash
-pedal to master cyl attachment under dash
-slave cyl push rod to clutch fork
-clutch fork to pivot ball
-clutch fork to throw out bearing
-throw out bearing to pressure plate spring fingers
-springs inside of pressure plate
Does the sound only occur when the engine is running?
Can you make it squeak when the engine is off?
-Mike
1998 V70 T5
|Feedback|
Old 09-19-2018, 06:28 PM   #12
Fa182
Stage 1
Fa182's Avatar
Thanks for the suggestions. The sound only occurs when the engine is running. No squeaking with engine off.
Old 09-23-2018, 05:07 AM   #13
Fa182
Stage 1
Fa182's Avatar
Replaced the clutch master cylinder yesterday because it was making weird noises and I thought I'll change it before it completely fails (had that happen in my old car and had to drive 200km back home without a clutch, wasn't the nicest experience).
But it did not stop the squeaking after all, I can still make the squeak go away when lightly pressing on the pedal, so I guess I'll give the shop a call next week to change the TO bearing.
Old 09-23-2018, 03:35 PM   #14
Dual mass flywheels can separate and make noise.
Old 09-23-2018, 05:19 PM   #15
Fa182
Stage 1
Fa182's Avatar
Thanks, I'll have the shop look at it again.
Weirdly enough, while driving the car today in the afternoon the squeak was completely gone. I guess I'll just see if it comes back in the next few days.
