Thanks Steve, I was going to look into a swap because the dude at salvage yard looked it up and according to his data base he printed out the direct fit for me. That printout could very well be for the rear axle only.....it doesnt specify. Thanks for the analysis, it makes alot of sense. I have found a lot of parts that are slightly indirect or direct crossfits from later models and even different makes. My starter for example is a direct fit and it came from a 92 Mercedes. Its a tiny bit stronger but I like that start power. My interior came from an 85 Volvo 740 and the fuel pump from a 95 Volvo. I switched the fuel injection to carbureted with a kit from IPD, so I had to alter the fuel delivery but this allowed me to dump the accumulator. Now about brakes. It seems I have found 2 problems that were the cause of system failure. Called my dad (best mechanic ever for old cars) and he suggested I dismantle everything and start from scratch. Im going to list steps for future readers in the hopes they save time and frustration and dont have to throw money at "possible" causes. Step 1. Disconnect everything from the master cylinder (MC), bench bleed the MC in place by directing 2 clear tubes from the outlets back into the fill cap of reservoir. Fill the reservoir with brake fluid. Pump the brakes slowly and to the floor until there are no more air bubbles travelling to the top of the clear lines. Also cover the exposed fill cap as best you can because fluid will squirt out of the exposed fill cap. I used a liquid coffee creamer cap from a bottle in the fridge. It fit perfect over the fill cap and I drilled 2 holes the size of my tubes to hold them snug in place. If you pump the brakes for 20 or 30 times and you still see bubbles...your master cylinder is bad and you need to refurbish with a kit or replace. If there are no bubbles and you are sure its straight fluid returning to the fill cap on to step 2. Remove the tubes from the MC outlets and plug the holes with 2 screw, make sure the are the same threading and wrap screw threads with teflon tape. When there is no dripping of fluid and the screws are set back to pushing the brakes. Its better to have someone do this with you so you can observe the MC. The brakes should be depressed slowly until pressure stops you from further pushing, during this phase you are checking the tiny "weep hole" at the bottom of the MC near the mount. If fluid drips out, your seals are bad and either rebuild or replace MC. Also you are listening for noise inside booster. If you hear liquid bubbling past the diaphragm...thats bad. The fluid back flowed thru seals in MC and collected in the booster remove all that you can with turkey baster or syringe with tube attached, the latter is better for reaching around angles. If you managed to get past those steps with no leaks, on to Step 3. This step requires that you buy an female end connector to match the threads of your hard tube lines that leave the outlets from your MC. (You do put those on by the way before starting step 3 and plug them with anything to stop the drip. Next remove one of lines from any one of the ports on the junction box and connect it directly to the hard line coming from the MC. Follow that line to the caliper so you know which one you are testing. At this point, you need to decide if you want to test the isolated caliper or 2 at once. If you want to test the one make sure you know which circuit of the MC is supplying fluid to your test caliper. The 2 circuits are listed as primary and secondary in repair manuals. I personally would use the secondary because that is the furthest reach of the rod that comes from the booster to activate flow of fluid. If you find that it is weak during testing, you may have to adjust the depth of reach of the rod (according to manual). If you choose to test one caliper, you must reattach the second bleeder tube to empty back into the filler cap as in Step 1. Next you will bleed the caliper to be tested of all air in the line. Then you a ready to test the caliper. Put the car in neutral (with engine off) and push the car. When it starts to roll----Hit the brake. If it works continue the same procedure for each caliper. One thing I forgot to mention was before you start the last step remove the flexible brake lines and check the by pushing fluid thru them with a syringe, a stream of fluid should free flow thru the openings with no pressure exerted from the star point. If you think there is obstruction and the amount coming out is less than you reasonably expect.....its prolly bad or getting there soon. Just replace.
