Old 10-08-2017, 01:44 PM   #1
blackswift bicycles
blackswift bicycles's Avatar
Question 145 bosh to autolite alternator problems
hey guys so i had to change my alternator and battery on my 145 with a b20e and now my charge light stays on and car wants to die when i come to a stop. any ideas?
blackswift bicycles is offline   Reply With Quote
Old 10-08-2017, 01:47 PM   #2
matt b
Is the alternator charging ? Have you checked the voltage at the battery when it's idling with a multimeter ?
I'm assuming the belt is tight enough and not slipping ?
Old 10-08-2017, 01:51 PM   #3
blackswift bicycles
no i haven't checked yet i cant find my meter
Old 10-08-2017, 01:59 PM   #4
planetman
planetman's Avatar
Did you change the external voltage regulator? Is it a mechanical or electronic voltage regulator?
Eric
Torrance, CA 90502
Old 10-08-2017, 02:01 PM   #5
blackswift bicycles
i hate to sound stupid but i didnt know it has one
Old 10-08-2017, 02:18 PM   #6
tryingbe
Boosting along.
tryingbe's Avatar
Get it first.
85 GLH 367whp
00 Insight 72 mpg
Old 10-08-2017, 02:43 PM   #7
planetman
planetman's Avatar
Yes, it should have 1. They are usually mounted on the right inner fender or radiator core support. Follow the alternator harness to find it.
Mechanical regulators should be changed every time a new or rebuilt alternators are installed. Electronic voltage regulators are usually reuseable.
Old 11-02-2017, 05:09 PM   #8
blackswift bicycles
so i couldn't find it i ran down the wire and it ran to a connector so i picked up one from ipd and wired it in now i was getting voltage but the amp light was flickering so i was able to drive the car but when i got back and shut off the car the voltage dropped down to 10. am i missing something here?
Old 11-02-2017, 07:49 PM   #9
Khrrck
Professional Amateur
What voltage were you getting with the engine running?
Is your battery good? Was it under load when you checked it with engine off?
Got a trickle charger you can top it up with?
'87 240 budget wagon.
Old 11-02-2017, 08:44 PM   #10
blackswift bicycles
battery is good and it was running 12-13 running i didnt re check it till i couldnt start the car again. i have to pick up my charger tomorrow
Old 11-02-2017, 09:21 PM   #11
Shifted
C&M '17 Survivor
Shifted's Avatar
Can't be bothered to spell 'Bosch' correctly.
Can't be bothered to speak in coherent sentences or use capitalization or proper punctuation.
Can't be bothered to find your vom to do some actual checking on your own.
...Go Fish.
Originally Posted by ME II View Post
Without mistakes there is no learning.
"Ego is the anesthesia that deadens the pain of stupidity" - Rick Rigsby
Shifted is offline   Reply With Quote
Old 11-02-2017, 09:24 PM   #12
blackswift bicycles
Exclamation
actually i did find my meter thank you and if you want to talk **** go somewhere else.
...Go Fish.
Old 11-02-2017, 09:42 PM   #13
Sexual healer
Should be minimum 13.5v running. 12. something means it's not charging.
Old 11-02-2017, 09:45 PM   #14
blackswift bicycles
huh well i might have to bite the bullet and have a shop take a look at it
