Old 07-29-2007, 02:14 PM   #1
m4ff3w
m4ff3w's Avatar
Default Proper oil pressure for b230ft?
What is the correct oil pressure for a 91 740 turbo?
m4ff3w is offline   Reply With Quote
Old 07-29-2007, 02:45 PM   #2
robiewing
RIP Trick Mick
robiewing's Avatar
35.5 psi
Originally Posted by TrickMick View Post
it *usually* ends up being some form of BASIC fail....
GOOD CATCH....I *hope* you logged the experience so
you can go back,and refer to it if faced w/a similar set
of "symptoms"!!
robiewing is offline   Reply With Quote
Old 07-29-2007, 11:45 PM   #3
m4ff3w
m4ff3w's Avatar
Is that minimum oil pressure while idling hot?
Old 07-30-2007, 09:19 AM   #4
robiewing
RIP Trick Mick
robiewing's Avatar
Probably ideal,
it's from Alldata.
Never (once maybe) heard of a b230 loosing oil pressure. Why are you asking?
Old 07-30-2007, 09:41 AM   #5
m4ff3w
m4ff3w's Avatar
Oil dummy light started coming on. Replaced sender with real gauge & electronic sender. Just wanting to make sure everything is OK.
Old 07-31-2007, 07:05 PM   #6
m4ff3w
m4ff3w's Avatar
Never drops below 45psi during hot idle, so I guess I'm good.
Thanks.
Old 08-01-2007, 03:53 AM   #7
disco192
Oil pressure is direclty related to RPM and Temperature. More RPM = more oil pressure. Higher temp = lower oil pressure.
As a rule of thumb, you want about 10 psi/1000 rpm... at least thats what Ive always known on V8s (im a V8 guy originally)
disco192 is offline   Reply With Quote
Old 08-01-2007, 12:00 PM   #8
m4ff3w
m4ff3w's Avatar
So at idle you'd have less than 15psi of oil pressure?
That just sounds scary.
Old 08-01-2007, 12:56 PM   #9
240on280
240on280's Avatar
The Volvo/VDO oil idiot light trips at 7-8 p.s.i which is about 0.5 Bar. At a hot idle you shouldn't be below 1 bar (16 p.s.i.). Typically you will run between 2-3 Bar (32-48 p.s.i.). A cold engine will give you 4bar (64 p.s.i) and may spike to 5Bar (80 p.s.i). If you're in this range don't worry about it.
The BMW said "I am the ultimate driving machine!" and the Volvo wagon said "Oh really?"
240on280 is offline   Reply With Quote
Old 08-01-2007, 01:11 PM   #10
m4ff3w
m4ff3w's Avatar
Thanks for the most comprehensive reply.
Old 08-01-2007, 01:50 PM   #11
disco192
Typically oil pressure in most V8s I build is around 20 at warm idle. In all honesty, oil pressure at idle isnt where most damage comes from. Most oil pressure issues and spun bearings comes from high rpm oil starvation...
The thing about oil pressure is it is MUCH different that fuel pressure because you cannot regulate it. You are pretty limited by the bearing clearances, spring in your pump (or type of pump), and type of oil.
The most important thing is to keep your levels good, run quality oil, and dont romp on it when you have any type of oil pressure issues.
Old 10-07-2017, 07:26 PM   #12
jmc0369
jmc0369's Avatar
bumping this thread. I dint see another thread for proper oil pressure in a NA motor.
I'm installing a speedhut gauge, and need to know what range gauge I should get. 0-100 or 0-60?
That being said, anyone have the pressure ranges expected for a healthy B230F?
Member: TBCCS
"Emancipate yourselves from mental slavery; only ourselves can free our minds" - you know who!
"It is no measure of health to well adjusted to a profoundly sick society" - Jidu Krishnamurti
jmc0369 is offline   Reply With Quote
Old 10-07-2017, 07:30 PM   #13
That depends on a lot of factors.
RPM?
Cold / warm / hot oil ?
What thickness / grade oil?
Old 10-07-2017, 07:46 PM   #14
It depends on where you want the gauge to read when warm. A warm engine will have .3 MPa (43.5 psi) @ 3000 rpm, which is where it will be (or lower) most of the time, but max pressure can reach .8 MPa (116 psi). If you use a 100 psi gauge, you'll be able to see the higher cold pressures, but the needle will be low on the gauge when warm. A lower pressure gauge will give better resolution in the normal operating range.
Old 10-09-2017, 01:36 PM   #15
jmc0369
jmc0369's Avatar
That's good info. I new about temperature,RPM and grade oil impact ion pressure, but wasn't certain about the typical operations range for a redblock.
The real concern is low pressure, right? Time above 60 psi, not usually a concern? If that is the case I like the higher resolution 60 psi gauge. I appreciate y'alls input.
