Old 07-25-2015, 06:19 PM   #1
PromiseRing
We don't even like Volvos
Default Relatively stranded 1,000 miles from home
1993 245
Main pump has always made a bit of a gargly noise. I brought a spare with the assumption that it would fail on vacation..well going up a steep mountain (full tank of gas) the car started bucking and hesitating until it finally shut off. It restart 5 minutes later but the main pump sounded awful. going to grab an adjustable wrench and change it to see if the issue persists.
What are the odds that it's the main pump at fault and not the intank pump also, whatre the odds I can make it home on a failed in tank pump with a fresh main pump?
P.s thanks Roy for the spare fuel pump!
Current
straight pipe
-93' 245 m47-iPd sways, B-cam
Past
-80' 242gt m46-
spill it MClovin and WTF happens to your glasses you piece of ****..
Ps how nice of you to browse my thread history. Next time you want to see up my skirt just message me and I’ll send you a Polish Sausage shots
Feedback Thread
Old 07-25-2015, 06:25 PM   #2
240240
White of Hispanic origin
240240's Avatar
If the intake pump is toast. A full gas tank will slightly help. Not up a mountain help. But it helps. Just don't w.o.t take it easy and you should make it back.
Originally Posted by alschnertz View Post
What would 240240 do?
Old 07-25-2015, 06:25 PM   #3
240240
240240's Avatar
Also where are you located. Watch those hot temps for vapor lock in the gas tank.
Old 07-25-2015, 06:27 PM   #4
PromiseRing
Thanks. I'm in Yellowstone national park. iPhone says temperature is 84 but I feel like it's pretty chilly with the high wind speed.
Edit:nvm temp is 73F.
Old 07-25-2015, 07:21 PM   #5
cleanflametrap
cleanflametrap's Avatar
No laughing matter but a Yellowstone camping trip is where my daughter found she needed a new tank pump. I talked her through the diagnosis on the side of the road, but she had to spend a four day weekend in Riverton WY while a shop ordered a tank pump and installed it. I wrote this up after that: In The Tank
The new main pump might get you home even with a dead lift pump, but keep that tank full and travel during the cool night and stay off the mountain. Right...
Asking about odds is kinda ridiculous outside of Nevada. You can know for sure if you follow the steps to diagnose the pumps.
-Art
Old 07-25-2015, 07:34 PM   #6
PromiseRing
New main pump installed and is muuuuch quieter..
Old 07-25-2015, 07:38 PM   #7
cleanflametrap
To be sure, it would be even if you re-installed the old main pump, because of the cooling that takes place while you do the job. But I have my fingers crossed for you.
Old 07-25-2015, 09:37 PM   #8
PromiseRing
Eh it's kinda loud again. Though no bucking and hesitation.
So am I right saying you can drive a car with a 100% failed in tank pump?
Old 07-25-2015, 09:42 PM   #9
cleanflametrap
Certainly you can. For years even. But not in all conditions, as you have probably learned for yourself. Takes 5 minutes, why don't you find out if the tank pump is working?
Old 07-25-2015, 09:44 PM   #10
PromiseRing
After dinner
I'll put my ear up to the filler neck while my girlfriend primes it?
Old 07-25-2015, 09:48 PM   #11
turbotankshane
Don't forget about that fuel filter man.
Also, I've only ever figured out I've had a fault in the fuel system when I was over 100 miles from home. Dunno what the deal is there. Murphys law I guess
Old 07-25-2015, 09:49 PM   #12
cleanflametrap
After dinner
Might be inconclusive. Read: In The Tank All your questions have been addressed here.
Old 07-25-2015, 11:01 PM   #13
PromiseRing
With fuse #4 out, a jumper from fuse #6 to the left side of 4, the main pump definitely buzzes and gives a nice spark. When I jump it to the right side of 4, (fuse still out) I get no noise almost no spark. The spark is so small I have to squint to see it. It seems like the intank pump is not drawing any current. It's either bad or the wiring is bad.
Old 07-26-2015, 12:45 AM   #14
PromiseRing
Maybe it's just stuck on a dead spot and I can bump it to life tomorrow..
Old 07-26-2015, 02:22 AM   #15
745 TurboGreasel
745 TurboGreasel's Avatar
We EFI converted my friends 63 chevy, and it stranded us one rainy day.
Short on resources, We discussed our options over a burger, pulled the fuel pump, beat it against the curb till it would spin again and reinstalled.
He drove it on that pump 5 more years and has the motor out for a 5.3 conversion now.
I'd give you a 'possible'.
Feedback
Old 07-26-2015, 10:18 AM   #16
Prob torn hose in tank. Time to pull it. Or just drive home with lots of gas and then do it.
Stick hose down tank to listen. Yes car will run with dead tank pump. I just would have sputtering when very very low on gas. That's when I knew I had maybe 15 miles till I ran out. After tank pump swap, now there is basically no warning when about to run out of gas. Just maybe a block or two of sputtering. Side story over.
Old 07-26-2015, 10:25 AM   #17
PromiseRing
Unfortunately I have lots of mountainous driving to do with gas stations few and far between. I'm going to buy a couple gallon gas can and keep it in the back.
We're headed from Yellowstone to Kansas City tonight.
Old 07-26-2015, 10:26 AM   #18
Sorry. Didn't read it all well.
It could be a million things. Not enough info. You need to do tests and inspections. Posting from the dinner table ain't gonna cut it.
Old 07-26-2015, 10:27 AM   #19
PromiseRing
You failed to read again...tested the in tank pump and it's silent. Either it's bad or on a dead spot on the commutator.
Old 07-26-2015, 10:32 AM   #20
Are you driving right now? Ha
Sounds like a fun trip. Gl on the way home.
Old 07-26-2015, 10:48 AM   #21
John V, outside agitator
Instant Karma's gonna get you.
or divine retribution..
Sleezattle WA, USA
--> CALL (206) 431-9696<----
www.rallyrace.net/jvab
www.rallyanarchy.com
Vive le Prole-le-ralliat
— Don Marquis
Old 07-26-2015, 10:52 AM   #22
PromiseRing
For what?
Edit: prolly for being a JohnV.
Old 07-26-2015, 11:16 AM   #23
For what?
You'll never know exactly what you did taht was the root of divine retribution---or karmic debt.
Old 07-26-2015, 11:26 AM   #24
ryanfay
more bounce to the ounce
ryanfay's Avatar
If you can't get a tanker pump maybe a longer section of hose to some kind of parts store strainer so you can draw from the bottom of the tank?
Might get you home.
ryanfay is offline   Reply With Quote
Old 07-26-2015, 12:01 PM   #25
cleanflametrap
Default 240 camping trip in Yellowstone
If your trip goes anything like my daughter's you will have proposed to your gf at a gorgeous overlook in Yellowstone, then get tired of becoming a road hazard on the way out and get towed to Bailey's in Riverton. Only you folks won't arrive on a Friday night and have to hole up for the weekend and then some, in a hotel room. I checked the work done at Bailey's (all told about $250 back in July 09) and all was well. Tank pump is still humming today. And we are enjoying the grandchildren.
The tank pump check is now part of the oil change routine, and that (on another car) has already netted one pump change before the symptoms. And yes, I have a paper clip in the glove box.
