Old 07-29-2015, 06:24 PM   #126
Jack
junkman
Jack's Avatar
Originally Posted by 93Volvo240 View Post
So 26hp loss isn't a lot to you that's a HUGE difference. Especially in a low horsepower car.
Do these lh2.4 cars compensate for the lack of oxygen up there to some extent?
at 8000 ft yes you would feel it but you werent that high most of the time....
also you can downshift with auto--- read your manual sir
dear god thats what mechanical and electronic fuel injection does... why we no longer have carbs
where is JOHNV with his JOHNV 9mm ?
Make old cars great again
Old 07-29-2015, 06:25 PM   #127
PromiseRing
We don't even like Volvos
It was a high enough elevation to notice a big power loss. Don't cry jack.
Current
straight pipe
-93' 245 m47-iPd sways, B-cam
Past
-80' 242gt m46-
spill it MClovin and WTF happens to your glasses you piece of ****..
Feedback Thread
Old 07-29-2015, 06:29 PM   #128
Jack
junkman
Jack's Avatar
not crying
more like this
Old 07-29-2015, 06:29 PM   #129
PromiseRing
And by the way you have no idea how high I was the entire time. Don't act like you know me.
Old 07-29-2015, 06:30 PM   #130
JohnMc
JohnMc's Avatar
There's no way to compensate for that. It simply has less oxygen to work with in each cylinder full.
A turbo car that does electronic absolute boost levels vs. relative (like most mechanical would be) could work the turbo harder and end up making the same hp.
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 07-29-2015, 06:31 PM   #131
PromiseRing
Interesting. It goes without saying that newer turbo cars usually do better in higher elevation than than NA, yeah?
Old 07-29-2015, 06:34 PM   #132
PromiseRing
I didn't notice that many turbo vehicles, primarily 90s, 5 speed Impreza and legacy outbacks. At least a few hundred.
Old 07-29-2015, 06:36 PM   #133
Jack
junkman
Jack's Avatar
how you see youself
how tb sees you
How I see you
how I wish you were
how you really are
Old 07-29-2015, 06:55 PM   #134
PromiseRing
^ HAAHAHAHHAHAHA the mclovin one and last one are the most accurate. I take pride in looking like mclovin. I could lose the glasses but being a 240 wagon driving mclovin is just WHO I AM, BITCH.
Old 07-29-2015, 06:56 PM   #135
Jack
junkman
Jack's Avatar
dont ever tell me I dont know you bitch
Old 07-29-2015, 06:57 PM   #136
PromiseRing
This thread stayed pretty on topic for a while. I'm surprised.
Old 07-29-2015, 07:15 PM   #137
240240
Terminal 11 trickster
240240's Avatar
Time to send in the big dawgs to finish this thread.
I know what I have, and you can buy it here
Old 07-29-2015, 07:20 PM   #138
PromiseRing
We loved you John Candy.
Old 07-29-2015, 07:53 PM   #139
Lord_Athlon
Sf1k Kryptonite
Lord_Athlon's Avatar
Were you even alive when he died?
Originally Posted by rvolvor
Old 07-29-2015, 08:33 PM   #140
PromiseRing
Idunno. Am I allowed to appreciate an actor whether or not I was alive when they died?
Old 07-30-2015, 04:42 PM   #141
One hundred gift baskets
Why not mechanical waste gate keep up more power, it takes 14 psi to overcome that spring tension in the WG actuator, doesn't matter if it's at sea level or not.
1980 primer JDM flares franken-242DL, 1989 silver 780 bone stock.
Old 07-30-2015, 05:45 PM   #142
John V, outside agitator
how you see youself
how tb sees you
How I see you
how I wish you were
how you really are
You asked where'z I's? Busy fixing lunch for 3 girlies girls...Don't worry you're doing just fine with this post here as in PLUS Juan Billion...
The kid said "You don't know how high i was"
Well at least its legal now in Colorado
Sleezattle WA, USA
--> CALL (206) 431-9696<----
www.rallyrace.net/jvab
www.rallyanarchy.com
Vive le Prole-le-ralliat
— Don Marquis
Old 07-30-2015, 05:50 PM   #143
I've wondered a bit about this myself..On some cars like that Frod whatevar Crossways thing I have its a map sensor system..EUC senses absolute manifold pressure and then the ECU controls the waste gate actuator (pulsing the solenoid thang over there)
So on this system if it doesn't se 2 bar in the manifold it doesn't waste off anything and the wastegate stays close 9and the poor little turbo spoools its brains out a little more) until it makes 2 bar boost..
That seems like altitude and reduced baro wis taken car of..
On other systems it should be similar... Like LH the electric element doesn't sense the volume and cool down so ECU says to waste gate "so solly lound eye no relief for YOU!"
Old 07-30-2015, 06:32 PM   #144
Khrrck
Professional Amateur
Would atmospheric pressure on the outside of a mechanical/spring wastegate affect its operation? I feel like a gate with 1 bar of sea-level air pressing against it should open slightly later than one at 5,000 ft, and thus build more boost.
Not sure how significant it is, since 5,000ft is only ~2 psi less of atmospheric pressure.
'87 240 budget wagon.
Old 07-30-2015, 06:32 PM   #145
JohnMc
JohnMc's Avatar
It's 14 psi over the ambient air pressure.
The ambient air pressure is lower, so adding 14 psi to it is still lower than adding 14 psi to a higher pressure.
I.e. at sea level there is about 14.7 psi of ambient air pressure. Add 14 psi of boost to that and you have 28.7 psi trying to fill each cylinder of air (with varying degrees of success - the volumetric efficiency).
Drive up to 12,000 feet and you have about 9.5 psi of ambient air pressure. Add 14 to that and you only get 23.5 psi trying to fill each cylinder. Obviously, that's dropping less of a percentage than a normally aspirated car will, but it's still a drop.
A car that is electronically regulating boost levels to an absolute pressure target will work the turbo harder, and assuming the turbo isn't maxed out in capacity, will still try to work up to that regulated 28.7 psi, making 19.2 psi of relative boost to accomplish it. Net result, no loss in power at all.
Old 07-30-2015, 08:11 PM   #146
PromiseRing
Nah I was just kidding, I don't smoke. I only drink
Koolaid
Old 07-30-2015, 08:40 PM   #147
Jack
junkman
Jack's Avatar
thats why I posted Phelps SIR
Old 07-31-2015, 10:51 AM   #148
I get it now, thanks!
Old 09-29-2015, 02:36 AM   #149
PromiseRing
I finally replaced the intank pump today. The main pump is much quieter and happier.
I pulled off the return hose and not much came out.
Then I clamped off the feed hose with some vice grips and disconnected the main hose from the main pump. Reasoning for the vice grips is due to siphoning lol. Ask me how I know.
yadayadayada remove pump, don't drop anything, clean the rim with many q-tips. install new VOLVO seal (not pictured).
I needed a new sender as well so I transferred what I needed from the old one to the new one. I reused the 3" tubing even though I bought the $6 piece from iPd It was much easier to fit and still in great shape. I also swapped the original float ball to the new sender because some of them are known to leak. FWIW, my aftermarket cheapie sending unit was NOT wired backwards. New filter sock as well.
Reinstalled the pump, it took me a while to get the float ball back in there and I kind of forced it, but it works.... I tightened everything down and installed a brand new r9 rated 5/16" hose for the return. I ordered some 12mm r7 hose for the feed (r7 should work I hope..) but it hasn't arrived yet so the stock hose went back on.
So new
-pump
-sender
-seal
-filter sock
-fuel lines off tank
It feels reliable now.
Old 10-10-2017, 06:00 PM   #150
PromiseRing
Who has the lead on high quality fuel hose? The r7 and r9 that were brand new 2 years ago are severely cracked/dryrotted and causing concern. No excuse for it to wear out this prematurely. IIRC i spent a prety penny on both fuel lines in hopes that they would last the rest of the cars lifetime.
https://www.tasteslikepetrol.net/201...-r9-fuel-hose/
I will have to check for sure which brand I installed but I will most likely opt for Gates or some other reputable company. Hopefully others will see this (and the above link) and stray away from 'cheap suitable fuel line'.
