Old 09-27-2017, 10:53 AM   #1
autoloclys
Default fuel distributor rebuild kit info needed
There are a number of rebuild kits available on ebay via "cis-jetronic" (they also have a standalone webstore)
This is the kit i believe I need
Does anyone have any experience with their product?
Can anyone confirm the correct kit for the B21FT in an 1984 245?
Any advice or links to detailed info on the procedure to do the rebuild?
autoloclys is offline   Reply With Quote
Old 09-27-2017, 10:55 AM   #2
Bricktothefuture
Under the years of grime and grease on the body of the fuel distributor you should see a small brass/metal plate with a model number - as long as it matches the kit I'd think you're good to go. I'll let more experienced folks chime in but I've always been hesitant to disassemble one of these units - they can be picky about how they go back together...
Bricktothefuture is offline   Reply With Quote
Old 09-27-2017, 11:00 AM   #3
Jack
junkman
Jack's Avatar
have you tried cleaning it first?
Soak it in mineral spirits for days
Originally Posted by toms_elleck View Post
I regretfully agree with Jack.
Originally Posted by 122power View Post
make k-jet great again.
Old 09-27-2017, 08:41 PM   #4
sisu_slay
yes, try soaking it first with mineral spirits or berryman b12. if that does not work, i would highly recommend sending it to john hervey at delorean auto parts for a rebuild or a refurbished one. unless you know exactly what you are doing and using permatex indian head, it's guaranteed to either leak or not be calibrated correctly.
sisu_slay is offline   Reply With Quote
Old 09-27-2017, 08:44 PM   #5
TestPoint
TestPoint's Avatar
I have taken two apart, one survived. Really not much to go wrong except for trash blown through the fuel filter.
What are you trying to fix?
Ford V8 Conversion Manual -
Old 09-27-2017, 08:46 PM   #6
Post in wanted for a known good takeoff.
how psi a stock can support?
Old 09-27-2017, 09:44 PM   #7
autoloclys
Its probably premature to say for certain that the fuel dist is the root cause of my issue. my current situation is that its much easier to do internet research than spend time under the hood doing proper diagnosis (2 small kids, long commute and no garage space/poor lighting in the driveway) I am new to fuel injection in general and mechanical injection in particular. I do have the bentley manual and I know there is a step by step procedure for going through a CIS system that starts upstream of the fuel distributor and I have not been able to work through that yet.
the issue is an 84 245 Ti that has sat for a couple years is now my project. It is running only on 3 cylinders (missing #2 from the front). Spark is good. Injector is clear. With the injector removed the fuel line to it, is only dribbling an anemic amount of fuel. So i suspect an issue at the distributor, since even with the missing cylinder the engine runs well enough that i doubt fuel delivery is an issue for the other cylinders.
happy for more opinions though
Old 09-27-2017, 09:51 PM   #8
centason
Wine enemas for all
centason's Avatar
Did you check the wiring harness? The insulation tends to just get crusty and fall apart in the mid 80s.
Member: TBCCS
Death to all who stand in the way of obtaining the freedom of working people!
Just remember this guys. Im related to cocaine.
they were pushing sloppy poo up a steep hill with a pointy stick.
Any forums history.
Old 09-27-2017, 09:59 PM   #9
nel621
Wash the diaphragm before using, note the stick out of the plunger before you remove it, don't use any gasket sealing goop. If the springs and seats and discs are all in the right place it should go together nice and snug. Be patient and meticulous. The Delorean guys do a good job ($$$) compared to the cost of the rebuild kit. You need to make sure the screens are very clean. Soak the parts and find a way to agitate the solution, home made ultra -sonic.
Old 09-27-2017, 10:03 PM   #10
nel621
Injector or distributor? Switch two injectors. Same result?
Old 09-27-2017, 10:16 PM   #11
Jack
junkman
Jack's Avatar
he pulled the injector off and it was meh
op remove line at dizzy and see if you get flow. Hopefully it's just the line or banjo
Old 09-28-2017, 01:38 PM   #12
PCH
I was able to fix fuel delivery (make it almost even on all injectors) and get good performance by running couple of gallons of 30% agricultural strength vinegar through the system. Did that to may be 5 K-jet systems back in the day. It will not help if the diaphragm is worn out or corroded but it cleans out calcium and grime very well.
Old 10-02-2017, 05:04 AM   #13
powerstroke4you
powerstroke4you's Avatar
Default K-Jet Is FANTASTIC
K-Jet fuel dist usually last 500K before needing a rebuild !! BUT they really dont like sitting around for long periods . Run the strongest fuel cleaner in the gas tank for 3-4 fill up,s if you can ,,, believe me it, not a amateur,s repair job ( opening one up ) I watched a cuban mechanic rebuild one as he was talking and explaining to me what he was doing in Miami it was one for a Rabbit Volkswagen. The springs have to be just the right height , than there are these flying saucers, really not a easy job . Now if you can take apart a swiss clock , AND put it back together go for it .. I usually just clean the out side -lotsa fuel cleaner an drive it hard
powerstroke4you is offline   Reply With Quote
Old 10-11-2017, 10:33 PM   #14
autoloclys
update. New (used) fuel distributor solved the issue! Thanks dobber13!
