Old 10-01-2017, 01:16 PM   #1
yarchlrl
Default fuel pump issues AGAIN!
Has anyone gone to a single fuel pump and avoided this BS in tank issue yet? I am sure someone has. If so, can you post what pump and supplies you used?
Thank you ...
yarchlrl is offline   Reply With Quote
Old 10-01-2017, 01:23 PM   #2
oldschoolvolvo
oldschoolvolvo's Avatar
I have not done this modification, but fellow tbrickers have upgraded to the DW200/300 pumps.
http://forums.turbobricks.com/showthread.php?t=276967
-Mike
1998 V70 T5
oldschoolvolvo is online now   Reply With Quote
Old 10-01-2017, 01:31 PM   #3
yarchlrl
Thank you. I have put in 3 Airtex pumps in 1200 miles. This is ridiculous...
Old 10-01-2017, 01:36 PM   #4
yarchlrl
I am wondering if anyone has tried AEM yet and if so, how well does it work.
Old 10-01-2017, 01:53 PM   #5
lummert
lummert's Avatar
I'd be searching for the cause of the failing pumps. My guess is that it's not the pumps that are at fault.
Old 10-01-2017, 01:55 PM   #6
coalminer
coalminer is offline   Reply With Quote
Old 10-01-2017, 02:10 PM   #7
yarchlrl
I's be searching for the cause of the failing pumps. My guess is that it's not the pumps that are at fault.
First two were warranty due to impeller cracks. They were great about replacing them but, all this install remove stuff is for the birds. I dont know why THIS one failed yet as it is still in the tank until the new DW300 arrives. Just ordered it.
Old 10-01-2017, 02:35 PM   #8
PromiseRing
We don't even like Volvos
Which airtex pump have you been installing? I installed the one that Art recommends in this writeup. It's an airtex E8778, and mine has been going for over 2 years.
Current
-93' 244 m47-iPd sways, 13c, iPd cam, 2.5
straight pipe
-93' 245 m47-iPd sways, B-cam
-94' M-Edition Miata-Stock with a hardtop
-95' Toyota Camry-auto 5sfe car. It was free
Past
-80' 242gt m46-
-92' 940 turbo, got for free, fixed, sold
Feedback Thread
can't replace u joints
Old 10-01-2017, 05:40 PM   #9
yarchlrl
2 8381, 1 8778 current.
Old 10-01-2017, 06:10 PM   #10
brickyard92
Regular Contributor
brickyard92's Avatar
Well you know the reason for the 1st two,cracked impellers.That's not on you bud.Soo you are really talking about the 8878. I installed one in my 740 wagon a while back and did not solder it good enough.That one was on me! Don't want to imagine what could of happened.
If you're the smartest person in the room, You're in the WRONG ROOM!
brickyard92 is offline   Reply With Quote
Old 10-01-2017, 07:20 PM   #11
PromiseRing
I bet it's a wiring issue. My original in tank pump never failed, but the electrical feed through on the top of the sending unit did. There was continuity and it put 12v to the pump, but it could not pass enough current to power the pump.
So I replaced the the in tank pump with the airtex, and replaced the sending unit.
Old 10-02-2017, 01:48 PM   #12
yarchlrl
sending unit is 9 months old, OEM, checks out fine. wires are fine. Put a new ground bolt in for the pump as well. Just a dead pump.
Old 10-02-2017, 02:10 PM   #13
PromiseRing
Have you since pulled the 8778 and bench tested it?
Old 10-02-2017, 04:20 PM   #14
yarchlrl
not yet. not till the DW300 arives.
Old 10-03-2017, 11:40 PM   #15
Nayo
Nayo's Avatar
Running AEM green ones on E85 on my 740 & 940 not a problem
Nayo is offline   Reply With Quote
Old 10-04-2017, 12:19 AM   #16
90volvo
I installed one pump in the tank. It wasnt bad and works great. Reason I did it was for simplicity and both my pumps were shot. I ran new wiring and did fuel pump relay mod. I can can give you part number if you need it.
Old 10-04-2017, 12:22 AM   #17
tryingbe
Boosting along.
tryingbe's Avatar
I have a DW300 on my GLH and DW200 on my 850.
3 year no fault warranty, SUPER quiet, flow plenty, and I don't have to worry about fakes pumps since I can buy directly from factory.
Works for me.
85 GLH 367whp
00 Insight 72 mpg
Old 10-04-2017, 11:32 PM   #18
yarchlrl
please do
Old 10-05-2017, 11:25 AM   #19
PromiseRing
please do
New pump come in yet? Im curious to see if the 8778 failed.
Old 10-09-2017, 09:41 AM   #20
yarchlrl
yes it did. I am going to swap it today.
Old 10-10-2017, 11:18 AM   #21
PromiseRing
And the verdict is....?
Old 10-15-2017, 02:11 PM   #22
yarchlrl
well, old pump is definitely shot. impeller is frozen. new DW300 is in and works great for 30 or so seconds then the car dies. put a 30A circuit breaker on the main pump, new fuel pump relay and still, CB and FP relay are getting super hot then, shuts off. next step is to pull the main pump and check all the wires to it, again... so frustrating!!! getting major over amp somewhere. Thanks for the help fellas. Truly appreciate it.
Old 10-30-2017, 04:15 PM   #23
PromiseRing
So was the failure of the E8778 pump the pumps fault or something else? Many seem to have good luck with this model.
Old 10-30-2017, 09:54 PM   #24
gsellstr
gsellstr's Avatar
Been thru....1 E2366, only reason I pulled it was to step up to an AEM Green 320 I got for a good price. That 2366 had 5 years or so on it, pressures as high as 80psi at full tilt, never burped. Only issue it was was the lack of a barb fitting so the hose came off a couple times as the hose got soft (yes, submersible hose, but ****ty apparently).
RIP
Mark Baldwin aka blue850t5 7/19/18
Nick Fengler aka fengler 8/6/18
74 144 B20
90 745Ti
Old 11-05-2017, 12:14 PM   #25
yarchlrl
completely frozen. no idea why. it simply wont spin. but, I put a new DW pump in-tank and main and tbh, holy wow.... HUGE difference in the car now.
