Old 10-04-2017, 10:05 PM   #1
DStarratt
Default M46 Rear Seal Replacement - Retaining Nut Size?
I have an 82 242 and a leak at the rear of it's overdrive. I'm going to replace the s al. Looks like an easy enough job. I'd like to have all the tools and parts onhand. Does anyone know the size of the flange retaining nut? I want to make sure I have the right socket in advance.
Also, the Haynes manual says to put "locking compound" on the output shaft splines. Does anyone know what they mean by locking compound?
Let me know if you have any other tips for this job.
Thanks.
DStarratt is offline   Reply With Quote
Old 10-04-2017, 10:15 PM   #2
1 & 1/8" iirc, and you'll have to pry on the old seal pretty good with a couple screwdrivers to remove it.
Old 10-06-2017, 11:35 PM   #3
DStarratt
Thanks! Any tips for holding the flange steady while breaking that retainer nut loose? The nut is on there very tight and i keep turning the flange with the nut, even with the car in gear.
Old 10-07-2017, 12:26 AM   #4
I just blast the nut off with an air gun, but I get the impression you don't have access to one.
This is the Volvo tool for holding flanges. You may also need a puller to get the flange off the tail shaft. Sometimes they come right off and sometimes they don't.
Old 10-07-2017, 12:36 AM   #5
Pipe wrench to hold the flange or an impact as hiperfauto says.
Old 10-07-2017, 01:00 AM   #6
DStarratt
No air tools here. That volvo tool looks cool but I don't see me getting one this weekend. I'll see what I can do with a pipe wrench. Thanks!
Old 10-07-2017, 01:03 AM   #7
You could put a socket and breaker bar on the crank pulley bolt, but it just might loosen that instead of remove the nut.
Old 10-07-2017, 11:22 AM   #8
planetman
planetman's Avatar
You can install 2 of the driveshaft bolts and nuts in adjacent holes in the flange and use a screwdriver or prybar wedged between the 2 bolts to keep the flange from moving by using the floor as stop.
Eric
Torrance, CA 90502
Old 10-08-2017, 05:53 PM   #9
DStarratt
Thanks! I looked for a spanner wrench but couldn't find one. I bought a fan clutch wrench at Northern Tool and it fit perfectly on the flange. It bolted onto two drive shaft bolts. It is nice and thin and it worked like a charm. Best $10 I ever spent. I recommend it for anyone doing this job without an impact wrench.
