Old 10-05-2017, 08:09 PM   #1
dirtbag240
Default More crack pipe ideas/ s60 seats in a 240
More crack pipe ideas but
At the local pick a part there's an 04 s60 with 2 tone real leather bucket seats for 25$ cad a piece ( like 18 USD)
Is there any way to make em fit??
dirtbag240 is offline   Reply With Quote
Old 10-05-2017, 08:12 PM   #2
PromiseRing
We don't even like Volvos
yes
Current
straight pipe
-93' 245 m47-iPd sways, B-cam
Past
-80' 242gt m46-
spill it MClovin and WTF happens to your glasses you piece of ****..
Feedback Thread
Old 10-05-2017, 08:26 PM   #3
dirtbag240
Originally Posted by PromiseRing View Post
yes
There is??
Old 10-05-2017, 09:35 PM   #4
gsellstr
gsellstr's Avatar
Yes. A local here did it, not sure what was required.
RIP
74 144 B20
90 745Ti
Old 10-05-2017, 09:41 PM   #5
dirtbag240
So you by a chance remember why it was ,or is there a thread you could link me too
Old 10-08-2017, 12:53 AM   #6
dirtbag240
Does anyone know who managed to make them fit ?
Old 10-08-2017, 03:23 AM   #7
smeha
Tranny Whisperer
smeha's Avatar
Dude simple, take a bendable ruler and measure around the back and bottom, take a needle. Be a fkn man and sew it.
My Feedback Thread
Old 10-08-2017, 10:51 AM   #8
nel621
You just have to figure a way to mate the new seat to the 240 seat rail frame. Maybe some welding or just drill and use nuts,bolts and lock washers to mate everything together.
Old 10-08-2017, 02:09 PM   #9
Funkee
Funkee's Avatar
Get them anyway for that price. I put S60 seats in my 142, made custom brackets for them.
Old 10-08-2017, 08:30 PM   #10
gsellstr
gsellstr's Avatar
vaderfpu - Dean.
Old 10-08-2017, 09:30 PM   #11
dirtbag240
Dud you get the manual or electric ones?
Old 10-08-2017, 09:33 PM   #12
tryingbe
Boosting along.
tryingbe's Avatar
I put 940 seats in a 240, we welded the brackets.
My GLH only need metal strips, bolts, and nuts to fit Recaro seats. Though welding would probably be cheaper.
My Insight required welding to fit RX8 seats.
85 GLH 367whp
00 Insight 72 mpg
94 855 in hibernation
Old 10-10-2017, 02:27 AM   #13
Funkee
Funkee's Avatar
Electric. They work for 30s after putting power on them.
Old 10-10-2017, 03:00 AM   #14
VolvoGuy123
VolvoGuy123's Avatar
this is a great idea! I wanted to do something similar with my 940.
VolvoGuy123 is offline   Reply With Quote
Old 10-10-2017, 12:48 PM   #15
dirtbag240
So 30s every time you turn the car on or 30s one and then they are locked there
Also did toy have to cut and bolt some adapters together or were you able to use the stock rails?
Old 10-11-2017, 03:41 PM   #16
Funkee
Funkee's Avatar
Yeah, 30s after turning the key, if you needed more time just flick the key again and another 30s. Worked fine.
You're lucky, I found some pics back from 2006
I used the stock rails and welded some tube with a nut inside in place. Not the way I would do it today though but it worked fine.
Also crammed a S60 rear seat between the wheel tubs. Could've done a better job upholstering them, I used the leather that came off the side pieces.
In the last pic you can see the wiring I used for testing the seats, only put a switched 12V to them.
IMG_4709
IMG_4710
IMG_4711
IMG_4719
IMG_4720
IMG_4721
Old 10-13-2017, 04:11 PM   #17
dirtbag240
Mm okay looks good, I'm not going to worry about the rears as I have a wagon and making that work would be a pain me thinks
Did you only have to connect to a single power line or was it 12v to all of the 10 connections?
And if you could re do it how would you, as you said it wasn't the way you'd do it now?
Old 10-15-2017, 05:23 AM   #18
Funkee
Funkee's Avatar
Just a single line. Not sure which one. edit: I remember I got some wiring diagrams from a dealership back then.
I wouldnt weld the rear supports directly to the floor without reinforcement, or adapt the existing mounts. Cant remember how they look like anymore.
Old 10-25-2017, 09:36 PM   #19
dirtbag240
To bring back the dead, what do you think the best way to test and see if the motors are fried is outside of the car??
Old 10-26-2017, 01:47 PM   #20
tryingbe
Boosting along.
tryingbe's Avatar
A 12v battery, some wires, a multilmeter, maybe some alligator clips.
Old 10-26-2017, 05:39 PM   #21
Funkee
Funkee's Avatar
^ that.
