Old 10-07-2017, 02:22 AM   #1
Svenska_Monokrom
Tormented by volvos
Svenska_Monokrom's Avatar
Default Steering returning to center with force
So yet another issue with this new 940 I purchased,
Basically the issue now is with the steering basically fighting you to return to center when turning. And when you let go of the steering wheel mid turn, it doesn't even consider doing it smoothly, it just instantly snaps back forward.
The alignment is perfect in terms of pulling or such like that. I'd almost prefer the car pulling than it fighting me when making any turn.
To clarify this in a way that I can understand (cause I over word things lol):
Basically say when I turn right, the steering wheel would fight me to return to center creating the feeling that the steering wheel is resisting turning making it slightly dangerous to drive even around tight turns. It's controllable but if any other person were to drive my car for the first time, it'd probably scare the crap out of then lol...
Im trying to find a solution that doesn't involved another alignment but it's seeming like that's gonna have to happen unless someone can give me some troubleshooting steps or give me something to check that can possibly cause an issue like this.
Thanks peeps.
__________________________________________
#Unappreciative volvos.
#Hooligans Anonymous
#MakeTheSeLegalAgain
#MakeThe2RunAgain
#BoostToTheMoon
1986 245T - Sketch
1991 940se - Dead
1994 940T Wagon - Dead
1996 960 Wagon - Dead
1998 S70 - Dead
1999 v70 T5 - Always breaking....
2001 s60 - Slow as hell
Svenska_Monokrom is offline   Reply With Quote
Old 10-07-2017, 05:25 AM   #2
TestPoint
TestPoint's Avatar
Sounds like you have some hydraulic assist going on.
Sorry, you need to replace the rack . . . and do another alignment.
Ford V8 Conversion Manual -
Old 10-07-2017, 06:20 AM   #3
John242Ti
trouserman
John242Ti's Avatar
Any weird noises when it's doing this? Our 760 seems to be doing something similar, but I think in that car's case, it may be due to low fluid, since it doesn't seem to do it when you're at normal driving speed, but only at low speed or at a stop. As an example, when you're making a U-turn in a cul de sac, it'll be rather twitchy and noisy.
1982 242Ti - black, M46. 1985 245Ti - blue, M46. 1989 745Ti - red, Aw71.
Formerly Blue245Ti, 245GT-Turbo, and, originally 242GT-Ti.
Old 10-07-2017, 01:00 PM   #4
lummert
lummert's Avatar
My 765 had a similar issue (in that it resisted turning the steering wheel at highway speeds) that resolved itself when I installed wider 215/60R15 tires.
Old 10-07-2017, 01:01 PM   #5
lummert
lummert's Avatar
In your case I suspect a slipping crankshaft pulley.
Old 10-07-2017, 01:16 PM   #6
viking20
Could be the joints on the steering tube/axle wth its called in your language. The lower one often seize up
viking20 is offline   Reply With Quote
Old 10-08-2017, 03:39 AM   #7
John242Ti
trouserman
John242Ti's Avatar
Close. Loose belt. Checked when I got home this afternoon. There's a bit too much slack in said belt. Not enough to cause the engine to run hot, but, it's enough to cause the pump to squawk like a hen being knocked up by a rooster when the steering wheel is turned at low speeds or when stationary. So, going to crawl under the car in the evening tom'w and retension the belt.
-J
Old 10-09-2017, 02:38 AM   #8
MasterBlaster
Just one direction, or both?
Waaaay too much positive caster?
Non-stock wheels with too much offset?
Even horribly mangled suspension can be "tweaked" to go straight.
Here's my muchly over-wordified casterization theory:
With positive caster, when you turn the wheel (right, for example), the inside (right) wheel basically wants to tuck under the car (extreme example), lifting that corner up a bit, while the other (left) wheel lets its corner drop. The act of "jacking" the right corner up helps to center everything when you let go, as there's now more weight on the right wheel, pushing it back up into position. Turn left, the left wheel tucks, gets more weight, and gets pushed back up. Way too much caster (without changing other settings to compensate) can increase the "pushing" force past the tolerable level.
Even with stock settings, if your wheels are offset too much (sticking out of the fenders like the "Kewl" kids), the wheels now have more leverage, and can push up even harder.
456,000 km so far...
Old 10-10-2017, 03:59 AM   #9
Shifted
C&M '17 Survivor
Shifted's Avatar
Look at tire wear, inners going first says too much toe-out.
Yeah just because it goes straight doesn't mean dick about proper alignment. Could still be way off either way.
Originally Posted by ME II View Post
Without mistakes there is no learning.
"Ego is the anesthesia that deadens the pain of stupidity" - Rick Rigsby
Shifted is offline   Reply With Quote
