Old 10-07-2017, 02:20 PM   #1
speedn_j
speedn_j's Avatar
Default Sender float ball fell off inside gas tank
Was changing intank pump and the floater popped off inside the tank. Been trying to fish it out for the last hour. Would filling the tank with more gas work or would emptying the tank be a better option? Has 3/4 right now. It's stuck in the far corner and can't get it to float out no matter what I do
i'm too sexy for RWD
2000 mb c230 kompressor
2000 ducati 748 45k miles
2004 jeep grand Cherokee overland
1988 volvo 245
speedn_j is offline   Reply With Quote
Old 10-07-2017, 02:35 PM   #2
Try blowing compressed air into the filler tube. That should get the float moving. If all else fails, get a new one.
https://www.oreillyauto.com/detail/v...?q=VDO+600-601
Old 10-07-2017, 02:49 PM   #3
Mr. V
Mr. V's Avatar
Or failing that, what about jacking the car up at different points in order to induce it to float in the correct direction towards the opening?
Old 10-07-2017, 03:05 PM   #4
swedefiend
I would try a coat hanger with a loop on the end just slightly larger than the loop on the float arm.
Try to lift it up using the hoop as a basket. Kinda like the little "tool" in an easter egg dye kit.
Old 10-07-2017, 03:12 PM   #5
speedn_j
speedn_j's Avatar
I got it. Added 5 gallons and it came right out with egg tongs. Now I got everything back together and it won't fire up
Old 10-07-2017, 07:13 PM   #6
tryingbe
Boosting along.
tryingbe's Avatar
Check your work.
85 GLH 367whp
00 Insight 72 mpg
94 855 in hibernation
Old 10-07-2017, 09:25 PM   #7
TestPoint
TestPoint's Avatar
There have been many reports of non-OEM in tank pumps having leads turned over.
http://cleanflametrap.com/transferPump.htm
Ford V8 Conversion Manual -
Old 10-07-2017, 10:30 PM   #8
speedn_j
speedn_j's Avatar
I jumped the fuses and it fired right up. Took the jumper off and it still ran. Drive around for a bit ..went to a friend's house ..then to the liquor store. Ran like a dream. I come out of the store and it won't start. I jumper it again and it struggles. 30 minutes later I got it going..thinking the main pump is shot also
Old 10-07-2017, 10:33 PM   #9
Is it noisy at all?
If so it's garbage.
Old 10-07-2017, 10:35 PM   #10
speedn_j
speedn_j's Avatar
Is it noisy at all?
If so it's garbage.
It is when the gas is low..i originally thought the noise was from the prepump.
