![]() hey guys so i had to change my alternator and battery on my 145 with a b20e and now my charge light stays on and car wants to die when i come to a stop. any ideas?
![]() Is the alternator charging ? Have you checked the voltage at the battery when it's idling with a multimeter ?
I'm assuming the belt is tight enough and not slipping ? |
![]() no i haven't checked yet i cant find my meter
#4 |
![]() Did you change the external voltage regulator? Is it a mechanical or electronic voltage regulator?
Eric Hi Performance Automotive Service (formerly OVO or Old Volvos Only) Torrance, CA 90502 |
#5 |
![]() i hate to sound stupid but i didnt know it has one
#6 |
Boosting along.
![]() Get it first.
85 GLH 367whp 00 Insight 72 mpg 94 855 in hibernation |
#7 |
![]() Yes, it should have 1. They are usually mounted on the right inner fender or radiator core support. Follow the alternator harness to find it.
Mechanical regulators should be changed every time a new or rebuilt alternators are installed. Electronic voltage regulators are usually reuseable. |
#8 |
![]() so i couldn't find it i ran down the wire and it ran to a connector so i picked up one from ipd and wired it in now i was getting voltage but the amp light was flickering so i was able to drive the car but when i got back and shut off the car the voltage dropped down to 10. am i missing something here?
#9 |
Professional Amateur
![]() What voltage were you getting with the engine running?
Is your battery good? Was it under load when you checked it with engine off? Got a trickle charger you can top it up with? |
#10 |
![]() battery is good and it was running 12-13 running i didnt re check it till i couldnt start the car again. i have to pick up my charger tomorrow
#11 |
C&M '17 Survivor
![]() Can't be bothered to spell 'Bosch' correctly.
Can't be bothered to speak in coherent sentences or use capitalization or proper punctuation. Can't be bothered to find your vom to do some actual checking on your own. ...Go Fish. |
#12 |
![]() actually i did find my meter thank you and if you want to talk **** go somewhere else.
#13 |
One hundred gift baskets
![]() Should be minimum 13.5v running. 12. something means it's not charging.
1980 primer JDM flares franken-242DL, 1989 silver 780 bone stock. |
#14 |
![]() huh well i might have to bite the bullet and have a shop take a look at it
