Old 10-08-2017, 02:16 PM   #1
Funkee
Funkee's Avatar
Default FPR O ring part number
Recently I changed my FPR for a used one, but I damaged the O ring.
Now I can't seem to find the part # on just the O ring, does anyone have the right number for me?
It's 18 on the image below, although that seems more like the hard plastic washer instead of the rubber O ring.
Old 10-08-2017, 02:31 PM   #2
It's the same o-ring as the injector seal and Volvo doesn't sell it separately. You have to buy an injector re-seal kit.
https://www.tascaparts.com/oem-parts...ng-kit-1346393
The Bosch part # is 1 280 210 711. You should be able to cross reference it to something at your local auto parts store since most injectors use the same seal.
Old 10-08-2017, 02:43 PM   #3
Funkee
Funkee's Avatar
Ok thanks, I thougt it looked a little thicker than the injector rings, but if they're the same I'll order a set and see what it does.
Old 10-08-2017, 04:01 PM   #4
lummert
lummert's Avatar
It's the same as used for Ford injectors. The o-rings are available in boxes of 4. Any parts store should have them in stock.
