Old 10-08-2017, 03:37 PM   #1
prometheus_aflame
Default 1990 245: No console lights around dash interior
1990 245 NA. 250k on the clock purchased as a daily. The car runs ok and needs some TLC. My first agenda item is the interior backlight lights on the dash and shifter. All of the lights are out except the dimmer bulb on the cluster, the cluster lights, and the momentary switch lights on the dash when engaged. I had a look at the fuse panel diagram and fuse 16 appears to control interior lights. Turning the dimmer switch on the dash brightens the bulb in the cluster, but not the backlit portions of the rest of the interior. The internal roof light doesn't work either. I had a problem on the road where the headlights cut out and I had to reengage them by turning the light selector switch back to standby (position 2) and them back into the full beams (position 3). I've been looking for anything online related to the dimmer itself, but it doesn't appear to be fully dead, just not lighting up the interior. Help is appreciated.
prometheus_aflame is offline   Reply With Quote
Old 10-08-2017, 04:39 PM   #2
amazonphil
ive seen headlights fail and replaced the switch temporarily with a pull switch from a 122, its just a switch. You can check it with a meter to see if it is working or bunned. when you turn the lights off and back on you are also opening and closing the contacts inside the headlight relay. they may be blackened and intermittent. if you pull the relay maybe you can pop the cover and pull some 400 grit wet or dry sandpaper through the contacts to get it going until you get a new one. headlights are important so I'd replace it if you have issues. the dash light dimmer is probably a variable resistor , you could jump it and get full brightness or replace it If it still kind of works i'd see if you can measure the ohms resistance with it unhooked and you can likely replace that with another variable resistor or even use a switch to engage a resistor for half or part brightness instead. If you hooked it so you had a switch and half brightness or full brightness that might be good enough, who needs the variable feature really? you might try spraying the switch with de-oxit to see if that revives it.
also check the buttons on the door, they often go flakey causing the interior light not to come on when you open the door but the dome light should still work in the always on position. if someone has been changing the radio or the heater blower or pulled the tranny then sometimes the little lights and things get left unplugged. Its really cool to get them all going at once, not uncommon some don't work.
if your fuses are going oxidised it's worth the time to unhook the battery, pull all the fuses and clean the fuse holders with a brush and contact cleaner then refit new fuses. sometimes the fuses get corroded or sometimes they can break with out appearing blown.. you can check each one with a meter to make sure you have continuity through each fuse. if the fuse holders get hot from a bad contact they can use their springiness, see if they are weak, sometimes you can re-form them a little to get them to hold the fuse with better tension. .
if you have fingers the size of a three year old that's perfect for pulling the fuses. If not get some spares, I always seem to drop them and they go down under the floor carpets never to be found until you have to pull all that apart so good to have a few spares, or think ahead and lay a cloth down to catch them.
amazonphil is offline   Reply With Quote
Old 10-08-2017, 06:03 PM   #3
billkaz
Bomber Dream
billkaz's Avatar
Had a similar issue with the first Volvo I bought. Turns out all the bulbs were burnt out.
1992 240 Wagon
2006 Mazda6 Wagon
billkaz is offline   Reply With Quote
Old 10-08-2017, 10:53 PM   #4
prometheus_aflame
Do I have to remove the instrument cluster to wire these two leads together? I found the following related forums that seem to reference the same problem.
http://forums.turbobricks.com/showthread.php?t=263767
http://forums.turbobricks.com/showthread.php?t=290170
Old 10-09-2017, 10:26 AM   #5
Kenunot
The dimmer either works or it doesn't and it sounds like yours works. As was said, it's likely bulbs are out. Connectors can also be corroded, just troubleshoot light by light. It took me a little to get all the cabin doohickies working in my car but it wasn't hard.
Sale Thread Feedback Thread
Kenunot is offline   Reply With Quote
Old 10-09-2017, 11:35 AM   #6
coalminer
Originally Posted by prometheus_aflame View Post
1990 245 NA.
I highly doubt that your headlight problem has anything to do with the dash light dimmer.
The problem with the headlights is most probably the headlight relay.
It's located on the left (driver's) fender rail under the hood, just back of the battery.
It's beside the 25A fuel injection fuse.
coalminer is offline   Reply With Quote
Old 10-09-2017, 01:28 PM   #7
Kenunot
they're separate circuits. the headlight relay that is more likely to cause problems is the one against the firewall in the passenger compartment on the driver's side under the rug. the hi-lo one rarely goes bad.
the contacts corrode which makes them hot when energized, which melts the plastic of the relay plug, which causes the contacts to make poor contact with the relay.
easy to fix though, I just bypassed the corroded plug with new spade connectors
Old 11-23-2017, 01:52 AM   #8
prometheus_aflame
I tested the illumination lights behind the center console and sure enough, they are all toast. Working on getting replacement bulbs for the cluster and the dash.
Old 11-23-2017, 03:48 PM   #9
Can play the blues
You can use 73 or 37 bulbs for these locations. I did not have a good experience when I tried leds so I went back to mostly all light bulbs for this kind of interior lighting.
1982 242 turbo. 339k miles. Stuff...old stuff....cool...old...stuff...rust...not...cool...
1993 245 Classic, 413k miles, enem V15. 5spd. IPD bars and chassis braces. New Simons sport exhaust from Scandix. chipped ezk. Been a good road warrior.
1981 242 turbo. 71k miles. Cool old stuff...
1969 145S more cool old stuff. A barn car.
1967 123GT yet more cool stuff in the barn.
