Old 10-09-2017, 03:13 AM   #1
Mr. V
Mr. V's Avatar
Default Sudden max revs: B21FT
I was driving tonight in my '82 244 Turbo with a B21FT when for no reason, while driving at a slow speed and gradually accelerating the motor immediately and unexpectedly raced to max rpm.
I shut it down, pulled over, started it up: same thing.
Waited a couple minutes, tried again: same.
The throttle cable seems fine, not kinked, in normal closed position with engine shut off.
WTF?
I suspect the throttle must be stuck wide open, but I wasn't on the throttle much at all when it happened.
Oh well, I'll try to sort it out tomorrow in the light of day.
A new one on me; any ideas as to what it might be?
Old 10-09-2017, 03:41 AM   #2
MasterBlaster
I vote for big vacuum leak.
Old 10-09-2017, 12:49 PM   #3
tryingbe
Boosting along.
tryingbe's Avatar
Check brake booster hose.
85 GLH 350whp
00 Insight 72 mpg
94 855 in hibernation
Old 10-09-2017, 12:58 PM   #4
propav8r
F*ck Edgar
propav8r's Avatar
Vote #3 for vac leak. That spring returns the throttle plate to closed. You'd have to have something wedged in there or some real black magic fvuckery to make that happen.
Brake booster hose or the brake booster check valve are my guesses.
turn the ignition timing up til it's faster than eamon's miata, then replace the shortblock #wootenthings
K-Jet to Megasquirt Article
The Departed: 1981 245, 1983 245 Turbo, 1983 244 Turbo, 1983 242 Turbo, 1984 244, 1985 245 Turbo,
1989 244, 1989 765, 1990 245 Turbo, 1991 244, 1992 245, 1997 855
Old 10-09-2017, 08:09 PM   #5
smeha
Tranny Whisperer
smeha's Avatar
Theoretically, would not he have problem stopping then?
Brake pedal soft?
My Feedback Thread
Old 10-09-2017, 08:53 PM   #6
PromiseRing
We don't even like Volvos
This happened to me one time. But on a 2.4 car that doesn't act quite the same as kjet.
My issue was one of those little clips on the intercooler couplers had come off and got lodged in the throttle plate. It eventually found its way holding cylinder 4 exhaust valve wide open..
Probably not your porblem, but it might be worth checking that nothing is stopping the throttle plate from fully closing.
Current
straight pipe
-93' 245 m47-iPd sways, B-cam
Past
-80' 242gt m46-
spill it MClovin and WTF happens to your glasses you piece of ****..
Feedback Thread
Old 10-09-2017, 09:06 PM   #7
kzoc
I've encountered this problem with 2 other 240T's... Both times the issue was the CIS (Constant Idle System) ecu gone bad.
It resulted in a very high idle (upwards of 2k), and the only way to bring it down was to pinch off the IAC air hose.
No real good way to test other than a known good "Leerllaufregler" That appears to be the name of the part/ecu that controls the IAC. It's the smaller of the 2 ecu's in the passenger footwell, and has 2 connectors.
HTH-
Volvo side: 84 242Ti
VAG side: 97 Jett TDI, 02 B5.5 Variant, 09 JSW TDI (Crushed!)
kzoc is offline   Reply With Quote
Old 10-09-2017, 09:26 PM   #8
Mr. V
Mr. V's Avatar
OK, problem discovered and solved.
The idle control switch on the throttle body had loosened a bit, such that its dangling little flat lever piece would sag too far.
This caused the outside cam (hooked to the throttle shaft) to bind to it when it rotated, preventing rpm's to go down.
Loosened and repositioned the switch, works fine now.
Old 10-09-2017, 09:50 PM   #9
Can play the blues
Good find. Always glad when it's an easy fix.
1982 242 turbo. 339k miles. Stuff...old stuff....cool...old...stuff...rust...not...cool...
1993 245 Classic, 413k miles, enem V15. 5spd. IPD bars and chassis braces. New Simons sport exhaust from Scandix. chipped ezk. Been a good road warrior.
1981 242 turbo. 71k miles. Cool old stuff...
1969 145S more cool old stuff. A barn car.
1967 123GT yet more cool stuff in the barn.
Old 10-10-2017, 03:07 AM   #10
John242Ti
manofewords
John242Ti's Avatar
That also would cause it to "idle" at 3200 rpm or so, even if it hadn't hung up on the throttle lever on the shaft. When the switch opens, the CIS motor is told to open up all the way. Dealt with this on my 245's old engine, when the throttle switch somehow had gone out of adjustment on the B21F intake manifold I'd installed.
-J
1982 242Ti - black, M46. 1985 245Ti - blue, M46. 1987 764Ti - beige, Aw71 (for sale). 1989 745Ti - red, Aw71. 1992 245 - white, Aw70 (for sale).
Formerly Blue245Ti, 245GT-Turbo, and, originally 242GT-Ti.
