Old 10-09-2017, 01:32 PM   #1
clintsnow
Default Heater Core replacement brands?
Hi all, I'm getting ready to replace the heater core in my '89 244 DL and I'm wondering if anyone has recommendations on which brand to purchase. I typically purchase everything from IPD, but when looking around I found this one: https://www.amazon.com/Spectra-Premi...44+heater+core which is only $39 compared to the one ipd sells for over $100. Not sure if the cheaper one is crappy and I'd have to redo the job, or if it is sufficient.
thoughts/suggestions?
thanks!
clintsnow is offline   Reply With Quote
Old 10-09-2017, 06:22 PM   #2
Can play the blues
Better to find a good used original heater core. The aftermarket ones have improper construction and don't cool the heater fan resistor properly. Get a used one and have it pressure tested if you aren't sure it is good. It is worth the effort to get the correct part in this instance. Put a listing in wanted section.
1982 242 turbo. 339k miles. Stuff...old stuff....cool...old...stuff...rust...not...cool...
1993 245 Classic, 413k miles, enem V15. 5spd. IPD bars and chassis braces. New Simons sport exhaust from Scandix. chipped ezk. Been a good road warrior.
1981 242 turbo. 71k miles. Cool old stuff...
1969 145S more cool old stuff. A barn car.
1967 123GT yet more cool stuff in the barn.
Old 10-09-2017, 06:27 PM   #3
Lando
Arthur Digby Sellers
Lando's Avatar
Alternatively, you could remove the old one, flush it out, solder the leak shut with silver solder, pressure test and reinstall. If you aren't that good with silver solder a radiator shop will do this for about $40.
Originally Posted by amerbritcan View Post
Lando you have an enticing midriff.
get on my lawn
Lando is online now   Reply With Quote
Old 10-09-2017, 06:28 PM   #4
Kjets On a Plane
Devoid of Luxury
Kjets On a Plane's Avatar
^Or just get a good used one and don't use acidic coolant or over pressurize it?
Usually it's not worth the time to solder up every tube when they pop.
How PSI a stock can support?
Old 10-09-2017, 06:30 PM   #5
Can play the blues
Yeah do the above if you can't find a good used original. Either way you want an original style part due to the way they designed the heater system.
Old 10-09-2017, 10:31 PM   #6
bobxyz
bobxyz's Avatar
How's your A/C? This might be your opportunity to swap to a '93 heater / r134 AC box instead of just replacing the heater core.
On my '85, the original heater core was replaced with an IPD core. What a hack job. I'm guessing that it was done by removing the dashboard and chopping an access hole instead of removing and splitting the box. The replacement core really didn't fit right - there were assorted wooden blocks, plumbers strapping tape and copious weatherstripping holding it in place. '85 is on left, '93 on right (click on img for full size)
See cleanflametrap.com for great dashboard and blower motor replacement instructions.
'85 245glt aw71 k-jet -> ms
Old 10-09-2017, 11:35 PM   #7
Kjets On a Plane
Devoid of Luxury
^To be fair, if all the vac doors work and it's the average POS 240, if you just death wheel the top of the heater box and remove the dash pad it does just pull right out the top without splitting the box and all that trouble.
Or cut it out the side if the fan works and you don't feel like taking the dash pad off, but the dash pad comes off easy with the cordless impact phillips and buzzing the steering wheel out of the way.
Hard to love half-disposable POS240 as a flat-rater
Old 10-09-2017, 11:58 PM   #8
One hundred gift baskets
Going in heater core replacement #3, mine have all been over pressurised. I cut the top of my box of as above, much easier than complete disassembly
1980 primer Franken-242DL, 1989 silver 780 bone stock.
Old 10-10-2017, 12:02 AM   #9
clintsnow
Great tips, thanks all. I think I’ve found someone selling a used core through turbo bricks so I’ll go that route.
Old 10-10-2017, 12:39 AM   #10
Can play the blues
Overpressure in the heater core can be helped with a restriction put in the heater hose. Stops the pressure surges. They have one stock in my F250.
