Old 10-09-2017, 07:15 PM   #1
oifish
my god it's full of stars
oifish's Avatar
Default New A/C compressor clutch won't engage
Car is my brother's 91 745 NA. His old R12 system had leaks and the compressor recently seized up so it was time for replacement.
We installed all new components (besides evaporator) including the proper amount of oil for the compressor. Pulled a solid vacuum that held overnight. But when trying to charge the system, the new clutch won't engage. I tried jumping the connection at the pressostat, but nothing.
His old a/c compressor was only a single wire with a weird little box that was mounted at one of the bolts to the compressor and then on to the red/green wire. The new one has a black wire from the clutch and a green wire the y's into the harness, then connects to the red/green wire.
We're stumped on why it won't engage. The idle's raise after about 10 seconds and we did double check the fuse.
1990 Volvo 744T M46 - Daily Driver - ( ͡° ͜ʖ ͡°)
__________________________________________
Buy/Sell Feedback
oifish is online now   Reply With Quote
Old 10-09-2017, 08:19 PM   #2
To old for this
Break out the test light. Did you forget the ground wire?
To old for this is offline   Reply With Quote
Old 10-09-2017, 10:14 PM   #3
DET17
Reformed SAABaholic
This. Check your ground from the compressor body directly to the battery post.... if not essentially zero ohms, run a ground wire to the frame rail, right behind the battery (existing tap points).
When I bought my 92, the JAPAN made control circuit board (attached to the back of the HV control knobs) had a failed circuit.... fairly common. Once you've confirmed ground, then see if that single wire has got 12V on it when the AC is engaged.
Old 10-09-2017, 10:40 PM   #4
oifish
oifish's Avatar
Derp, forgot the accessories are isolated. Grounded it and no problems
