Old 10-11-2017, 07:53 PM   #26
swedefiend
Originally Posted by LloydDobler View Post
Given how little is adjustable on the alignment of these cars, usually alignment is all you need to know if the car is square or not. If it aligns, it's very unlikely that the body is bent. If a setting is too far out to be corrected that's a red flag.
I mention this because my car was wrecked. It was pulled for $100 and took alignment directly afterwards.
Point is, it can be fixed. Going to alignment first is a crapshoot though. And as far as I know, they're not cheap these days either (and alignment, pull, alignment is more expensive than pull, alignment ).
Old 10-14-2017, 07:00 PM   #27
dmax99
Set the steering wheel straight,look to see if both front tires are pointing north & south.You can also sight down the inside of the tires to see if the line of sight is the same on the rear tires.Look at the tires for camber,are they both sitting near straight up and down(zero degrees).Next with the steering wheel straight measure the wheelbase of the car,should be the same.If these three things are good,than you'll be able to have it aligned.Like was said there's not much to adjust on these cars (mostly toe--in).
dmax99 is offline   Reply With Quote
Old 10-16-2017, 02:25 PM   #28
Ryan_R
Somewhere in 87, [I think late in the year] so many of them are good in fact I wouldn't write off any of the LH 2.2 cars since most have replacement harnesses by now anyway...
Edit:
Or even a nice B23 / LH 2.0 car.
LH 2.2 is awesome. My '87 with 340K miles has gotten zero love in the decade I've owned it. Touch the starter and it roars to life. Like new compression. Uncanny. 1987 was a so-so year for wiring. Mine's been OK, but the insulation isn't as long wearing as the later cars.
Originally Posted by John242Ti View Post
Also, don't limit yourself to 1990-93 240's. The 1989 models are mostly the same, but without the bomb in the steering wheel. I've actually downdated my family's '92 to an '89, since it had the 1st generation bomb installed.
-J
It's actually functional as an airbag. A friend just had his '93 get smashed head on up to the A-pillar and the airbag actually did some good. Of course, I was in a pretty good collision in an '85 245 20 years ago... so I'm not sold.
-Ryan
Athens, OH
1987 245
1989 245 GL
1989 745 GLE
1991 745 --Regina powered B234F!
1995 945T -- Mildly modded
https://people.ohio.edu/ridgely/e-code.htm/
Ryan_R is offline   Reply With Quote
Old 10-16-2017, 02:39 PM   #29
Can play the blues
I've had my 93 wagon for over ten years now and the wiring hasn't been a big upgrade over the 80s wiring. Mine has some type of teflon insulated engine wiring and that gets hard from heat and exposure which then cracks and spits open. Especially anywhere there is a bend. So wiring should be checked carefully on any 240 that you are considering for purchase these days.
1982 242 turbo. 339k miles. Stuff...old stuff....cool...old...stuff...rust...not...cool...
1993 245 Classic, 413k miles, enem V15. 5spd. IPD bars and chassis braces. New Simons sport exhaust from Scandix. chipped ezk. Been a good road warrior.
1981 242 turbo. 71k miles. Cool old stuff...
1969 145S more cool old stuff. A barn car.
1967 123GT yet more cool stuff in the barn.
Old 10-16-2017, 02:40 PM   #30
John242Ti
manofewords
John242Ti's Avatar
-Ryan
Functional, yes. As safe as a modern airbag, no. The old ones were meant to stop a 200 lb man, not wearing a seatbelt. The new ones are meant to be used with seatbelts, therefore, they're less likely to severely injure (unless Takata) a 5'2" tall 120 lb woman who happens to have the driver's seat all the way forward, like my mother. Her torso length is normal, but she has somewhat short legs so, in a 240, the seat cushion is touching the center dash console for her to reach the pedals comfortably.
-J
1982 242Ti - black, M46. 1985 245Ti - blue, M46. 1987 764Ti - beige, Aw71 (for sale). 1989 745Ti - red, Aw71. 1992 245 - white, Aw70 (for sale).
Formerly Blue245Ti, 245GT-Turbo, and, originally 242GT-Ti.
Old 10-16-2017, 05:49 PM   #31
dmax99
Yeah,I remember seeing bloody airbags,& head imprints in the windshields in cars where the driver wasn't belted.A real double whammy!
