Old 10-10-2017, 12:33 AM   #1
Motakitty
Default Power window fuse keeps blowing
I have a 91 240 wagon and the window fuse keeps blowing. The windows still work if I jump the fuse. I checked for shorts but the wiring still looks good and checked the switches which looked good and were working. Before this happened they would roll up and down kinda slow so I'm kinda thinking the windows need a good cleaning and regreasing the tracks might help.
Motakitty is offline   Reply With Quote
Old 10-10-2017, 03:41 AM   #2
nordmaschine
forced instruction
nordmaschine's Avatar
Is that a question?
Jetronic is romantic.
Whiteblocks
Old 10-10-2017, 03:47 AM   #3
Shifted
C&M '17 Survivor
Shifted's Avatar
Hit the tracks with a good dousing of some silicone spray and see if things improve.
Originally Posted by ME II View Post
Without mistakes there is no learning.
"Ego is the anesthesia that deadens the pain of stupidity" - Rick Rigsby
Shifted is offline   Reply With Quote
Old 10-10-2017, 11:26 AM   #4
coalminer
Wash your windows inside and out with glass cleaner and then apply "Rain X' both inside and outside.
This should lower the electrical current required to move the glass, and help your problem.
coalminer is offline   Reply With Quote
Old 10-10-2017, 01:51 PM   #5
nel621
Lube the tracks, rails , whatever is inside the door. All pivot points. If you are adventurous you can open the motor and clean out all of the old lube and renew.
Old 10-10-2017, 02:09 PM   #6
What works well to lube the tracks? Any how to keep it off the glass?
Old 10-10-2017, 02:14 PM   #7
swedefiend
We always used silicon spray. It is not easy to keep off the glass.
I was usually successful using the straw that comes with the can of silicon spray AND taking a piece of cardboard (cereal box type) and folding it over the window before spraying.
Glass cleaner with alcohol as its primary ingredient is best for removing any overspray.
Old 10-10-2017, 02:15 PM   #8
swedefiend
Was going to add this. Good suggestion.
Old 10-10-2017, 03:14 PM   #9
Can play the blues
Also make sure you are using the good brass and copper fuses. The white metal fuses corrode and won't last long. They can even look good while being old and compromised.
1982 242 turbo. 339k miles. Lots of good changes.
1993 245 Classic, 415k miles, enem V15. 5spd. IPD bars and chassis braces. Simons sport exhaust from Scandix. chipped ezk. Been a good road warrior.
Old 10-10-2017, 03:22 PM   #10
Shifted
C&M '17 Survivor
Shifted's Avatar
Put the window(s) down, this leaves a gap or channel between the guides and the glass, and keeps the window fairly clean. Use the 'straw' to aim down into the gap, and don't be stingy with the silicone. Raise and lower window a few times to distribute, lather/rinse/repeat as necessary until smooth and rapid operation is achieved.
Old 10-10-2017, 07:10 PM   #11
nel621
Just take the door panel off and get in there.
Old 10-13-2017, 03:45 PM   #12
Motakitty
Awesome thanks guys I will try lubing the tracks and everything in the door. If that doesn't work I'll open up the motors but I know that's more involved.
Old 10-27-2017, 01:45 AM   #13
Motakitty
I finally had time to lube up my windows and it seemed yo help. I also noticed that my rear driver window bolts that hold the window bracket (brain fart on the proper name) were loose so I tightened em up. I was able to roll each window up and down without the fuse blowing. They also went up and down much faster. I used to roll them up and down all at the same time which I'm sure added much more draw on the system so I'll do em one at a time now.
