Old 10-10-2017, 03:48 PM   #1
Cwazywazy
Cwazywazy's Avatar
Default No spark
Finished the second headgasket job on my 245 turbo, LH2.2 EZK. Last ran Friday. Didn't touch the ignition system other than moving the plug wires out of the way, now no spark. Both wires to the coil go to ground. Fuses are fine.
Old 10-10-2017, 04:06 PM   #2
Can play the blues
One wire on the coil should go to 12V swtiched power from the ignition key. The other wire on the coil in LH2.2 ezk goes to the power stage. Usual culprits in this ezk are the hall sensor failing or the wiring to it, and the power stage. Both wires going to ground seems like there is a fail like in the power stage. It should hold ground then open the circuit when switched to create a spark with the coil. The primary side
+ to - of the coil is low resistance so you would measure this short on both wires on the coil.
1982 242 turbo. 339k miles. Stuff...old stuff....cool...old...stuff...rust...not...cool...
1993 245 Classic, 413k miles, enem V15. 5spd. IPD bars and chassis braces. New Simons sport exhaust from Scandix. chipped ezk. Been a good road warrior.
1981 242 turbo. 71k miles. Cool old stuff...
1969 145S more cool old stuff. A barn car.
1967 123GT yet more cool stuff in the barn.
Old 10-10-2017, 04:09 PM   #3
Can play the blues
You can check the power stage by looking at the input wire from the ecu for a switching signal when cranking. Using a low power test light or meter and back probe the connection under cranking. If it switches and you have no spark the power stage is bad.
Old 10-10-2017, 04:33 PM   #4
Cwazywazy
Cwazywazy's Avatar
I checked each connector unplugged from the coil. Where do I find which wire that is, on the powerstage?
Old 10-10-2017, 04:52 PM   #5
Cwazywazy
Cwazywazy's Avatar
Nevermind, cleaned the powerstage and hall connectors. Sputtered into life.
Old 10-10-2017, 06:05 PM   #6
Can play the blues
Better than bad parts. Good fix.
