Old 10-10-2017, 05:13 PM   #1
Brick-hi
Brick-hi's Avatar
Question 92 Volvo 240 wagon
The neighbor came over to "try and help get my tail lights working". He must of been looking for wires because when I tried to use the washer in the back ............nothing!!! so I looked and sure enough the washer hose has been cut in half. I went to the parts store today and got a white tube that you push in both ends of the hose and nothing come's out, and yes you can blow through white fitting . (smiling). But now nothing comes out of the washer onto the rear window. It worked fine before he cut it. I can hear the washer motor working. Any thoughts or help would be greatly appreciated
Thanks in advance for any help.
Brick-hi is offline   Reply With Quote
Old 10-10-2017, 06:02 PM   #2
Can play the blues
There is supposed to be a right angle one way valve inside the rear fender. He may not have cut the hose but disconnected and lost the valve in the bottom of the rear fender. The valves fail and stick closed. Without it, it takes the washer pump more time to get the fluid to the rear window. The valve helps hold fluid near the window so it comes out sooner. The washer motor may run but that doesn't mean it works.
Since you can't buy the black replacement washer motor any more. You buy the one for the front of the car and color the top of it black with a permanent marker. Or put some type of marker on it so you know it is the rear washer system.
1982 242 turbo. 339k miles. Stuff...old stuff....cool...old...stuff...rust...not...cool...
1993 245 Classic, 413k miles, enem V15. 5spd. IPD bars and chassis braces. New Simons sport exhaust from Scandix. chipped ezk. Been a good road warrior.
1981 242 turbo. 71k miles. Cool old stuff...
1969 145S more cool old stuff. A barn car.
1967 123GT yet more cool stuff in the barn.
