Old 10-11-2017, 01:54 PM   #1
eyeroll63
Default Strut Spacer 1229423 is unavailable: Suggestions?
Hey all, new member here. I have a herd of three 240s at present, with my current project being a 1982 Turbo wagon. I've rebuilt the entire front suspension and am almost complete, but I've hit a snag. I'm replacing the old DeCarbon strut inserts with Bilsteins, but can't complete the job without strut spacers, Volvo part number 1229423. I can't seem to track them down anywhere, as they've been discontinued.
I'm at the point now where I need to either find the inserts or fabricate something that will work correctly so I can get my Turbo out of the garage and on the road again. Any suggestions from the turbobricks hive mind? Any info appreciated. Thanks!
eyeroll63 is offline   Reply With Quote
Old 10-11-2017, 05:42 PM   #2
283SD
Had some 25 years ago. They are a stepped collar. I don't know where to get them now. I put Koni adjustable shocks in my car with no problems. Had an issue with KYB shocks years ago. Sounds like some fab work , or different shocks maybe?
Old 10-11-2017, 05:47 PM   #3
sbabbs
sbabbs's Avatar
Cut slice out of old strut maybe make a spacer with that? Use blown strut so it don't explode on you or drill one first. Maybe cut top of spacer at angle of what the bottom of new strut is like so it sits on the spacer with more of the load even on the bottom of strut.
1990 745 B230FT Getrag JohnV flywheel 240mm clutch 13c A-cam 3.54 G80 544K MILES
Old 10-11-2017, 06:00 PM   #4
planetman
planetman's Avatar
If you need them I have 2 new ones for $10.00 each plus shipping.
Eric
Torrance, CA 90502
Old 10-11-2017, 08:46 PM   #5
eyeroll63
Thank you Eric at Hi Performance Auto Service for setting me up with two spacers! Most excellent. I really appreciate your help!
