Old 10-11-2017, 02:49 PM   #1
Sweep
Default What to do with this hose?
Can someone remind me what this hose used to go to? It comes from the breather box on the block, is it the one that went to the original turbo inlet elbow?
If so, what can I do with it? I'm running a Holset and obviously non standard inlet hose.
Ben.
Old 10-11-2017, 02:55 PM   #2
Ursan
الله الفول السوداني شطائر
Ursan's Avatar
Get a catch can.
how psi a stock can support?
I think this might be my chariot if I can jew the price down.
Old 10-11-2017, 02:57 PM   #3
Sweep
Get a catch can.
Marvellous, so it's just a breather hose?
Old 10-11-2017, 03:24 PM   #4
sbabbs
sbabbs's Avatar
That goes before turbo on the air intake it sucks air so the breather setup works properly or doesn't if not hooked up. Oil blows everywhere otherwise.
Old 10-11-2017, 03:41 PM   #5
Ursan
Ursan's Avatar
Yup. As Simon said, it normally goes just before the turbo's intake as there's a tiny amount of vacuum there.
But you can run that hose to a catch can and then from the catch can to prior to the turbo's intake.
These work really well.
Old 10-11-2017, 04:24 PM   #6
Sexual healer
Old 10-12-2017, 02:08 AM   #7
Sweep
That's annoying, what do people do that aren't using a stock turbo inlet hose? I have no way to take a hose from mine to the breather box.
Old 10-12-2017, 04:24 AM   #8
K9 240
K9 240's Avatar
Hi Sweep
You can use an alloy induction pipe with a 1" T-piece & integrate it into your induction system.
I think the original pipe from the breather box fits into a 1" tube (secured with a jubilee clip) which would then fit on the T-piece. Or if you use a catch can, the 1" pipe can come straight from it.
Tim
K9 240 is offline   Reply With Quote
Old 10-12-2017, 12:14 PM   #9
Sweep
Originally Posted by K9 240 View Post
Hi Sweep
Tim
Hi Tim, thanks for the idea! I'm a bit limited on space but hopefully I can make that work.
By the way, is this likely to bring any oil vapour into the inlet? I'm wondering whether to put the hose before or after the AMM and obviously don't want it getting oily.
Ben.
Old 10-12-2017, 12:21 PM   #10
Stiggy Pop
Stiggy Pop's Avatar
I haven't gotten bothered to work out a catch can setup, so I've been running a new OE breather box with a hose vented to atmosphere for like 2 years now. No issues at all, built motor with an HX35 at ~25psi.
'79 242
943 pickup
