starsandbars
- Nov 4, 2012
- Poulsbo, Washington
I have an 83 242 glt with a m46 transmission with 160k miles. When you shift to 5th gear there is a noticeable rumble feeling above 50mph / 2400 rpm when you are getting on the throttle. When you back off fully on the throttle there is a loud moaning sound. Initially I thought that it was exhaust sound but then you push the clutch in the noise goes away. Is this is that the sound of a bad transmission?
