Construction Volvo 740 wagon (from Russia with love)
Definitely interested in what you plan on doing for the caliper brackets. Looks like a great start.
I order and machined center of the brake disk and put these here
I bought
D2racing 330/32
Looks like the start of something fun.
Maybe consider moving the thread to the "Projects and Restorations" section, since you're not asking performance questions (yet).
I want to put the cooler on the Nissan GTR level2 and want to know whether I have enough of it !? and it will be necessary to set forth the water jets for better cooling? Cooler 100 * 600 * 300
To be honest, I have not found through Google translator for large projects section))) if it is not a problem, then please move my topic😊
Tavarich 1 "We have best system in world. Far better than system in West."
Tavarich 2 "How can you say that, Tavarich? What truth are you thinking?"
Tavarich 1 "is easy, We solve problems that they don't even have in the West!"
See? Easy--coming from man with daughter named Natsha-- and we just learned together on the piano По́люшко-по́ле
<iframe width="560" height="315" src="https://www.youtube.com/embed/tD_Y9iVq3kY" frameborder="0" allowfullscreen></iframe>
Slava russia!
We already do not sing))) is the remnant of the Soviet Union)) is now singing like this
http://youtu.be/0TQPPGl-W8c 😂👯🙈
Tell me !!)) which gearbox is better to put?
I was advised to garaget.ogg here this
http://bakaxel.se/vaxellador/530-6-vxl-volvo-rod.html
but I have a problem in the delivery and the price too high!
I wrote a letter to the store and told me that it's a box of BMW
http://www.realoem.com/bmw/enUS/showparts?id=VU91-EUR-01-2005-E91-BMW-330d&diagId=23_0926
we have such a box (second-hand) costs $ 300
I want to remake itself (stomach dome) and save $ 900
good this transmission?
or better than the other?
Terrific build.
If 5spd is ok, then go for E39 diesel trans, they are cheap and sturdy, just have to machine the bellhousing like they did with the link.
Keep us updated!
Think a standard Getrag 260 won't hold the power?
They're sturdy, you know.
And a dime a dozen... (cheap)
Getrag 260 family follows same rules that govern all conventional gearboxes in terms of what makes it strong..
Yes Volvo, and Ford in their Turbo Group a touring cars used the 265 and their engines made mountains of torque compared to the limp weenie little BMW and Rover touring cars which dod not make much torque at all..
But that box they used was same CASE -housing- gehause and completely different gear ratios.
Just like you will see on the T5 ID charts that show max torque, the taller the 1st gear ratio the higher the torque capacity of the box.. thus the 4.08 first T5s have the lowest max torque, and the 2,95 first gear boxes have the highest torque capacity...It is largely a function--in a given box--of the gear reduction from clutch input shaft down the bottom/cluster gear..
Also! The 4.2 or whatever horrible 1st gear 265 is, aside from the utterly useless 1gang ratio, nowhere near as strong as those old GpA boxes with 2,37 for 1 gang..
Hi))
Bought at dump trucks Getrag 260/6 of the BMW 734 (he is stronger than 260/5)
It cost me $ 80 $
I gave to the plant to alter the gearbox housing!
all cook evenly and exactly what they needed in the engine block B230
(Also bought at the dump old cars for $ 20)
* They said that next week will begin to remodel!))
Approx 9000 engine rpm
GETRAG 260
1st gear 87.96 km / h
2nd gear 153.13 km / h
3rd gear 240.64 km / h
Fourth gear 336.89 km / h
5th Gear 415.92 km / h
and the figures at 4500 rpm (where the turbine has already started to blow air)
The first transmission of 45.82 km / h
Second gear 75,6 km / h
Third gear 118.81 km / h
Fourth gear 166.33 km / h
5th Gear 205.34 km / h
These figures are calculated on the condition that the rear gear number 3.2
Hello!
my news)
gearbox made me))
welding seam was not very beautiful, but durable)
In connection with the crisis of the project did not Drag a street car)) Holset 52pro was sold and bought Holset 40 super))), but calculations showed that AR very high (1.2)
In the end, he spat and ordered presisen 6466 �� 600-900 price tag sil�� Hells 2200 ye
I had to donate money for painting
Holset 40 sold by 5 to less than taking)
But this is one of the top Turbo
Cap for $ 20 was a gift
Help me choose a clutch kit !! ??
splines on the gearbox 10 pieces
that need to be held it in 1000 and the moment of 700-800 horsepower
and I also need the flywheel
Please help with the choice
It's so funny that the guy at the start says "so we hit crysis and I decided to build a street car" and then orders all of these expensive parts :)
That's cool man, following this. Going to be very powerful!
By the way, so you don't have to weld the bell, we (abc-clutch) offer adapter kits to bolt on BMW boxes on Volvo engines. Next time hit me up :-)
P.S. - privet iz Latviji, udachi!
