Old 06-21-2018, 05:14 AM   #1
bullet5150
Default LH2.4 940 wiring harness
Hello guys..
To remove the ecu harnesses do i have to take out the whole dashboard..? I know all 940 is 2 piece wiring harness.. one for the engine bay.. and one in the cabin..
bullet5150 is offline   Reply With Quote
Old 06-21-2018, 11:48 AM   #2
EivlEvo
I don't believe so, but am not an expert on 9 series.
Old 06-21-2018, 12:04 PM   #3
esmth
dirty swede
esmth's Avatar
Originally Posted by bullet5150 View Post
Hello guys..
The 240 has the two piece harness. the 940 engine harness is integrated with the chassis harness
esmth is online now   Reply With Quote
Old 06-21-2018, 03:17 PM   #4
EivlEvo
Devastating.
Old 06-22-2018, 05:23 PM   #5
bullet5150
Lol.. just to get myself squeeze under the steering column is already pain in the arse..
Old 06-22-2018, 05:41 PM   #6
This is a yes and no type of question. You can remove the ECU section and the EZK section of the harnesses without removing the dash. That said, the dash harness is what allows those to sections to communicate.
Old 06-24-2018, 10:20 AM   #7
bullet5150
I think its wired this way.. sure a lot of wires to be removed..
Old 06-24-2018, 12:59 PM   #8
Yes. What is missing there are the power sources to the various components which come from the dash section of the harness. Also, the speed signal that the ECU needs in order to operate properly and the fuel pump circuit, which the ECU controls. There isn't much in the dash harness that is needed to make the system work. Sorting out what is needed from that section is going to be time consuming.
