Which pressure plate
Los_215
I have a lh 2.4 flat flywheel but don't know which pressure plate to use allthe ones i find are forthe bowl dish, help and thank you.
240 clutch kit (new) 150 shipped
If your flywheel is stock flat, and not drilled for 228mm then you need a 215 flat fw PP and disc.
If you want to have it drilled to go to the 228mm PP so it can hold more power... now is the time to do that and grab some Saab plates.
