maxitoman007
- Feb 15, 2017
- Calgary, Alberta, Canada
Will this heater control valve work in my 87 740? Pulled it from a Ford Expedition
https://m.autozone.com/cooling-heating-and-climate-control/heater-control-valve/4seasons-everco-heater-control-valve/ford/expedition/933612_0_0?aqs=
Works the same way, IE closes with vacuum applied. Only difference I can see is that my old valve had holes in the diaphragm to allow some coolant through even when the valve was closed where as it looks like this one just seals it right off. Would that be an issue?
