I've looked at these, and communicated with somebody there named Peter (go figure, haha). They look nice to me. There's also somebody on here that was making camber plates too, I can't find the thread though. The only thing that bothers me about Bens camber plates is all the slotted holes, what are the chances of one of the bolts coming loose, let alone being able to center them perfectly. I get the idea of being able to rotate and kind of aid your camber/caster curve, but....
http://www.retroturbo.com/?product=vrs-7900-series-performance-camber-plates#!prettyPhoto
a proper alignment takes a little time to do properly, especially if you aren't using fancy laser alignment scales and angle finders. You can do a good enough alignment with some strings, an angle finder, a few taper measures, and some aluminum sheet. It's really not rocket science.
Any alignment related device should be installed and then aligned, it can be on a rack or at the track with strings.
those bolts don't loosen up, the form of the plate perfectly matches the form of the factory sheet metal, so there is a very high surface area of contact which means its not going to slip. Do you find you have bolts falling off your cars? A properly designed bolted joint will never come undone from normal use.
Do you under stand the basics of aligning a strut car? You move the strut in if you want negative camber and back if you want positive caster. So you bolt them up and eyeball it to what you think you might want. Check with measurements and adjust the plates to make your measurements match your targets.
I have some of the old ones left on the shelf too, like ones that retro turbo copied, if your interested shoot me a pm.
What's "normal" use? I have to double bolt because under "normal" use things come undone. You are missing something here.... Know what it is?
Cut the attitude, ok? Those camber plates of yours can be installed in any rotation of 360*. If I installed them in a car, went and moved the strut in for a camber change on one side, then did the other side - if those camber plates aren't perfecly oriented at the exact same angle, the caster is going to end up being different on both sides. Most camber plates, the plate itself is adhered to the car, and you can move the bearing part to wherever you need it to match your camber & caster needs (first pic below). Your camber plates, (2nd pic below) have a camber slider, and the only method of caster adjustment is by loosening & rotating the entire camber plate, thereby probably needing to re-set your camber. So, not much caster adjustment then?
Ben, why are you making a habit of trolling and baiting in any suspension thread I post?
At the end of the day you know you let me down, you know you lied to me and blamed me for your failings. You know you actively ignored a customer but had time to post on here.
Your excuse was I wanted a "custom" part but you did not communicate the fact you were having issues making a threaded spacer. Something I make with basic hand tools yet you couldn't do in weeks. I had to push a refund through Google before you replied to me.
No trust = no money from me. So why are you here?
The thing with copying part, YOU have done it. Why was that ok but it's not ok for people to do it to you?
Mods, my apologizes for you having to clean up again.
Trying to get in contact with me at 3 AM local time is a good way to have your attempts at communication "ignored" You do realize we are in different continents. Right?
Did you forget this was AFTER multiple emails over weeks which were ignored? This was a last ditch effort before a refund. Again, since you were ignoring email what choice did I have? You had other contact asking you to respond to me and ignore that too didn't you?
First of all, I never copied the noltec design. I heavily improved on the concept dimensions and tolerances so they would acutally work in a 240 without having to get your grinder our or add a **** load of ride height.
I have the original PM's Ben. You need to be accurate. If you have forgotten what really happened then don't contradict someone who KNOWS.
At that time I was young student and it was just a hobby, did the parts have similar design features to the noltec? It had couple.
Copied. Copied.
Although it was a good exercise to help point out what design failing those plates had. Would I do something like that as a business today? Absolutely not.
You were selling them
A couple observations:
If you're worried about the slots on my parts coming loose, you can say the same for the vorshlag plates, it has a slot too.
Good point. I've just never seen a design like yours, in the Vorshlag plates (and most of the rest of them) the bolts are still attached to the plate.
What if you want some caster angle in between what the large bolt hole adjustment has? You're SOL. Now how will you align it?
I'm not sure what you mean here. What large bolt hole adjustment? Which plates are you referring to?
Now a tip,
If you're really paranoid about having it "centered" left to right, just max out the adjustment at the edge of one of the slots, that way it's symmetrical.
I guess that makes sense too.
Even though having it the same left to right most likely won't give you the alignment that you really need.
