- Sep 18, 2002
So i bought a boost cntroller
yesterday, (I got bored of 6psi rather quickly.. i know... no self control...)and anyways, ever wonder how long a
180k mile, NA M46 would last behind 18psi of heavily intercooled boost into a modified B23ft?
The answer
is about 10 minutes. Put it to the floor at around 4000rpm's in 4th gear, headed up a slight grade. Rocks in a
blender. Followed by some sort of weird over-rev, cyclic shock on the engine, engine also make bad noises.
So ya the f'er is toast man. It was the most glorious implement of thrust ever for those 10 minutes
though.
Worth every fucking cent.
The plan is to swap the engine/trans from my 242 in (with
turbo reinstated). I will have to use some restraint and drive with a stockish engine for a month or 2 until I
rig up something a little more fun.
I have been kicking myself after some of the more recent threads, I
was kinda unhappy with a few aspects of the motor anyways.
So, I plan to:
Build with a tighter squish:
0.030-0.35 :?:
Open the chambers up some more, and do big valves.
bronze guides
uprated
valvesprings
Some things up in the air are what the actual dimensions will be (the cosworth pistons are
still a thought) and what actual components to use.
I'm thinking I might just stay with a standard sized
motor- hardened M rods and forged mahle flat tops. Depending on how mutilated the B23 in there is- i may have it
sleeved to 96mm.
If I got with a B23 bore size, it will definitely be a sleeved b23 block. i think that is
the answer.
Does anyone have anything they want to buy from Unitek?
Despite their recent slaggings,
their pistons are simply dirt cheap.
Am I dissappointed? Sure. That was a lot of work. And the stock
B21ft will be much less fun. Am I excited about being able to have a decent car to drive, and shop space at work
so i can build something exactly how I want to? Absolutely. And am I wiser for the experience? Absolutely.
So it's all good- ya gotta pay ta play sometimes.
The answer
though.
So, I plan to:
0.030-0.35 :?:
bronze guides
uprated
valvesprings
sleeved to 96mm.
the answer.
