photoman327
- Apr 15, 2009
- North Alabama
Thanks. had a line on a VX cam at a good price. I'm just don't know Volvo Cams yet.
Any Volvo stock cam would be better than T, If you like revving a bit K- is the preferable it performs best at midrange an high end you loose a bit below 1800 rpm, A or VX performs better in very low end and is "almost" comparable in midrange to K.So, were I to use a T-cam in my non-turbo 940 automatic, would that be best in your opinion, guys? It seems as if the low down torque it would provide would be a good match to it were I to work a few intake tricks and the new exhaust is on the way: freer flowing muffler, no resonator and a fresh cat. I'm sort of a newbie to this and am just a bit unsure of how the install would work with the current engine's timing.
I see the cam list here https://turbobricks.com/resources.php?content=camspec says that the KG-Trimning KG004 cam is a substitute for a Volvo K cam.
I emailed KG Trimning and asked them which cam for my automatic naturally aspirated 245 would provide a considerable increase in power down low. They recommended their KG004 cam. Their website http://www.kgtrimning.org/tuning-special/b23b230b234/camshafts/kg004.html says that the cam provides high torque from low revs.
The KG man also told me that their KG004 is very similar to a Volvo K cam. That sounds like what I am looking for (big power down low) but a few K cam descriptions in this thread make it seem like the K cam is slightly worse than a stock cam (M?) down low.
Does anyone have any thoughts about this?
Thanks very much.
welcome in a car enthusiast hell, dear fellow!
u prolly never will find out.. unless you try it out?!
For use in an automatic equipped B230, the K cam would benefit from being set up with valve clearances on the looser side of spec(0.018", or even 0.020" if you don't mind some more valvetrain noise), and being advanced 2, 4 or 6? from straight up. The more advanced it is(up until a point where it's just horrible up top), the more torque you'll have at low rpm at the expense of the torque curve falling off at an earlier rpm. I will try to get some dyno charts loaded up when I have a chance later showing this as my previous posts about it don't have working pictures anymore.I see the cam list here https://turbobricks.com/resources.php?content=camspec says that the KG-Trimning KG004 cam is a substitute for a Volvo K cam.
Thanks very much.
Here's another thread talking about camshaft timing on the dyno. His results didn't show much change in lower rpm torque with the D cam except it's worse when retarding it, which doesn't coincide with what I've experienced with the A cam, B cam, T cam, K cam, H cam and K13 cam where advancing it noticeably helps down low(and reduces power up top).
http://forums.turbobricks.com/showthread.php?t=209648
I need to re-host and post up my images showing the changes it made for me.
A cam came in penta redblock boat motors in USA. Usually a few on Ebay or in for sale section here. Came in the boat AQ125A or B motors.
http://www.ebay.com/itm/Volvo-Penta...ash=item2a79bd5d9f:g:x1oAAOSwMN9XQ0nB&vxp=mtr
You are most welcome! I am all about making these cars faster. When you say have the valves worked over, are you hoping to have larger valves installed or just doing a valve grind to make sure they're seating properly with fresh angles?
If you're just shooting for a fun daily driver with more power than stock at low rpm but also a lot more higher up, then having a little taken off the cylinder head with the K cam and a fresh valve grind should wake the car up nicely.
Do you mind using premium fuel all the time?
An '87 does have LH2.2 from the factory and you can adjust the base ignition timing by rotating the distributor. The distributor itself controls the curve of the ignition advance, of which you can't do anything about(easily, or at all? Not 100% certain if they can be modified). At least you have the option of quickly and easily rotating the distributor in case you're experiencing any detonation. Idle speed is easily adjusted on LH2.2 as well with the screw.
