Old 05-03-2016, 10:22 AM   #51
toms_elleck
toms_elleck's Avatar
That green car is awesome.
Originally Posted by Finnish240 View Post
I painted my '90 4 door rocker panel white, then black and now it's white again white makes it look lower IMO
From your thread:
I think I'll give the white a try. If I don't like it, then just like you I can paint over it with trim black, or undercoat it to prevent chipping.
-Thomas
toms_elleck is offline   Reply With Quote
Old 05-03-2016, 11:09 AM   #52
Tuff240
240 Ninja
Tuff240's Avatar
Painted only looks good if the rocker trim is gone like an earlier car. Then the body seam always looks like crap.
And +1 to the tree sap/bird poop. Toxic stuff if just left there for years.
-Patrick
Old 05-04-2016, 04:46 AM   #53
Finnish240
Finnish240's Avatar
Mine is on/off daily driver, so I can't do big things right now. Later I 'm going to remove all trimming, weld all holes and do a good rust preventation for it. I've got side skirts from Bross body kit, maybe I paint it white and put it on car, maybe not.
Looking good keep it up that way!
Volvo 240 GL - not so low, but yes.... it is slow
Finnish240 is offline   Reply With Quote
Old 05-06-2016, 01:13 PM   #54
toms_elleck
A few small updates. Replaced both front wheel bearings last night, and MAN, the car is so much quieter above 25mph. Less road noise and buzzing in the steering wheel too. It's almost as if I put $200 worth of dynamat up under the dash.
I also installed an IPD skid plate, that came off a parts car I destroyed. That might have helped with a little of the road noise too. Check out those sweet old school IPD 25/25 sways!!
Also got a 12" sub wired up in the trunk, adjusted the camber a touch more positive because the spring perches were rubbing on the inside of the strut tower and dislodging the springs, discovered a bad inner tie rod end on the ZF rack, moved the deck to the upper dash position because I hate reaching behind the shifter to adjust the radio, and lubed the door and hood hinges. I will need to replace that tie rod end and have this pig aligned by a person with a better tape measure.
Big rush to get little crap fixed and ready, for a 3 hour road trip with my wife and 6 y/o daughter this weekend. My wife's car has an unexpected corded tire, presumably due to a jacked up alignment, so the 242 is pulling family car duty this weekend while I save up for a pair of 245/40/19s. She's been driving the 242 to work all this week, and she actually loves it. But I reeeally don't want this weekend's road trip to be an unpleasant experience! I might even buy some air fresheners, and stop at Starbucks for a $75 breakfast on the way out of town. Any other suggestions, aside from renting a real car?
Old 05-06-2016, 02:23 PM   #55
Jack
junkman
Jack's Avatar
Tell her to leave your ass behind, Im sure it crossed her mind after you not fixing her car sooner
Old 05-06-2016, 02:59 PM   #56
propav8r
F*ck Edgar
propav8r's Avatar
I love that side trim. Might have to do that on my car.
K-Jet to Megasquirt Article
The Departed: 1981 245, 1983 245 Turbo, 1983 244 Turbo, 1983 242 Turbo, 1984 244, 1985 245 Turbo, 1989 244, 1989 765, 1990 245 Turbo, 1991 244, 1992 245, 1997 855
Old 05-06-2016, 04:12 PM   #57
toms_elleck
That's unkind.
I can't wait to finish getting the glue off, brushing the rest of it, and then painting the caps. I'm finding that a little bit of brake cleaner on a red scotch brite pad melts the glue pretty quickly, and then a second pass with a wet red pad gives a good brushed finish.
Old 05-06-2016, 05:36 PM   #58
Got only a tiny bit done this weekend, chipping away at it little by little.
The side trim was in OK condition, but it had a few blemishes. One of the worst blemishes was on the black part of the rear quarter trim, and that stick is somewhat hard to find since it's 242 only. So in an effort to make the best of it, I pulled the black rubber off the trim, and gave the remaining stainless trim a nice subtle brushed finish. I prefer the early stainless-only trim, and had no idea that all I had to do was remove the rubber to get a very similar look! Also trimmed down the plastic caps on the ends, to match the new profile of the trim.
I love the clean look of it against the white paint. I'll tweek out on the trim's end caps at a later date, maybe with a bit of satin nickel paint to better match the stainless.
I don't get it, that rub rail is the best part of the Dl trim, now it's as vulnerable as 140 trim to denting, and still doesn't look as good.
Personally I would have just sourced another 1/4 stick.
Old 05-06-2016, 05:43 PM   #59
toms_elleck
I just think it looks a lot better, but I am sure it's not for everyone.
BTW it will be easier to source a 1/4 panel trim with torched rubber to match this one if I get too many dings, than it would be to find a clean 1/4 trim. Especially if you are the type of person who can't bring yourself to spend over $100 for a piece of trim!
Old 05-06-2016, 06:11 PM   #60
So typical TB form over function?
Or tweak for tweek's sake?
I have a good one here for a lot less than that.
Old 05-06-2016, 06:42 PM   #61
toms_elleck
Yes, the stripped trim is purely form over function.
Frankly, I wasn't planning on getting a whole lot of usage out of the rubber door strips. I'm not all that worried about a hypothetical ding that may or may not happen someday in a parking lot now that I removed the tiny additional rubber bumpers from my trim. I certainly won't lose sleep over my side trim being marginally less functional than it used to be.
Bottom line is just that I think it looks better. On a white car, the pure stainless trim doesn't stand out as much as the black rubber, and doesn't create such a brutal visual division at the body line. This trim is more subtle, and I dig that. It was a very pleasant surprise when I peeled back the rubber from the one section that was the worst damaged, and realized it didn't slide into a slot or something. That being said, I don't know if it would look better or worse on a dark colored car. But it looks great on white!
I winced a bit at butchering some usable 242-only trim pieces, but every one of the pieces had some sort of damage on it. So it's not like I ran through an automotive museum destroying priceless car parts.
In case you hadn't noticed, this car has flathood/singleround/cut springs/subwoofer/BBS/etc. Yes, Ken, this is a typical textbook ruined turbobricks car. I'm enjoying the piss out of it, and this is exactly what I bought it to do.
Old 05-06-2016, 06:43 PM   #62
Tuff240
240 Ninja
Tuff240's Avatar
It's stainless steel. Pop it off, knock out the dent and refinish it.
83's are my favorite so I really like the original unmodified trim. That being said, the modified ones don't look at all bad.
Old 05-06-2016, 07:13 PM   #63
It's your car, and your prerogative, I'm just stating my opinions on the trim.
Looking good, onward...
Old 05-06-2016, 07:15 PM   #64
toms_elleck
Old 05-09-2016, 03:22 PM   #65
toms_elleck
Road trip was a huge success. A++ Will Volvo road trip again.
I got the back seat all set up so my daughter could comfortably nap the whole time, giving my wife and I the opportunity to listen to music with bad words in it, and talk about whatever we wanted. LOL
Love how water beads up on freshly waxed OG Volvo paint.
And a couple of standard operating procedure gas station shots.
The only things I got done this weekend was the installation of a driver's side mudflap, topping off the oil, and installing a fog light switch in anticipation of the fog lights that I'm hoping to pick up soon. I want to put some cheap H3 HID kits into some original style fog lights. That way I won't be obnoxiously running cheapass HID lights every time my headlights are on, but I will be able to light up these incredibly dark forest roads at night as needed.
Problem is, I don't really want to mount them super low where they'll get broken easily, but I think GT grills are way too ugly. I'll figure something else out.
Old 05-09-2016, 03:36 PM   #66
Jack
junkman
Jack's Avatar
god damn it ThOmas I have like 3-4 different styles of old school fogs...
ummm - I hate to be the bad news bearer but thats Olaf and not a person,.....
are you even married ?
Old 05-09-2016, 03:52 PM   #67
toms_elleck
Why do you keep holding out on me? You should have guessed that I wanted fog lights. BTW, you should sell me that $20 Recaro so that I can reupholster it in diagonal Volvo tan cloth. I'll offer $15 for it.
And WTF man? Olaf? There's no need to insult my chilrens like that.
Old 05-09-2016, 04:01 PM   #68
Jack
junkman
Jack's Avatar
I'll upholster it in that fabric and use it as my chair before I sell you that seat... I have and obligation to keep these parts away from Disney characters
Old 05-11-2016, 01:47 PM   #69
toms_elleck
Yesterday evening I had a rare opportunity to follow my own car home. And it also gave me the chance to get photographic evidence that my wife likes driving it!
Unfortunately, it also got me wanting to buy some 20mm rear spacers and further abuse the rear wheel wells.
Old 05-11-2016, 02:13 PM   #70
LC4CARL
Aero challenged
LC4CARL's Avatar
Nice!
#carlfeague on IG.
Old 05-11-2016, 03:05 PM   #71
Coupid
Coupid's Avatar
That looks great going down the road. No need for spacers in my opinion.
1972 142S Project Thread: http://www.turbobricks.com/forums/sh...d.php?t=311926
1991 780 Sold
1979 244DL Sold
1986 740+T Sold
1983 242T Sold
Coupid is offline   Reply With Quote
Old 05-11-2016, 03:40 PM   #72
MoCounselor
MoCounselor's Avatar
DO IT!!!
MoCounselor is offline   Reply With Quote
Old 05-11-2016, 04:27 PM   #73
Pro Sneaker Peddler
Check out how that worked out for me.
I release my dibs btw.
Old 05-11-2016, 05:07 PM   #74
Jack
junkman
Jack's Avatar
Thumbs up
**** the spacers, it looks good that way and handles better with a narrower rear than front
Edit: how much did you pay those actors to pretend they are your family?
Old 05-11-2016, 05:37 PM   #75
toms_elleck
Skimmed through your thread.. are you implying that it worked well? Or did you run into some issues?
I'm on the fence about the spacers only because I think it'd look great to force a 255 tire on the back wheels.
Your Bimmer wheels look great! Good job. Glad you're not sitting around waiting for these, because they're not going anywhere anytime soon. LOL
Narrow handles better? You mean by helping induce oversteer? This pig will never get to that point, and in fact, I'd prefer to generate understeer if anything. Turbo 911s had wider rear tracks to try and keep the damn things from spinning backwards and killing people. That's what I want, for my daily commute over the mountain. Slow, steady, and predictable. That and a $15 Recaro seat.
Oh, and you got me. Here's the original, untouched image:
