#26 |
All the gauges
![]() your right, i didnt read all that far
Kyle and the "Projects" -- '84 242 TI -- '66 220 S -- '89 Supra Turbo -- '84 Rabbit GTI ![]() |
#27 |
holstrich 2.0
![]() great work kyle, glad to see it moving along
Isaac ![]() 1995 940 Turbo: 531 head, Holset HE351 @ 20 psi, Emusa External Wastegate w/screamer, Mild Steel Header, 4" Downpipe, Ostrich Emulator, IPD Turbo Cam, TTR Cam Gear, Big Piping and Intercooler, 3" Exhaust, V8 T5 soon, Synapse Synchronic BOV, AEM Wideband, 18" Pegasus, B&G Springs, Billy HD's, Chassis Bracing, Sumimoto HTR ZIII 225/40/18 |
#28 |
Jazzhands, not jizzhands
![]() yeah dude, euro corners are teh hawtness. and cut springzzz. you know lol
#29 |
All the gauges
![]() Going to the pull-a-part tomorrow and hope to leave with a b230 of some flavor
New and improved list of things to do on the 242: All the brakes, ex. the master cylinder, rubber lines, 4 calipers, pads and rotors Driveshaft bushing and torque rod bushings 2 outer tie rod ends LF wheel bearing Front strut mounts heater blower motor 2 taillights and a headlight, and a turn signal lense fix floor B230, megasquirt, descided on msns for a while, may go with the k-jet ignition temporarily for simplicity to get it rolling, eventually going with wasted spark clutch needs 4 tires as well, but ive got them, just waiting to do that last cut the springs and ive got 1 VERY bent virgo, i have a spare, but unknown if its actually straight or not But aside from all that everything else looks good ![]() ![]() ![]() ![]() Last edited by stick70; 02-20-2010 at 08:42 PM.. |
#30 |
The son of Chico Dusty
![]() Kyle, I have a line on two 240s outside of Siler City that are being parted for free I believe. One is a 79 an the other is an 80s model, the older one is a straight drive. I should be checking them out within the next few weeks. I dont know if you are interested in anything off em. Apparently they would be running with a little work but the owner, one of my coworkers fathers, wants them gone as NC is reclaiming their property in one of those deals.
#31 | |
All the gauges
![]() Quote:
#32 |
All the gauges
![]() Found a clean B230 last month in the pull a part, 130k, no leaks. Got the B21 out yesterday and got all of the lights working outside. Mounted some free 195/60/15s I had tonight, they look alot better than the 205/65/15s that were on it. The car definately needs a windsheild, theres a new one in it, but whoever put it in glued a 84 windsheild in instead of getting new rubber for it. So it leaks. And it still has no brakes. Well, the LF caliper works...but thats it. Going to pressure wash the engine bay tomorrow and prep for the engine swap that should happen monday pending parts, clutch mainly. Pics of aformentioned shens tomorrow.
#33 |
All the gauges
![]() w00t! pictures!
![]() ![]() old engine out ![]() ![]() M46 cleaned up ![]() B230 waiting to go in ![]() ![]() and its clean inside as well ![]() Hardwired the taillights, yay they work! Still need 2 new ones though ![]() A view of the disaster area that is my shop ![]() ![]() Hopefully ill have my clutch tomorrow and I can start to drop the engine in tomorrow night. |
#34 |
holstrich 2.0
![]() Awesome work! I like how high it sits in the front now without the engine. Are you not going to pretty the B230 up before dropping it in?
#35 |
Mahalos
![]() no turbo?
#36 | |
All the gauges
![]() Quote:
![]() just clean it, nothing special plan to, the engine is a n/a engine though, its whatever. When I go for power it will all be ripped apart and built anyways. EDIT: No clutch tomorrow, ive got a whoop tee do 84 factory intercooled car, so its got the bigger clutch and flywheel. Cant get the bigger clutch from worldpac, gonna try the dealer tomorrow and see how quick I can get one. |
#37 |
All the gauges
![]() Nothing special, but its progress. Got the rear calipers on, cleaned up the rotors, poly torque rod bushings, a new tie rod end, and new wheel bearing. Clutch is on the way along with engine and tranny mounts. Front calipers should be here tomorrow as well. Hopefully I get the right clutch
![]() Couple pics ![]() ![]() Thats all for tonight, hope to have all of the brakes done tomorrow along with the beginnings of the engine swap. |
#38 |
All the gauges
![]() Engine is in, trans goes in tomorrow. Got the front brakes on as well.
![]() ![]() ![]() Last edited by stick70; 03-10-2010 at 01:22 AM.. |
#39 | |
![]() Very very nice!
#40 |
All the gauges
![]() Woot! Rust fixed today, no more holes in the floor! Gonna paint the floorpan black, itll have to sub as my black carpet for a while
![]() Only suffered a few burns and only set the car on fire twice! ![]() |
#41 |
![]() Where in NC are you?
'84 244TIC - 15G, Ported 90+,LAO DP, 3" full mandrel bent exhaust, NPR, Halman Pro MBC, IPD T Cam straight up, Term 11, 14-15psi of fun, front polys in, rears in..Koni Yellows on cut stock springs. '94 945TIC - Son's first car...Project "Swagon" Billy's, IPD springs, pretty stock...so far! '98 S90 - Stock...couldn't pass it up. '12 MX5 SE - What a fun car! |
#42 |
All the gauges
![]() I live in charlotte, but im about an hour north of raleigh alot to work on the car
#43 |
All the gauges
![]() The car is now officially rust free!! Yay! Got the seat pan welded back in and painted black to match the floor, sealed everything up underneath as well. My left buttcheek was crushed up and rusty, and after I beat it back into shape with a 4x4 and a hammer it had a couple holes in it, so I got those welded up as well. The seats and floor vents are back in for good now, feels good to have a rust free 242. Plugged the egr pipes on the head as well, Ill remove them completely when I turbo the car. Glad to have the floor fixed, progress at last.
#44 |
All the gauges
![]() updates, trans is in, springs cut, floor fixed and painted
![]() new clutch ![]() ![]() seat pan back in ![]() ![]() |
#45 |
dunning-krugersquirt
![]() Love the stance.
1966 220 wagon: dormant resto project 1999 S70 manual: #base, 192K 2000 V70R: 135K, deer victim/just a flesh wound 2006 V50 T5M AWD: 145K Feedback Thread |
#46 |
![]() how many coils did you cut?
#47 |
All the gauges
![]() I took out 3 in the front and 2 in the rear, no a/c. Itll go lower when I get coilovers obviously, but im not running it jacked in the air. I dont want to go lower with stock struts.
#48 |
![]() Damn Kyle, You're putting many of our project car threads to shame.
Keep up the good work, I'd like to see this one at SE in October.
I have no Volvo, therefore I have no life. Need vintage motorcycle parts? Visit Rubber City Vintage Cycles |
#49 |
Home Schooled
![]() yeah seriously, keep kicking it, you make todd look slack as all getout
![]() speaking of which, todd, when are we gonna finish your car? |
#50 |
All the gauges
![]() Thanks guys
Yeah todd it will be running by then im sure hell it may even be turbo by then, it may even run for carlisle, but if it does i prob wont be driving it up. Idk, its not going to be comfortable at all, i need to fix the drivers lumbar support. I dont have any scheduling conflicts for SE this year, hopefully when it gets closer ill have some cash saved up to go. Next thing on the list is a megasquirt harness, then it will be well on its way to working, mechanically everything is a-ok, and I already have a megasquirt. |
