Old 10-02-2013, 07:21 PM   #176
kyle242gt
Still has a Volvo
kyle242gt's Avatar
I found my 15mm end wrench!
Removed the inner sheetmetal, rest of the rocker looks good. Started removing the jack points since they're going to interfere with the inner rails.
Originally Posted by stickbuilder View Post
You don't grow wealthy by working your ass off.
Get a life.
I killed a 5.044!
kyle242gt is offline   Reply With Quote
Old 10-05-2013, 07:05 PM   #177
kyle242gt
Still has a Volvo
kyle242gt's Avatar
Fixed the second hole in the rocker, replaced the captive nut for the fender, and then made the patch for the inner rocker.
Glad I went with 18ga instead of 16.
Flanged it with my new HF beadroller (kind of a POS, to be expected I suppose). Upon reflection, flanged it the wrong way - on top of the old metal. whatever, not like it's visible.
Was roaring along, really had a great handle on the welding, and of course I ran out of wire. Ugh.
Old 10-12-2013, 07:14 PM   #178
kyle242gt
Still has a Volvo
kyle242gt's Avatar
Driver's side is worse, had to cut out some of the seat support and more of the floor. Fun!
Flanged the patch the right direction this time, slid it underneath the old metal and plugwelded.
As I'm doing this I'm trying to learn the technique of metal patching in case I lose my mind and buy another rusty car.
Old 11-06-2013, 08:36 PM   #179
kyle242gt
Still has a Volvo
kyle242gt's Avatar
Continued to the rear, removed the jack points since they're deformed and in the way of the new inner frame rails.
Passenger side was no biggie, but the driver's side has body damage and rust. Cut out the affected area, made a patch, welded in. I suck at welding, but getting good with a grinder.
While straightening the rocker flange, found some more rust, cut that out and patched. Yuck.
Old 11-06-2013, 08:50 PM   #180
Magnum TE
Broke another B230F+T
Magnum TE's Avatar
lookin pro
Goldie Bricks - '92 940T : B230F+T MSnS-e...
The Black - '98 318i : stock drive-train DD
I have some cool stuff done to my cars
The Gold Car: Owner since 2001
B230F+T MS1nS-E / Ford T5, 1pc DL
ebay FMIC / Mechman Alternator
T3 60/.63 ATP WG / 98#/hr injectors
Full 3" Turbo to tail / IPD TP Cam
IPD bars / Coilovers
Koni Dampners / Lower Chassis brace
NIW-T3 camber plates / Full poly front end
Full Kaplhenke Rear end
-Torque rods -PH Bar -Subframe
Daily Driver
Magnum TE is offline   Reply With Quote
Old 11-10-2013, 06:10 PM   #181
kyle242gt
Still has a Volvo
kyle242gt's Avatar
Passenger inner frame rail in. 1" x 2" x 1/8"
Thought I could bend it, hahaha, no. Sliced, bent, welded back up.
Old 11-11-2013, 01:16 AM   #182
Magnum TE
Magnum TE's Avatar
I have been thinking of doing that to the frame rails on Goldie, to gain some more rigidity and better jack points. I may choose to use larger than 1/8 wall... what ever is in the scrap bin is usually my choice.
Old 11-11-2013, 01:04 PM   #183
kyle242gt
Still has a Volvo
kyle242gt's Avatar
I'll likely do a double layer at the front and rear for jack points and call it good. It wasn't that hard to make up the pieces. Make sure you have clearance inside though....
Old 11-11-2013, 01:19 PM   #184
JohnMc
JohnMc's Avatar
I'm cringing. Not because of what you're doing, but just because it makes me think how rotten mine is underneath.
Yeah, I really need to start over with a new body shell, mine's not really worth trying to fix.
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 11-11-2013, 01:54 PM   #185
kyle242gt
Still has a Volvo
kyle242gt's Avatar
mine isn't either.
Old 11-27-2013, 05:11 PM   #186
kyle242gt
Still has a Volvo
kyle242gt's Avatar
Was going to work on the trans crossmember and floors today, but had a small situation with the engine hoist - unsure if it had enough fluid, I lowered it down all the way and proceeded to pull out the inspection plug. about a quart of jack oil shot out, hit me in the face as well as shooting all over the damn garage.
Definitely low on fluid now.
Got the other frame rail in, and figured I may as well tie the rails to the front frame horns.
If I didn't know better, I'd say that almost looks like I know what I'm doing.
Old 11-27-2013, 05:35 PM   #187
Rectilinear
Longitudinally Mounted
Rectilinear's Avatar
Looking good as always! You are inspiring me to get out and get the Datsun underway.
Now if only I had some time....
Originally Posted by A Random CL Ad
A Volvo 240 does not have a slow zero to sixty time. Nor a fast one. It reaches sixty precisely when it means to.
Rectilinear is offline   Reply With Quote
Old 12-02-2013, 12:41 PM   #188
kyle242gt
Still has a Volvo
kyle242gt's Avatar
Trans crossmember is in, tied to the outer rails as well as the inner frame horns. The way it's assembled I'll have about 1/2" of up/down leeway to fine tune driveline angle if needed.
Put the engine, trans, pedals, steering, seat back in to get the feel of it. Gonna be tight. Up next is a bunch more metal work. Have to adjust the trans crossmember - didn't leave room for movement of the trans (oops). Will also have to widen the footwell area, really not enough room for clutch in and brake down without hitting the gas.
Then the firewall, floors, tunnel, column hanger. Going to pass on further frame bracing for now.
Old 12-02-2013, 03:21 PM   #189
spe1983
spe1983's Avatar
Looks really good, also your welding appears to be getting very good.
1972 142 w/ 130K, in progress.
1992 944T w/ 195K, DD
2004 XC90 2.5T AWD w/ 124k
1984 242T - gone, now brettmobile
1994 855T - gone
spe1983 is offline   Reply With Quote
Old 12-02-2013, 03:26 PM   #190
kyle242gt
Still has a Volvo
kyle242gt's Avatar
Thanks!! I keep reminding myself (as I receive my semi-regular overhead shower of molten slag) that I'm learning things while beating myself to death on this otherwise pointless project.
Old 12-03-2013, 01:27 PM   #191
Rectilinear
Nothing pointless about it. You are building a hell of a machine!
Old 12-03-2013, 01:33 PM   #192
JohnMc
JohnMc's Avatar
Are those new frame rails going to tie into something like a 4-bar rear suspension at some point?
Old 12-03-2013, 02:24 PM   #193
kyle242gt
Still has a Volvo
kyle242gt's Avatar
Thanks for the kind words!!
That's a definite possibility. The rear suspension is complete and functional as it stands, but will likely need to be revisited.
The rails also make a nice place to attach the trans mount, and provide some stiffening... if I wind up wanting/needing to and some roll cagery to it, the rails will also serve as a good solid tie-in.
After falling victim to analysis paralysis time and again, I'm basically just putting one foot in front of the other. It was suggested (by RWC IIRC?) to run some rails, who am I to argue with him?
Old 12-18-2013, 08:33 PM   #194
kyle242gt
Still has a Volvo
kyle242gt's Avatar
Default Floor pans
Made the floor pans; still need to bead roll them and drill holes for the spot welds. Plan spots along the frame rails, and bead and/or stitch weld where it meets the old floor.
Planning to weld from the bottom, overlap on the top (except for one section of the driver's side, where it overlaps under the seat support. The old floor material is pretty rusty on top, and the inside corners too hard to grind clean. I have a product called "rust mort" that I'll put in the overlapping area to mort the rust that's there.
Interested in feedback on that plan.
Old 12-18-2013, 08:43 PM   #195
kyle242gt
Still has a Volvo
kyle242gt's Avatar
Default Clearance, Clarence
Before welding in the floors, I want to be sure to tackle anything else made simpler by having no floors in place.
One such issue is the clutch pedal clearance. I'm using (a piece of) the Mustang's firewall for the pedal cluster mounting, to keep the relationship between clutch/brake/gas pedals.
In so doing, there's precious little room for the clutch foot... I have this concern that with clutch-in, I'd be unable to fully depress the brakes. Not a good scene.
Following my ongoing strategy (if it's in the way, cut it out) I removed a section of the inner body to make room. There was a 2" piece of metal between inner and outer, so it's gone too.
The firewall section is thicker than the inner or outer body. I'd estimate 14 ga vs 18.
I'm figuring since I put the new inner frame rails in I can afford to sacrifice some hull integrity. Current thought is to transition the inner body to the outer, boxing it in, and enclose the open area of the firewall. I have a sheet of 16ga for this.
What do you think of that?
From there, I'll get the column position nailed down and fab up the rest of the firewall and tunnel. Then on to wiring, plumbing, headers, gas tank, heck, I'm almost done!
Old 12-18-2013, 09:52 PM   #196
Rectilinear
You can drive yourself crazy chasing down every single dab of rust on a 40 year old car. You are doing a great job of replacing metal and making the car more structurally sound that it ever was. Use your best judgement and fix what you can get long as you feel good that it will not cause problems down the road.
While I am not familiar with the exact product you speak of, it sounds similar to Naval Jelly that folks used to use to convert rust. Nowadays, I would be comfortable with using POR 15 with their metal prep for hard to reach areas.
As always, looking good!
Old 12-18-2013, 10:38 PM   #197
kyle242gt
Still has a Volvo
kyle242gt's Avatar
Man, you have no idea how good that makes me feel. Thanks!!
Old 12-19-2013, 02:13 AM   #198
Magnum TE
Magnum TE's Avatar
I approve of cutting metal that gets in the way.
Old 01-01-2014, 04:16 PM   #199
iadr
Originally Posted by 745 TurboGreasel View Post
Early Tempests used a wire rope driveshaft,
Myth. They looked like they hung like rope in the technical drawings/advert drawings, so people concluded they were.
Actual material was a spring steel, OD-ground, solid tube.
Just FYI
iadr is offline   Reply With Quote
Old 01-03-2014, 03:14 PM   #200
Andrewhans
Turbo LS ****poster
Andrewhans's Avatar
This is going to be amazing. So much work involved and you jsut slowly keep plugging away at it. Keep it up!
Current setup - Aluminum L33/Summit Turbo Stage 2, single Walbro 450 and Dual AEM 400's, Bosch 210's
3060lb no driver
3240lb with driver
