Old 12-29-2016, 05:34 PM   #101
Broke4speed
Broke4speed's Avatar
Ran out of heat shrink tubing :(.
Old 12-31-2016, 03:08 PM   #102
Broke4speed
Today was a good day
The cheap Windows tablet I got specifically for tuning this car connected first try, and all the sensors read properly. I'm pretty stoked, because I was a bit concerned about my home-made harness, and the master disconnect I put in the middle of it to facilitate engine removal. 93-99 VWs have a nice round 36-pin connector at the engine harness, so I grabbed one at the junkyard and put it to use.
Old 01-01-2017, 04:31 PM   #103
Broke4speed
The wiring is done (mostly)! I need to wire in an IAT, and connect the low/high fan outputs, but the rest is finished.
Old 01-08-2017, 04:59 PM   #104
Broke4speed
Intercooler mockup has begun. I'll be able to use mostly OEM piping/connectors, so I'm pretty happy. I have to get some 0.125"x1 flatbar to make some lower IC brackets, just to drop it enough to allow the upper core support to sit properly.
Old 01-14-2017, 05:57 PM   #105
Broke4speed
Intercooler in, new transmission cooler lines run (bending my own), and 1.5-2 coils cut out of the front springs. I can't get decent pics inside the garage, so I'll have to wait until I can roll it outside.
As soon as the tranny lines are done, I can put some ATF and oil in, and try to fire it up .
Old 01-15-2017, 02:11 AM   #106
John242Ti
LH-Jet & Carb Free Zone
John242Ti's Avatar
^I guess we can consider your 244's B21A a B21F+T now. Nice work. Should be a fun spring through fall driver...
-J
@1982_volvo_242_turbo on IG
Old 01-15-2017, 10:47 AM   #107
InTheWhite
InTheWhite's Avatar
Nice project!
Don't know if i missed it, but ar you going to tune the engine as well?
Old 01-15-2017, 11:06 AM   #108
Broke4speed
-J
Yeah, I'm definitely stoked. I will have to do something about the lack of tunes, but I plan on driving this from end-of-salt to beginning of salt, lol.
Old 01-15-2017, 11:12 AM   #109
Broke4speed
Originally Posted by InTheWhite View Post
Nice project!
I plan on sticking to ~10psi (9.3:1 CR), and it comes with an A cam already, since it was a carbed car originally. The engine only has 125k KMs (77k miles) on it, so I am just going to enjoy it for now. The megasquirt will be enough fun to keep me occupied for a while, haha.
Old 01-15-2017, 11:22 AM   #110
InTheWhite
InTheWhite's Avatar
Okey!
I was just curious because i'm haveing an AW71L in my 945 as well and are a little bit concerned if it will put out with my 185hp and 290Nm. But it shouldn't be a problem.
You are up in those numbers with your engine to?
Old 01-15-2017, 04:06 PM   #111
Broke4speed
I'm going to aim for 200hp, but I've rebuilt the transmission and done the accumulator mod. I don't expect any trouble, especially since I'm not very hard on my cars anymore . I probably could have gotten away with a stock rebuild, but I like sharp shifts .
Old 01-15-2017, 11:46 PM   #112
amerbritcan
Hnnnnnng
amerbritcan's Avatar
1990 745tic
1984 244DL (parts)
Originally Posted by My Mom
Get a bike
Poopie scissors
Old 01-16-2017, 09:42 AM   #113
Broke4speed
Haha, nice. I've never seen that one before .
Honestly, I was a drag racer, and even though I don't plan on doing much with this car (I'm gettin' old), autos are king when it comes to straight line speed. I like to tell myself that, to help justify putting one in, when the truth is that I just want an auto so I don't have to clutch anymore, haha. My daily subie is a 5-speed, and getting stuck in traffic is a bitch to a guy with old knees.
Old 01-21-2017, 01:51 PM   #114
Broke4speed
Got home from supper at the inlaws last night (enchilada casserole, god I love my MIL), and decided to put in some ATF, oil, and try to fire it up. After a few minutes of work, a DIY VW coil-to-volvo dizzy cap wire, and a double check on spark/fuel...it fired up straight away . There's no downpipe, and it wouldn't idle on it's own, but damn I'm stoked.
Today's job is to reassemble the dash and install the OEM triple-gauge panel.
Old 01-21-2017, 08:38 PM   #115
Broke4speed
Today was a successful day. The interior is back together, the car fires right up on the MS1, AND the transmission works (once I added enough ATF, oops). I have a f**king oil leak near the oil return, that seems to be from the pan flange. It didn't look warped from the welding, but maybe it is a bit. Liveable, but very irritating.
I also got my downpipe fabbed up, and it was super easy. My turbo is a 16T angled flange, and I grabbed the DP from the S60 when I got the turbo at the junkers. All I did was cut the DP at the flange, rotate it a bit, tack it, test to fit, and weld. It took 10 minutes. There's even an O2 bung, so I didn't have to install one.
Old 01-22-2017, 06:41 AM   #116
InTheWhite
InTheWhite's Avatar
Nice that it fit so well!
Old 01-23-2017, 06:40 PM   #117
Broke4speed
Finished my intake piping tonight. I've deleted my window sprayer for now, because I am using an old Turbo Dodge airbox for my intake/filter. There's a nice port on the bottom for the PCV line, so the oil vapour stays in the sponge in the pocket, but there is constant suction on the line. I've used these before, and have seen very little difference in power level (at least for my needs) vs. a cone filter.
Old 01-27-2017, 09:17 PM   #118
Broke4speed
It makes total sense that the e-fan relay I grabbed months ago from the 940 fan donor is completely pooched inside. After getting it all wired up, it wouldn't work...so I popped the cover off...yuck!
I went to a local yard and grabbed 5 others (one is in the car already) for $16 after tax. All of them are sparklingly clean inside, and work great.
Old 01-28-2017, 12:54 PM   #119
Broke4speed
Still fighting a f**king oil leak at the pan flange
I drained a quart of oil, and the level read at the halfway point on the stick, so maybe there was just too much oil and the cheap chinese gasket wasn't having it. Anyway, we'll see what happens next. I snugged down the low side oil pan bolts too.
Old 01-28-2017, 08:44 PM   #120
Broke4speed
Looks like the pan is coming off :(.
Now I have to decide if I hate myself, or REALLY hate myself. Do I fight my way through it from underneath, or do I take the engine out?
I really regret not filling it with oil and checking BEFORE I put it in :(.
Old 01-28-2017, 10:51 PM   #121
Jack
junkman
Jack's Avatar
there are these gaskets
also you can suspend engine and drop the sub frame
I love you even more Jack.
Old 01-29-2017, 09:10 AM   #122
Broke4speed
I'm probably going to do just that. I've accepted my fate. I'm going to pick up one of those engine support bars this week and try to tackle the job on the weekend. I'm putting money on the possibility that the flange isn't straight, even though I thought it was.
Old 02-15-2017, 09:43 PM   #123
Broke4speed
So, I was right. It wasn't quite flat where I welded in the oil return. The outer lip was fine, but the inner was low, so no amount of gasket would seal it up. I dumped it right into the trash and went with a tried-and-true method that a lot of manus use now...RTV. 24 hours later, and the joint between pan and block is bone dry. I ended up dropping the entire subframe, since going with the RTV method requires a straight-shot to the sealing surface, more or less. It wasn't any more difficult than lowering it slightly, and it's a good excuse to clean it before I put it back in.
Old 02-20-2017, 02:19 PM   #124
Broke4speed
After all the threads I've read here about doing the oil pan gasket, I could not believe how easy it was to drop the subframe in it's entirety to make the job even easier. I highly recommend that method, even though I know I'll be criticized for suggesting it, haha.
I undid the front and rear control arm bolts, steering shaft, tie rod ends, steering rack lines, all the wee brake line bolts, and the subframe bolts themselves. It dropped right out, no fuss, no muss. Then I could clean the mating surfaces perfectly, apply the RTV, and slap it all back together. The leak issues have been solved (never using a separate gasket again, on anything), the front end has been re-assembled, and now I'm working on the downpipe.
Old 02-25-2017, 08:06 PM   #125
Broke4speed
Bought this, while I'm dragging my ass finishing the exhaust.
