Old 02-18-2017, 05:05 PM   #76
Cwazywazy
Single jingle
Cwazywazy's Avatar
Got the interior back together and I was sick of not driving it so I stuck the spring back in place and went for a test drive. The steering tries to stick to the center and clunks when I turn it past center... The ****.
I don't know what I have
Old 02-18-2017, 08:55 PM   #77
57plymouth
57plymouth's Avatar
Two things:
First, it sounds like it's hanging in neutral and your shifter is causing yiu b to think it's out of gear.
Second, the steering is a more serious issue as you know. Take a good look at the intermediate shaft between the rack and the column. It may need replacing. Also, if you can put the front end on jack stands, try disconnecting the intermediate shaft and turning the front wheels while the car is running. If it turns rather freely, the issue is in the column. If not, it is in the rack or column. If you eliminate the column, reconnect the intermediate shaft, and disconnect the tie rods. Then you will know if it is the rack, the tie rods, or the column.
Old 02-18-2017, 10:10 PM   #78
Cwazywazy
Single jingle
Cwazywazy's Avatar
Originally Posted by 57plymouth View Post
Two things:
Hanging in neutral? I'll look into the steering tomorrow, thanks.
Old 02-18-2017, 11:21 PM   #79
57plymouth
57plymouth's Avatar
It may feel like you get into neutral, but it may be hanging a gear engaged.
Old 02-18-2017, 11:33 PM   #80
Cwazywazy
Single jingle
Cwazywazy's Avatar
I did take a video. What do you think?
Also earlier when I was putting the interior back together I found a rectangular thing in the back of the driver's seat.. Feels like thin flimsy plastic. No idea what it is or how it got there.
Old 02-19-2017, 04:52 AM   #81
petiww
petiww's Avatar
Seems like a sticky pilot bearing. Does it grind gears when you want to engage reverse from neutral?
1980 Brown 244 GL
Old 02-19-2017, 10:57 AM   #82
Cwazywazy
Single jingle
Cwazywazy's Avatar
Haven't noticed any grinding at all. This is in neutral, clutch engaged. I didn't check to see if it stopped spinning if I stepped on the clutch.
Old 02-19-2017, 12:08 PM   #83
petiww
petiww's Avatar
Oh damn, my mistake... Then its just the gearbox itself. Our family fwd astra can move itself just a bit forward in neutral when its cold. If it gets hot it does not do it.
Old 02-19-2017, 06:16 PM   #84
Cwazywazy
Single jingle
Cwazywazy's Avatar
Do I have to remove the brake lines to get the strut assembly out of the tower?
Old 02-19-2017, 06:23 PM   #85
Yes if you want to remove it anyway.
What are you trying to do remove the spring?
Old 02-19-2017, 07:27 PM   #86
Cwazywazy
Single jingle
Cwazywazy's Avatar
I read somewhere that you can just lower the strut assembly and lean it out but I don't seem to have enough brake line to do that..
Old 02-19-2017, 08:09 PM   #87
You can but you have to unbolt the flex line anchoring bracket, and the steering drag link to get enough slack.
Edit:
Oh and the sway bar obviously.
Old 02-19-2017, 09:42 PM   #88
Cwazywazy
Single jingle
Cwazywazy's Avatar
Edit:
Already undid those. Looks like I'll be taking the lines off, ordered some new ones because I might as well.
Old 02-20-2017, 02:36 PM   #89
Cwazywazy
Single jingle
Cwazywazy's Avatar
I only managed to get one line off but it seems that's all I needed. Got the driver's side spring off, which only took about 2 days to do. Ugh.
Old 02-20-2017, 09:30 PM   #90
Cwazywazy
Single jingle
Cwazywazy's Avatar
Old 02-20-2017, 09:34 PM   #91
*sweet*
Did you rip off the side trim to 'clean up the look' yet?
Old 02-20-2017, 09:49 PM   #92
Cwazywazy
Single jingle
Cwazywazy's Avatar
*sweet*
No, the trim makes it more luxurious and fancy.
Old 02-21-2017, 06:18 PM   #93
Cwazywazy
Single jingle
Cwazywazy's Avatar
She's roadworthy again. Swapped front springs with the 86. Steering still tries to "stick" in the center. Biggest issue now is no heat. Blower doesn't turn on and I'm pretty sure it's still stuck on recirc.
Old 02-21-2017, 06:20 PM   #94
Jack
junkman
Jack's Avatar
check fuse ?
I love you even more Jack.
Old 02-21-2017, 06:53 PM   #95
Cwazywazy
Single jingle
Cwazywazy's Avatar
check fuse ?
Not that. I made sure the plug on the back of the fan switch was on all the way too. Obviously something I did because it worked fine before I took the dash apart.
Old 02-21-2017, 07:00 PM   #96
Jack
junkman
Jack's Avatar
corroded fuses could be causing your stuff... especially where you are. and dont use the aluminum ones
just trying to save you time... nothing like digging for a problem then spinning the fuse and instafix
Old 02-21-2017, 07:09 PM   #97
Cwazywazy
Single jingle
Cwazywazy's Avatar
I know, I'm already familiar with the issues aluminum fuses cause.
Old 02-21-2017, 07:52 PM   #98
Cwazywazy
Single jingle
Cwazywazy's Avatar
I'm also having an issue with the engine cutting. Mostly at low and high revs. Just falls flat on its face for a split second like the ignition is cutting.
Old 02-23-2017, 04:07 PM   #99
Cwazywazy
Single jingle
Cwazywazy's Avatar
So turns out one of the pins to the connector on the fan switch came off. Easy fix. Looked into the recirc issue some more. Switch works fine, but I can suck on the vac line constantly. I'm guessing it came off or there's a hole or something. How hard is it to get to wherever the vac line goes? Looks pretty deep inside the dash..
Old 02-25-2017, 02:24 PM   #100
Cwazywazy
Single jingle
Cwazywazy's Avatar
So since I fixed the blower my speedo stopped working. One day I'll manage to fix something without breaking something else. Followed the recirc vac line and it just disappears behind the blower housing thing. I'm thinking I'll go to a dyno day on Mar 5th but I wanna figure out why the car is breaking up at high RPMs before I do. I did some WOT pulls on the highway earlier. It pulls fine up until about 5-6k when it starts to break up a little. Cruises fine though, except for the vac leak causing it to almost die at times when idling.
It bucks super hard if I give it any gas when turning at low parking lot speeds. Really annoying.
