Old 07-24-2018, 10:19 AM   #226
Andrewhans
Turbo LS ****poster
Andrewhans's Avatar
Originally Posted by cosbySweater View Post
I had mine like that for a long time on 91 octane. It was sitting at around like 22 degrees. Didn't loose any material but still. Lol
Jesus lol. E85 has absolutely saved my ass quite a few times on my tuning adventure. It's amazing.
Current setup - Aluminum L33/Summit Turbo Stage 2, single Walbro 450 and Dual AEM 400's, Bosch 210's
3060lb no driver
3240lb with driver
Old 07-24-2018, 12:20 PM   #227
cosbySweater
cosbySweater's Avatar
Yea e85 is nice. I still have some slight ping on mine even with the e85 at the track, my fuel system is completely maxed out on the car. So after the fuel system gets addressed I'm gonna crank it up till it leaves the crank on the ground
1995 Porsche 993
2013 VW Passat TDI
Old 07-24-2018, 01:46 PM   #228
Andrewhans
Turbo LS ****poster
Andrewhans's Avatar
I think I may be able to do that with my voltage boosted walbro 450 on e85. I know for a fact I could make enough on 93 to drive over the rods with that pump. It's a monster when voltage boosted.
Old 07-24-2018, 02:13 PM   #229
cosbySweater
Yea those voltage boosters do work. However the nhra stuff is really strict here in California at least at the tracks I've been too. So I need to redo the fuel system anyway. So may as well just throw in another pump!
Old 08-19-2018, 09:18 AM   #230
Andrewhans
Turbo LS ****poster
Andrewhans's Avatar
If I need more pump than this I have to redo pretty much the entire system from tank to rails. Ill probly just keep inching forward. I would like to hit 600whp on e85 with a single 450 and deka 80 but Im just gonna push till I see fuel pressure drop off a little and back it off.
Old 08-19-2018, 10:52 AM   #231
Andrewhans
Turbo LS ****poster
Andrewhans's Avatar
Finall got around to working on the 8.8" now that the Volvo axle is starting to make some noise.
Standard stuff here, cut 2 7/8" out of long side, reweld install another short axle.
Just need to put it under the car now and get the brackets finish welded on.
Old 08-19-2018, 01:35 PM   #232
740atl
educator monkey
740atl's Avatar
Looks great. Are you using adapters or 5x114.3 rims?
Old 08-20-2018, 10:38 AM   #233
Andrewhans
Turbo LS ****poster
Andrewhans's Avatar
Using the dual bolt pattern jegs/summit brand steel 15x6 wheels. Has the 5x108 and 5x114.3 with the right offset.
Old 09-20-2018, 09:58 AM   #234
Andrewhans
Turbo LS ****poster
Andrewhans's Avatar
Havent been updating much bc the 8.8 swap has been in progress. Hopefully I get the driveshaft back today/tomorrow. I will hopefully have a full 1/4 mile on slicks pass if the track is open this Saturday.
The local 1/8 track hasn't recovered yet from the hurricane so that's out for tonight.
Old 10-16-2018, 05:55 PM   #235
brendon_ak
Just read the whole build, what a monster!!
Old 11-01-2018, 08:13 PM   #236
Andrewhans
Turbo LS ****poster
Andrewhans's Avatar
So 8.8 swap got finished. 3.73's were still in the axle. So 8.8 swap got finished. 3.73's were still in the axle. LSD made a big difference in how much power I can put down at the track. Been turning it up slowly. Up to 18psi now with 7875. It's an absolute animal now. Hit my personal best of 6.99 at 107mph in the 1/8th. Best mph of the night was 108 and change.
Also got it regeared to 3.27 this past weekend and it made a WORLD of difference for how the car drives. Should have done gears a long time ago. Im seeing a 250-300rpm drop at 60mph. I could see the track times improving too because of the higher launch rpm Ill be able to hit before I push through the brakes.
Also completely redid the brake system. New rotor front and rear, EBC Yellow Stuff pads front and rear, new master cylinder, and new distribution block thing. The difference is amazing. Before I was only able to hold the tires until about 2100rpm on street tires before I would push through the brakes. Now with new brakes and same tires I hit 3200rpm before I pushed through.
I cant wait to make some more passes with the new gears and redone brake system.
Old 11-01-2018, 08:25 PM   #237
MDVLN
Kapitän Klugscheißer
MDVLN's Avatar
Nice stuff. Just off high 10's in the 1/4. Has it been weighed at all? I'm just curious to where it may be with some stuff removed and other stuff re-added.
Old 11-01-2018, 08:46 PM   #238
Andrewhans
Turbo LS ****poster
Andrewhans's Avatar
Without me in it, full tank of fuel with random tools in the back, no rear seat it weighs 3040lbs. My goal for the car was drive an hour to the track, switch to slicks, run a 10, switch to street tires and drive an hour home.
I want to get it re-weighed with the 8.8 swap done. Im also skeptical of the numbers and want it on another scale.
Old 11-06-2018, 10:50 AM   #239
Andrewhans
Turbo LS ****poster
Andrewhans's Avatar
So the not so fun money spending has begun too. Need front tires, balljoints, tierods, shocks, strut mounts. Now that the swap is done as driving the rest of the car needs attention.
Old 11-12-2018, 06:44 PM   #240
Andrewhans
Turbo LS ****poster
Andrewhans's Avatar
So a local car group was going out to Fayetteville for some 1/4 mile action. Prepped the car by doing plugs(NGK-BR7EF), oil(5w-40 T6 Rotella), rear diff fluid(Redline 75w-140NS) and just giving everything a once over.
After the plug refresh I had to check to make sure the 2 step still worked... it did.
So initially a big goal of this car and this build was to drive about an hour to a track, switch to slicks, run a 10, switch back to street tires and drive an hour back.
I am EXTREMELY happy to say that was achieved. The slicks were toast and I was having severe traction issues in the first 60' on every pass except my first one(which was also the fastest ET of the day). The track was getting worse as the day was going on and my slicks were already corded and just getting much worse. Even with the garbage dead slicks the car still managed a 10.68@134.3mph. This was on around 15psi if boost.
This pass was with boost around 17.5psi and stable fuel pressure the entire pull. -6AN line, single Walbro 450, deka 80's on E85 is doing amazing work with the ECS Fuel Pump Booster powering it.
Overall I've had an amazing weekend and can't believe I hit my goal that easily. I honestly think this car has a 9 sec pass in it with 2 more psi of boost and a 1.5-1.6 60'
Not bad for a china turbo, camshaft, valvespring gen 3 4.8 with 366k miles on it.
Old 11-12-2018, 07:37 PM   #241
MDVLN
MDVLN's Avatar
Congrats!
Old 11-12-2018, 10:29 PM   #242
soclosenotnear
Nice work!
check my feedback here
Old 11-13-2018, 08:42 PM   #243
Andrewhans
Turbo LS ****poster
Andrewhans's Avatar
Thanks. The slicks are toast and I'm done racing at the track until I get a new pair.
Going to step up to 26x8.5x15. Had worn out 24.5x8x15 on there. I think that having a little bit more tire will allow a better 60'. I also need new shocks up front bc the front lifts really fast then starts to come back down and the rear tires unload and spin.
Really need to start designing some Anti-Squat into the rear suspension. That includes a complete redesign of the system and I'm not really ready to go that route yet with the car.
Going to continue to make small changes and track progress.
Old 11-17-2018, 11:04 PM   #244
Andrewhans
Turbo LS ****poster
Andrewhans's Avatar
The wife surprised me with a set of MT ET Street Drag Radials for a "just because" gift. Couldn't believe she did that.
There's a local "street car" shootout that I will be able to attend now too. They weren't allowing slicks to race so the that fact she bought street tires makes it even better IMO.
So we will see how it does or if I can get it to hook on radials. Should be a fun experiment switching from a 24.5x8x15 slick to a 235/60/15(26x8.5x15) drag radial.
It just dead hooks at a 60 roll now. The acceleration is amazing with these tires. I'm blown away and it is a rocket on the street instead of spin city.
The radials also have the added bonus of providing a huge amount of grip when needing to pull something... like a stuck F250. My truck got stuck in the side yard from all the rain we've been having and the only vehicle that stood a chance of pulling it out was the volvo. Hooked up some straps and pulled it right out. Haha
Old 11-21-2018, 02:16 PM   #245
Andrewhans
Turbo LS ****poster
Andrewhans's Avatar
Car didn't do terrible on the 235 radials. Faster mph and et than I've ever gone but just by a little bit.
New personal best is 6.86 @ 107.8mph with a 1.68 60'. Still working towards a 6.5 or so at 110+
Old 11-23-2018, 08:23 PM   #246
Andrewhans
Turbo LS ****poster
Andrewhans's Avatar
Here are some photos from the StreetCar Shootout I entered. Had a really good time. A $100k+ turbo Camaro from RPM Motorsports ended up winning the whole thing. I made it to the second round at least. I lost to the guy who came in second place. So I don't feel bad at all about it. Almost everyone there had a 275 or bigger tire so I was the massive underdog when it came to tire size.
This is my first round win. I ended up driving around him before the 1/8th was over. It was a close finish bc of my poor 60'.
Here it is lined up against the nitrous Mustang that took second. Local guy who races here a LOT and knows the track very well.
Here am I losing to that mustang LMAO. He was cutting in the high 1.3 to low 1.4 60'. I was around 1.7-1.8 the whole night. He had more tire, better suspension and far better track knowledge. I was very close in power judging by the mph we were both putting down.
Good friend backing me up into the water box and helping me with some drag racing tips throughout the night. I had a really good time.
Just a good shot of the suspension at full drop while rolling out.
Old 11-23-2018, 11:18 PM   #247
Andrewhans
Turbo LS ****poster
Andrewhans's Avatar
Forgot to add that I re weighed it.
No back seat
8.8 swap
235/60/15 drag radials
TH350
Iron block 4.8
Front battery
Turbo
Rear mounted AC condenser(trans cooler)
3140lbs
1800lbs front
1340lbs rear
Old 11-24-2018, 12:13 AM   #248
55superbeetle
Awesome
83 242, Turbo 6.0 LSX, E85, TH400, 8.8, 10.3@135
55superbeetle is offline   Reply With Quote
Old 11-24-2018, 09:06 AM   #249
Andrewhans
Turbo LS ****poster
Andrewhans's Avatar
Originally Posted by 55superbeetle View Post
Awesome
Thanks, your build was one of the largest influences for this car. Simple, cheap and effective is how I saw your build.
Turning it up more and going for a 9 next.
I think it has a very high 9 at 140mph in it with a little more power and a 1.6 60'. All my current ET at mph records have been at 15psi. Its held 20psi on test pulls with stable fuel pressure so we will see what happens at the track if weather holds up.
Old 11-26-2018, 10:40 AM   #250
Andrewhans
Turbo LS ****poster
Andrewhans's Avatar
Went out to Coastal Plains today because all of my close tracks had been rained out.
Drove an hour and a half to get to the track on drag radials, dropped tire pressure to 18psi, ran 5 tens in a row with the slowest being a 10.68@136, and drove back home without an issue.
Had an excellent time there and Im getting closer and closer to my 9 sec pass and 140mph goals. I should have been more aggressive on the 60' because the track was hooking really well.
I'm also past the limit of my 6psi wastegate springs. With 100% duty cycle I can touch 19psi and then SLOWLY taper to 17.5psi by redline. Going to step up to an 8-10psi spring so I can hold a stable 20psi to redline.
The little gen 3 4.8 is hanging in there! 367k miles and counting on the entire engine minus camshaft(Jegs 200580), valve springs(PAC 1218), a single used piston rod combo(unknown miles), and one new cam bearing(the rest are the originals). Re-used TTY headbolts, re-used tty rod bolts, stock headgaskets.
Just wanted to keep you few that have been following since the start updated!
