#101 |
![]() Join Date: Jul 2002
![]() good work on getting that brace to clear,
I figured you would either be sectioning the intake manifold or doing something of the sort. One thing I would recommend is making a cap or gusset to blend between the sheet metal bar that you welded up and the top of the tubing.
#102 |
![]() Ditto on the gusset suggestion - was typing away on the previous page, and then saw Ben's comment....
'82 242 6.2L; '17 Mazda3; '16 CrossTrek |
#103 |
Keep it clean...
![]() Haha. Right on, proving them all wrong! Love following the progress on your build!
Derek 1980 242 16" BBS RSs - 25/25 Sway Bars - Bilstein HDs - SuperPro Poly - MSD - R Sport Wheel - 'Skinny' Bumpers' -Project Thread- |
#104 |
![]() Good advice. Had about a half hour at home last night and messed with these gussets a little bit. I also move the upper brace up 1/4", it was just a little close for comfort before.
I like this. I think I am going to incorporate a brace right into the upper strut tower bar for the brake booster instead of the bolt on version. ![]() |
#105 |
![]() Can you show the brace from behind? Does the intake manifold extend past the main bar plate? If it doesn't you could box it in from behind to make it like angle iron.
#106 |
80/20 speed parts club
![]() I'd make room for the brake booster brace. It is as good as the strut brace itself, if not better.
#107 |
Sleazebag 7-9 Owner
![]() Beautiful... I'm just going to set all my stuff on fire as it so inferior to this build. Good work, keep that progress rolling!
#79WDP 2010 Porsche Cayenne S - DD 2010 Cadillac Escalade ESV - Wifeys ride - 194k stock 2006 Cadillac DTS - Sons ride - 193k stock mint 2006 XC70 Wagon - "Chuck Feo" - Daughters ride - stock 1992 965 - "Savage Wagon" w LS 5.3 LM7 + LS7 cam + GM T5 swap in progress. 1983 Jeep Cherokee - LS 5.3 LM7 + LS9 cam + SM465 swap in progress 1979 Porsche 911SC - stock 1971 Chevy C-10 w 5.3 LS (LS2 cam) & GM T5 trans 1948 Spartan Mansion travel trailer - aluminum greatness |
#108 | |
Knipex=welfare queen
![]() Looks good. Everyone always says it's not going to fit. If a 4 valve Ford fits with a Cobra intake, anything can fit.
Member: TBCCS "The urge to save humanity is almost always only a false-face for the urge to rule it.” -H.L. Mencken Quote:
#109 | |||
![]() Quote:
Sean |
#110 |
Sarcastic Optimist
![]() Too slow...
^^^ what he said.
2013 Audi Q5 1989 245 'Angry Moose' 5.0 GT-40 with T5 transmission. 2009 S80 Interim Road Trip Car Sold- 2006 V70R |
#111 |
#112 | |
![]() Haha....Thanks man!!!
Not sure its the finished product but its close, will have two bolts to a tab welded to the bottom of the strut tower on the front tab and the same on the rear tab. ![]() ![]() I gotta get some fuel system **** ordered up for this turd. In tank Holley 450 with a hydramat is what I am thinking. Guys are having no issues running these things on -6 lines. Regulator will be near the tank. Thoughts? Sean |
#113 |
![]() Oh snap, the flared holes make it extra baller.
#114 |
Comes with a free Frogurt
![]() What's the model year & trim level Mustang that donates its master cylinder to all of these 240s? I'm looking into this myself now...
#115 |
That One Guy
![]() -6 would work but -8 would be better. Don't really want to mess with the fuel to much, Overkill is the answer in that department.
#116 |
![]() Your master cyl brace looks good.
Id prefer triangles instead of holes but you know... I think doing it the way you are doing it is a bit cleaner and for a build like this its worth while. The tube gussets on the main bar look great! |
#117 | |
![]() Quote:
The fuel rails on the factory LSA are only 5/16" as well as the quick disconnect for the fuel rail, the factory fuel pump is the same size. The fuel lines on the new ZR1 with the 750hp LT4 I believe are -6 as well. Reading up on some gen 5 camaro forums guys are running up near 4 digit numbers on -6 lines. I am more curious on feedback on the hydramat. I have heard awesome things about it being used in everything from road race cars to KOH rigs. I have a number of people I know running it and swear by it. Thanks, Sean |
#118 | |
![]() Quote:
I do like your idea though and I know you like triangles =) Sean |
#119 | |
![]() Quote:
Ill just need some templates. |
#120 |
![]() Join Date: Jul 2009
![]() It's like a sn95 gt master cylinder, Im pretty positive that's what i have on my car
1979 Volvo 244DL 5.3/4l80e,8.8,Ms3x goldbox ecu and Mircrosquirt tcu, GTX4202r, 226/230 turbo cam, tbss intake, 11.0@128mph 9psi, 3600lbs with driver 1974 AMC Gremlin, 401 v8, 727, 8.8 1974 BMW Bavaria, m30, dcoes, getrag 265 1995 Porsche 993 2013 VW Passat TDI |
#121 |
dunning-krugersquirt
![]() Killer build so far, excited to see the rest of it come together.
1966 220 wagon: dormant resto project 1999 S70 manual: #base, 192K 2000 V70R: 135K, deer victim/just a flesh wound 2006 V50 T5M AWD: 145K Feedback Thread |
#122 | |
![]() Quote:
Ben, totally appreciate the offer, its a bolt in item so if I want to redo with some cool CNC stuff later I can. I am pretty impatient =) So, one thing I am working on is my TIG welding. I have had no official classes on it, no lessons at all, just been tinkering with it off and on for a few month. I think I suck but wanted to try it out on this piece. I should have just migged it together hind sight but it will work and not fall apart. ![]() ![]() This will get powder coated and I am thinking of doing it with the tightest wrinkle black finish I can, my other idea is a satin metallic brown, interior will be brown, centers of the wheels is likely going to be the same flat metallic brown. What say you Turbobrickers?? Sean |
#123 |
equal opportunity car guy
![]() Brown sounds good. Sure nice seeing something different now and then.
Just curious is there a matching brace like the one on the brake master? And overkill is always good but is that brace needed with that stout strut brace? Love the build so far, thanks for taking us with you!
_____________________________________________ 80 Bertone (part-time driver) learn how to 5.0-Volvo here.... http://forums.turbobricks.com/showthread.php?t=250257 B20 sound! https://www.youtube.com/watch?v=6FpMWALskko 242, https://forums.turbobricks.com/showthread.php?t=344891 |
#124 | |
![]() Quote:
The brace is there to support the booster and master cylinder from movement. It was amazing how much that booster and master could move before the brace was installed. I have heard increased pedal feel is the best byproduct of the master cylinder brace. Thanks for the props!!! I am thinking more and more about the brown color for the upper strut tower and a bunch of little odds and ends. Sean |
#125 |
![]() We offer these braces in a coffee brown, They look awesome in a beige engine bay
![]() ![]() You can always smooth out those TIG welds before you powder coat it and it will look ok. |
