Old 07-31-2019, 11:54 PM   #101
R32RennSport
Outlaw Amazonian
R32RennSport's Avatar
Originally Posted by Vol242vo View Post
Get it running already!!! Can not wait to hear this thing run!
You and me both! It's called family life. I get a few hours here and there a week. I'm grateful I've even been able to get this far. Soon though, I'm so close!
Steven
1966 Volvo Amazon, 2004 VW R32 Golf
R32RennSport is offline   Reply With Quote
Old 08-14-2019, 01:44 PM   #102
R32RennSport
Outlaw Amazonian
Just a little update. This is my current solution for adapting the throttle cables to the DCOE's utilizing the stock accelerator pedal. The coil relocation cup made for a convenient bracket mount location. Just a simple cable clamp and a radiused pinch washer. I'll add cable stops for security once I figure out final lengths. Cables run up and out parallel to the speedometer cable.
Old 08-14-2019, 02:56 PM   #103
sspony
sspony's Avatar
So what did you do for the choke cable on the dcoe's?
Potential, potential, potential....
65' 122s (weekend cruiser) http://forums.turbobricks.com/showthread.php?t=308197
67' 122s (Rallyx racer)
82' 242 dl
83' 242 glt (v8 turbo swap project)
sspony is offline   Reply With Quote
Old 08-14-2019, 03:17 PM   #104
R32RennSport
Outlaw Amazonian
I deleted the choke circuits. I live in central California where the ambient temp rarely is under 70 degrees and even a cold morning might be in the high 50's/low 60's. Never really saw a need for them on the last 5 classics I've owned, especially on this engine with a non cross flow head there should be plenty of heat to keep things happy.
Old 08-15-2019, 09:51 AM   #105
sspony
sspony's Avatar
Bummer... still trying to get the choke cables sorted on mine haha.
Old 08-19-2019, 03:41 PM   #106
R32RennSport
Outlaw Amazonian
Making a few more steps this past weekend. For you DCOE wizards please ad some input over in the performance and mod forum, I've posted my full specs over there. Got the baseplate cut out as well as final sorting of the linkage, man does the gas pedal feel amazing!!! Also sorted out my mechanical timing (forgot to install the distributor drive gear when I was building the engine). Mechanically I'm just about ready for fire in the hole, electrically I still have to sort out the charging, ignition and starter wiring. I don't have any experience with the 123 distributor so I may just break in with my old Bosch unit with the Petronix.
Old 08-21-2019, 02:03 PM   #107
R32RennSport
Outlaw Amazonian
Oil changes are going to be a mother... Definitely going to look into doing a remote oil filter/cooler. In retrospec I wish I had fronted the money for a nice ceramic coated 4-2-1 header. I know I'm going to regret this installation in the future. I give the welds less then a year before they crack, quality on this header was less then ideal.
Old 08-27-2019, 01:14 PM   #108
R32RennSport
Outlaw Amazonian
Fabricated an adjustable support rod and brackets last night that attach to the engine mount bracket and run through cylinders 1 and 2 primary tubes up to the air filter base plate. Today I'll fabricate a backing plate to sandwich the upper bracket and base plate that will tie into the inner carb air horn studs for rigidity as the barb base plate is fairly thin aluminum. Similar to the VCS unit but with the added ability to adjust length as needed. The support assembly is isolated by means of split rubber bushings.
Old 08-28-2019, 08:54 AM   #109
sspony
sspony's Avatar
Looks great!
Old 08-28-2019, 01:11 PM   #110
R32RennSport
Outlaw Amazonian
Looks great!
Thanks! The carbs and brace are in as of last night. The fuel system is also dialed in. That leaves me with finalizing the throttle cable, adding fluids and wrapping up charging/ignition system wiring. Maybe 15 more hours to fire in the hole!
Old 09-05-2019, 07:44 PM   #111
R32RennSport
Outlaw Amazonian
Well it's been a pretty rough past week for me. On Friday the transmission in my wife's Tahoe grenaded at 199K so I spend my Saturday morning pulling that out, luckily it's 2WD. My local rebuilder had it turned around in 48 hours so I spent Tuesday night installing it and all is well less my bank account.
On top of that I spent my labor day weekend getting the Volvo engine ready for break in on Monday. I was getting pretty excited until... As I started to do the initial coolant fill I noticed as I was finishing and getting ready to add the oil that I was getting a small puddle on the ground. At first I thought that it was coming from the water pump area and running back. The closer I looked I saw coolant seeping from all around the head gasket. Obviously, I found this pretty unusual even for my first engine build. So I checked the torque on the cylinder head just to make sure and all seemed well there. Pulled the plugs, sure enough, coolant puddling on top of all the pistons, pulled the oil pan drain plug, out came a quart of coolant. UGH. So I drained the radiator and attempted to drain the block but the previous gorilla tightened that so much that the head exploded so I vacuumed out the rest from the thermostat tube.
Long story short after asking advice from friends and online a friend theorized I was getting a false torque reading at the head bolts because they had bottomed out. Sure enough the aftermarket ARP bolts were 2mm longer then the stock head bolts on an already cut down low compression head. So apart came the engine, I dried up everything, and oiled everything back up. Just waiting on an ARP stud conversion from Planetman. I'm going to reuse the head gasket because it was never compressed and after much thought I'm going to avoid an MLS gasket for the time being as my block surface isn't really up to MLS standards. To be continued later this week...
Old 09-06-2019, 10:57 AM   #112
sspony
sspony's Avatar
Glad you found this before trying to start it.
Old 09-06-2019, 12:23 PM   #113
6thousandths
Good catch on the longer bolts, Ive had this same issue before on a different car and learned the hard way.
Car is looking good!
6thousandths is offline   Reply With Quote
Old 09-10-2019, 04:09 PM   #114
cwdodson88
I never saw how big of a bore you went with... I have a 92mm .036 cometic if you feel like you need it.
The Build Thread
SVEA - PUSHROD TURBO!
Old 09-10-2019, 05:17 PM   #115
R32RennSport
Outlaw Amazonian
Thanks for the offer. I ended up rolling the dice and reusing my gasket as it was never cinched down, just soaked in some coolant. I cleaned it up and gave it a copper coat. I'll find out tonight or tomorrow when I refill the system if I lost that bet or not With the ARP stud kit I could safely add more torque so I feel like I have a fighting change. I decided to not go MLS gasket because the block side had enough imperfections that I felt a non coated gasket would be kinda risky.
Old 09-16-2019, 03:43 PM   #116
R32RennSport
Outlaw Amazonian
Welp boys... ITS ALIVE!!!
I haven't posted progress this week because I'm busting my butt for the VCOA national meet next Saturday. Car is still less interior, which is the plan for this week. The good news though is it runs and it runs well. A huge shout out to CAMERON LOVRE, he helped walk me through a few of the finer points over the weekend, always willing to help out an enthusiast on his days off, a real stand up guy in our community!
Break in went fairly well, ended up doing two 10 minute run in sessions. Started to get a little warm on the first run from coolant burping and it was running a little lean, lots of popping. Topped up coolant and fixed a blocked idle circuit, some minor mixture and timing adjustments and it purrs at idle and barks at WOT, very happy with no leaks! Baseline settings as of now are 12 degrees advance at idle, 38mm chokes, 150 mains, 200 airs, 60 idles, valve lash set to .016 per camshaft manufacturer recommendations.
Old 09-16-2019, 05:33 PM   #117
doucheNozzle
doucheNozzle's Avatar
Um, video?!
'93 944 T - #TrophyVo
'00 XC70 SE - Slow
'04 V70 T5A - Feels Fast
Old 09-16-2019, 05:42 PM   #118
R32RennSport
Outlaw Amazonian
Originally Posted by doucheNozzle View Post
Um, video?!
I'll take a better one and post it soon. The one from the first run yesterday had the carbs popping and lots of background noise as I was running cooling fans in a fairly confined space. When I cleaned it up the second time I forgot to film.
Don't worry, lot's of content will be coming in the next week.
Old 09-16-2019, 11:01 PM   #119
matt b
Congrats! It's a big milestone and I'm glad you're using the VCOA meet as a deadline to have a show worthy car.
Keep the updates coming!
Old 09-16-2019, 11:05 PM   #120
R32RennSport
Outlaw Amazonian
Thanks Matt! I'm trying my best. The only unfortunate detail that wont be done is the interior, my upholstery guy isn't available until next month and I missed my appointment last week because of the head gasket debacle. Mechanically its good to go pending my first road test tomorrow!
Here's the music...
https://youtu.be/btL9mVxaVIg
Old 09-17-2019, 09:44 AM   #121
Tfrasca
Tfrasca's Avatar
It's hard to beat the sound and response of side drafts.
Old 09-17-2019, 11:18 AM   #122
Vol242vo
Keep it clean...
Vol242vo's Avatar
+1 sounds like a strong runner, well worth the wait and beautifully executed!
Derek
1980 242
-Project Thread-
Follow on IG: @vol242vo
Old 09-17-2019, 12:14 PM   #123
R32RennSport
Outlaw Amazonian
Right???
Old 09-17-2019, 12:15 PM   #124
R32RennSport
Outlaw Amazonian
Thank you! Definitely worth the patience and effort!
Old 09-17-2019, 12:38 PM   #125
Toybox
mostly lurking
Toybox's Avatar
Ah yes, nothing like last minute panic, eh? A motivator for many of us.
But even with all the challenges, I must say the whole car looks great. I'll bet it will be a lot of fun. Very good catch on the head bolts. Glad it was out of kilter far enough to show leakage before you ran it -- imagine trying to diagnose if it had only been 0.001 loose.
I love the silver highlight. Reminds me of the types of details I've done, for no other reason than to encourage a smile. I can appreciate an absolutely concurs car that looks like it rolled off the factory line yesterday, and I can respect a guy's right to customize to the Nth degree, but in the middle ground between those extremes holds a lot of magic. A car that looks almost stock except that every bolt head under the hood is polished or painted a contrasting color, that sort of thing. Stuff that an assembly line would never have done.
Nice work.
