Old 07-21-2019, 06:50 PM   #126
didenpx
didenpx's Avatar
Originally Posted by sksmith View Post
Good luck!!
Steve
+1 Glad to see you're going to give it another chance at life!
My feedback: http://forums.turbobricks.com/showth...hlight=didenpx
1970 1800E (Project Roedluvan:http://forums.turbobricks.com/showth...highlight=1970)
1977 242DL "Senf" (Summer Cruiser)
2x1973 1800 ES (Project Reanimator; disassembly and parts detailing to begin Winter 2020)
didenpx is offline   Reply With Quote
Old 07-22-2019, 07:54 PM   #127
vwbusman66
Stößelstange über alles!
vwbusman66's Avatar
I'm putting this list here for my own records as well as a reference for the **** that needs to be done in the next three weeks
T5 Swap: shortened driveshaft, trans tunnel install/tweaking, speedo cable?
Gaskets: Rear main seal, oil pan gasket
Fuel: fuel filter, fuel line bungs front and rear, carbs rebuilt, air filter installed
Water: E-fan installed, thermostat installed, efan wiring designed and installed with saab coolant T, new heater lines, fresh coolant, new lower rad hose
Lube: Oil change, wheel bearings re-packed, diff lube flushed, T5 filled
Electrical: crescent lights re-wired, Hella 500's installed and wired to headlights, head unit installed, tachometer wired and installed, speedometer cluster tightened
Exhaust: finish side pipe and re-hang system
Brakes: verify rear brakes operational, re-bleed, re-plumb vacuum lines with check valve
1971 142 beater/fake racecar
1972 145 sh*t hauler
Originally Posted by propav8r
The incest is implied.
Old 07-23-2019, 10:57 PM   #128
vwbusman66
vwbusman66's Avatar
Engine came out. After getting it off the mounts and everything disconnected, I realized that I needed to remove the shifter. A quick google search revealed that the large hex shape is a big-ass nut that holds the shifter.
Now to restrain myself from putting my b230f in it
My awesome brother (vwbusman69) running the hoist while I swear and pull.
Now to find a powerwasher
Old 07-24-2019, 08:22 PM   #129
didenpx
didenpx's Avatar
Now that looks serious!
Old 07-24-2019, 08:39 PM   #130
vwbusman66
vwbusman66's Avatar
Especially the socket on the floor and the coolant dumped everywhere.
Old 07-25-2019, 02:48 PM   #131
stick70
All the gauges
stick70's Avatar
I missed that too the first time, it's deceptively easy.
Old 07-27-2019, 09:56 PM   #132
vwbusman66
vwbusman66's Avatar
SOOO
I pulled the oil pan to replace the gasket and clean it and discovered this:
I pulled all the rod caps and all the main caps. The bearings don't look bad, they just dont look stellar. The thrusts are showing copper, and there is very minor imperfections on the crank and bearings that can be picked up with a fingernail.
So yeah. I have 3 weeks to either finish the b230f swap crack pipe dream, or find another, better B20.
Old 07-27-2019, 10:03 PM   #133
sksmith
sksmith's Avatar
That sucks!
Good luck finding a running B20 in the next 3 weeks. I doubt you can pull of the OHC swap & be sorted that quickly, but good luck with that as well!!!
You don't know any machine shops in your area that can get you in & out?
If so, bearings from IPD are on sale, take about 3 days to get. Pistons from VP, if they're in stock, would be to you in 2 days tops.
If you find a 74 or 75 8-bolt B20, I have a brand new set of STD pistons sitting in my shop. We could discuss pricing, but it would be cheaper than from a vendor.
Steve
Old 07-28-2019, 02:36 AM   #134
John242Ti
LH-Jet & Carb Free Zone
John242Ti's Avatar
Looks like fun.
I can see why you want 240 JAH's B20. Try to get the whole thing, since you might as well convert it over to FI, that way the car is ready for when you decide to install a B230F or FT underhood. Might even make life easy if you decide to grab the B21FT from the guy in NJ and rebuild that for the 142.
@1982_volvo_242_turbo on IG
Old 07-28-2019, 03:09 AM   #135
mocambique-amazone
Don't try to swap the B230F upright.
If you prefer to +T this it's obligated.
Complicate too
I won't remember why the B20 has to go.
If the only problem is the carb and ignition site , I prefer to LH2.4 a B20. Runs pretty well with LH2.4 :-)
Good luck, Kay
("New" and used B20 in stock for good luck, B230 too)
Old 07-29-2019, 12:47 AM   #136
Hootbot
Hootbot's Avatar
If the engine wasn't making noise and had good oil pressure before I would just fire in a fresh set of bearings and call it good.
-10000 on what everyone is saying about SUs though, I've driven my 144 off and on for 10 years and I've NEVER gotten those damn things to idle worth a ****. Pure garbage.
Hootbot is offline   Reply With Quote
Old 07-29-2019, 08:58 AM   #137
stick70
All the gauges
stick70's Avatar
I had good luck for a while with mine after I got the throttle shafts re-bushed. The problem with them is you need to **** with them all the time. You just do.
Old 07-29-2019, 11:21 AM   #138
JohnMc
JohnMc's Avatar
Yeah, I always had to do 'seasonal' fiddling with the SU's. Whenever the idle got too uneven, I'd just pull out the UNISYN and balance the airflow F&R, then twiddle around with the mixtures and lift pins. Then reset the idle speed. more of an art than a science, but eventually I got pretty good at it.
Then I stuck on DCOE's and haven't needed to do much to them at all for a decade or so.
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 07-29-2019, 08:36 PM   #139
Hootbot
Hootbot's Avatar
Mine are HIF so the throttle shafts should be ok and they don't seem to leak. If you tune them up they're fine for a few days.
Old 07-31-2019, 09:21 PM   #140
vwbusman66
vwbusman66's Avatar
Bottom end is torqued and back together. New HD oil pump, updated RMS, thoroughly lubed the mains and rods, and pseudo-primed the oil pump.
Friday will be oil pan re-install and torque, flywheel install, PP and clutch alignment, and final install of the B230FT bellhousing for the T5. Driveline guy is charging me $425 to shorted the driveshaft, put new U joints in, add a mustang slip yoke, and balance the whole thing.
I ordered a 10" Efan (750cfm), a 2.5" bosh tach, and a relay (for the fan) from Summit so I can wire it up to work with the Saab 900 coolant T.
Old 07-31-2019, 10:36 PM   #141
Cwazywazy
Single jingle
Cwazywazy's Avatar
Are you using the efan with the mech fan? I doubt a 10" on its own will be enough, even for NA.
I don't know what I have
Old 07-31-2019, 10:39 PM   #142
vwbusman66
vwbusman66's Avatar
Just Efan. The thing runs pretty cool as is, just starts to boil when I'm in heavy traffic at 95 degrees. We shall see.
Old 07-31-2019, 10:41 PM   #143
Vol242vo
Keep it clean...
Vol242vo's Avatar
Looking good. Keep plugging away on it, one thing at a time!
Derek
1980 242
-Project Thread-
Follow on IG: @vol242vo
Old 08-01-2019, 11:42 AM   #144
stick70
All the gauges
stick70's Avatar
New slip yoke? That's what I would expect for that price.
Old 08-01-2019, 11:47 AM   #145
JohnMc
JohnMc's Avatar
I <3 the driveshaft shop I use. I think it was around $300 + tax for a whole new shaft, trans to rear axle. Once years ago fo the T5 swap, and recently for the CD009 swap.
However, that was a one piece. New slip yoke, 1350, shaft, 1350, Volvo compatible flange.
Old 08-01-2019, 11:54 AM   #146
stick70
All the gauges
stick70's Avatar
iirc that's what mine ran for the wagon for a 1 piece
Old 08-01-2019, 12:30 PM   #147
Tfrasca
Tfrasca's Avatar
$425 seems steep, but what can you do? It's been a couple years, but I think I paid around $300 for a new, shorter front section, new slip yoke, and all new U-joints. And that's in California.
Old 08-02-2019, 10:21 PM   #148
vwbusman66
vwbusman66's Avatar
Rebuilt the carbs tonight. Believe it or not, the one pictured below was the one that didn't have a clogged jet. The rear carb (no fuel/clogged) didn't look as bad inside. I suppose the front was catching all the filth from the tank. I guess I need a fuel filter
Old 08-04-2019, 09:48 PM   #149
vwbusman66
vwbusman66's Avatar
Engine is in. Trans will go in tomorrow.
Cool ass stamping I never noticed before today.
Old 08-05-2019, 08:48 PM   #150
vwbusman66
vwbusman66's Avatar
Trans is in. Need to do final fab on the crossmember and new larger tunnel.
