impolvo
Is always busy
- Feb 23, 2006
- Chapel Hill NC
D24t + Aftermarket intercooler No boost controller just a steel rod in the pressurized line to the internal wastegate
So I was running 20 something lbs no problems
Never really went that hi normally 16 maybe
I noticed my output was declining and the sound of the whoosh changed
Leak can be heard
I went through all my piping and found some small leaks fixed them
Tightened all the T clamps a little bit
But still can?t find where the main leak is
I guess I need something I can clamp onto the intake and pressurize with my air compressor to find where the leak is
Even though the diesel will Build boost in neutral there?s too much wind and noise from other thingsTo efficiently find said leak
If anyone has any tools made for this please let me know
The car is still drivable no problem
The leak doesn?t start till around five psi
And I can still get up to 10 pounds if I am flogging it
No go ahead and criticize away just if you can toss in some helpful information
I?ve had leaks before But they were normally more like blowouts
Leak can be heard
