Old 10-22-2019, 02:13 PM   #1
Deacon07
Default Project GoodSpeed
Hello,
This is my first time with all of this stuff and wanted to get a running record of how things are progressing and maybe get a little help from the all knowing here. To start. I'm Dan and this is my $1,000 Volvo 240DL Wagon. Not sure if it should be called anything differently, please don't beat me up too badly.
It runs and drives pretty well actually. The rear fender where the spare tire sits is rusted out pretty bad, interior is turning to dust, suspension is...not good, brakes a spongy, and the only things that actually work are the brake lights, speedo, temp gauge, and sometimes the heater motor.
Deacon07 is offline   Reply With Quote
Old 10-22-2019, 06:36 PM   #2
brickcupra
Default project GD
Welcome to the TBS, You/'ll get plenty of help here and no killing allowed !!!!
Any questions i am available take care
DZ
brickcupra is offline   Reply With Quote
Old 10-22-2019, 08:31 PM   #3
Vol242vo
Keep it clean...
Vol242vo's Avatar
Welcome. Lots of resources here, looks like someone chopped the springs up front. A good bath, cut and wax will result in pretty good paint results, I’m sure.
Derek
1980 242
-Project Thread-
Follow on IG: @vol242vo
Old 10-23-2019, 06:57 AM   #4
rms
rms's Avatar
Nice patina on your wagon! It's going to be a neat project!
-Ryan
rms is online now   Reply With Quote
Old 10-23-2019, 09:44 AM   #5
Deacon07
Thanks guys. I did do a test spot with some 3 step meguiars(sp) I had laying around and the paint looked pretty good. There are some other rust spots that worry me a little. Especially around the windshield area where the weatherstripping is all jacked up. I'm hoping it can just be cleaned up and put in a new piece of rubber.
I worked on the turn signals, headlights and wipers last night. I got the signals working. I think the actual contacts in the stalk was corroded. So, tore that apart and cleaned it up. Seemed to work well once I got it back together. Similar situation with the headlight switch, but, I broke that. I think the back cover is porcelain and I....wasn't gentle with it. Wipers, I'm not 100% on. I cleaned all the contacts on the stalk and it tried to move for a second then just gave up. Next move is to pull the wiper motor and clean it up see if I can get it rolling. No sign of anything from the tailgate motor, but that's for another day. Also, seemed to have ground issues from the stalk mounting to the actual steering column so I might get into cleaning that as well. Once i get those things functioning and I don't take a flamethrower to the door open/seat belt buzzer thing, I'll move on to getting the taillights all up and running. I'll share pics of the interior tonight if I remember. I will warn you. It's pretty bad.
As far as the springs go. You think it's sitting further down than just sag? I haven't looked at it yet, but i suppose that would better explain the ride home. Should I be worried about the cut springs?
Old 10-23-2019, 12:24 PM   #6
Vol242vo
Keep it clean...
Vol242vo's Avatar
Cutting springs is extremely common and really just fine, you may need new struts if the ride is bouncy, that’s an indication that the rebound is gone. Pretty inexpensive and simple job.
Old 10-27-2019, 04:36 PM   #7
Deacon07
A few more pics after a little "cleanup" over the weekend.
Old 10-27-2019, 05:07 PM   #8
DD Ranch
DD Ranch's Avatar
What a difference on that paint!
Paint the wheels and it'll look quite respectable! From the outside at least
I like that color - I've had two green ones.
Florida Chapter VCOA
DD Ranch is offline   Reply With Quote
Old 10-27-2019, 05:54 PM   #9
Deacon07
Haha, yeah, the interior is.... rough....
After seeing the one black rim, I think that's the color of wheels I'd like to go with. Whenever that time comes.
Old 10-27-2019, 08:39 PM   #10
Deacon07
Weekend progress update is. I got all of the exterior lights work and the main wiper motor working. Added an extra ground as suggested from all of the searches.
Pulled the passenger door card cleaned it up as best I could. It's super faded. Glued most of the plastic back together. Just waiting on a door handle and package tray thing to put back on. Then that door will be done. I'm missing the door lever plastic cover and I cant find them online anywhere....
Old 10-29-2019, 03:06 AM   #11
Scaramanga
Nice job with that paint! Keep up the good work
Volvo 142 1968, 145 1972, 245 GLT 1991
Scaramanga is offline   Reply With Quote
Old 10-30-2019, 11:50 AM   #12
BillyMaysHere
BillyMaysHere's Avatar
For small plastic bits post in the wanted section. For interior restoration this paint is a match to the stock interior color SEM Products 15173 Camel Color... https://www.amazon.com/dp/B00PH6MOYW...p_mob_ap_share
Old 11-03-2019, 02:50 PM   #13
Deacon07
Thanks for the heads up. I ordered the paint suggested.
Weekend update: pulled the seats to clean underneath and put cheap seat covers on. Made $1.45 to go toward the build so that's a win. Got the dash back together as best I could. Ended up ordering 2 different column covers. Apparently there are different sizes. Whoops. Still need to figure out why the fuel gauge doesn't work.
Previous owner was clearly a smoker that couldn't find the ashtray often.
The e-brake was broken so I replaced that as well. Pulled the rear panels to install a new fuel pump and I'm not excited about that project. Tight spaces and all.
Is there a carpet match replacement for the rear floor panels?
Old 11-03-2019, 05:44 PM   #14
Vol242vo
Keep it clean...
Vol242vo's Avatar
You should PM 77volvo245....he may have a one piece replacement for a reasonable price...
Old 11-03-2019, 06:01 PM   #15
DD Ranch
DD Ranch's Avatar
Main cabin carpet or cargo area?
In any case, I've had very good results dying the carpet with Duplicolor Fabric Paint.
No, it's not an exact match, but it's a sight better than what I had and the color works well.
Remove the carpets, wash/scrub and dry, paint and re-install - of course, after inspecting floor, cleaning out the sills, handling any problems and adding sound insulation while the carpets are out!
Old 11-03-2019, 08:21 PM   #16
Deacon07
Cargo area. I would dye it, but there's really nothing left of it. The more I take apart the more it turns to dust.
Old 11-04-2019, 05:12 PM   #17
DD Ranch
DD Ranch's Avatar
Old 11-04-2019, 09:19 PM   #18
Deacon07
Originally Posted by DD Ranch View Post
Well, now I know what my plan is!
Old 11-04-2019, 09:21 PM   #19
Hank Scorpio
Chubfest 2009 Survivor
Hank Scorpio's Avatar
Those metal strips are the same ones used to fasten the wood bed in my C10.
https://www.summitracing.com/parts/m...saAlnzEALw_wcB
Old 11-05-2019, 08:28 PM   #20
Cool green wagon project! Try painting the wheels silver. Silver goes really well with green.
1982 242 turbo. 340k miles. MVP coilovers and 3" exhaust. Flowed 405 with a V15. Cossie turbine housing with upgraded compressor housing. 90+, IPD remote oil filter. Some other goodness, too. Been lots of fun over 25 years. Restored in 2k. Now ready for a 2nd restoration.
Old 02-20-2020, 11:15 AM   #21
Deacon07
Well, I realize it's been a while, but I've basically just been parts collecting for the swap. Below is a spreadsheet of what I've picked up so far and the actual cost. I'm sure there are better deals to be had, but this is what I've come up with. I can probably provide part number data too if that's something you guys would like to see. I had some issues with the 5.3 block. The middle cam bearing was spun so I had to install new cam bearings. Let me know if you have any questions. I hope to get started pulling the motor this weekend and will hopefully be able to provide pictures of how that is progressing. I'm sure I'll have to add more to the costs, but thought I'd throw in an update for you guys to let me know how it's going.
I included the 6.0 motor build as well, so I may remove those since it will be for a future build to go in Skylark I'm trying to source.
Build Costs
Items Cost
2 bar map sensor $16.99 Ordered Wrong One
2.5" FMIC Piping $82.99
2.5" Mandrel Pipe Kit $106.00
2.5" x 4 Flex Pipe $11.99
3 Bar MAP Sensor $43.00 MAP Sensor adapter not required if ordering EFI Source MAP Sensor
3" Mandrel Pipe Kit $165.88
4L80E Line Fitting - Radiator $11.84
4L80E Line Fitting - Trans $4.84
4L80E Line Fitting - Trans $11.69
4wd 4l80e -$300.00
5.3 Cam Bearings $26.15
6.0 .02 Piston Rings $42.99
6.0 Block Work $836.51
6.0 Cam Bearings $33.22
6.0 Pistons $189.99
6.0 Rod & Main Bearing Kit $55.94
6.0 Rod Bearings $23.99
60mm Wastegate $66.88
Tap & Die Set $143.50
8.8 Short Axle Shaft $121.72
Boost Cutout $84.96 Returned
Cam Bearing Tool $133.74
camshaft $249.99
Car $1,000.00
change found under seats -$1.45
circuit tester $69.99
Creeper $52.98
decapped injectors $140.00
Dipstick & Tube $35.96
Exhaust Gaskets $18.76
exhaust and dust cover bolts $31.00
Front Grille & Console $130.00
Fuel Lines & Fittings $168.17
fuel pump & fuses $114.98
Fuel Pump Lock Ring $18.57
Headlight Switch $17.77
Headlight Switch Bezel $38.00
Holley EFI $1,199.95
Intercooler $76.45
4L80E Shifter $144.11
Interior Paint $21.78
JB Weld $6.99
Liftgate Arms $31.70
LS Motor $500.00
LS Truck Manifold Flanges $29.99
8.8 to 1350 Flange Yoke Adapter $38.51
Marker Light Bulbs $50.32
Motor Mounts $446.00
Oil Pan $264.71
6.0 Dowel Pins $14.99
pac 1218 springs $152.94
Passenger Arm Rest $25.98
No Baby on Board Sticker $6.99
Power Steering Pump & Bracket $49.99
radiator $283.45
rearend $200.00
Registration $247.00
Sandblast Cabinet $403.05
Shipping $538.00
Steering Column Cover $37.60
Switch Light Bulbs $10.98
T4 Flange to 2.5" Pipe Adapter $48.10
taillight & seat cover $81.65
Thermostat $13.99
Timing cover Gasket $24.99
torque converter $500.00
TransGo HD2 $133.21 Better kits available
Transmission $300.00
transmission dipstick $73.00 questionable
exhaust manifold lock washers $13.00
an wrench $25.00
Transmission Pan/Filter/Gasket $49.51
(2) 3 x 12 c channel $15.00
bellhousing bolts $10.00
turbo $399.99
Valve Spring Compressor $34.99
Wire Loom $15.98
Total $10,519.42
Old 02-20-2020, 12:35 PM   #22
Mick13
Build Costs
Items Cost
Mick13 is offline   Reply With Quote
Old 03-31-2020, 11:01 PM   #23
Deacon07
Gonna post some pictures later, but excited to say that it fired up tonight. There might be major issues, but for the initial startup it ran well. Still need to work on the rear and get a driveshaft in, but getting there.
Old 04-08-2020, 11:47 AM   #24
Deacon07
Picture Updates.
1. Homemade Powdercoat Oven
2. VS Racing 7876 Turbo
3. Powdercoated Engine/Trans/Rear Mounting Hardware from Giffin
4. Driven into the garage.....
5. Engine pulled - I got bored and got it out in an evening
6. LS Mocked up for the first time
7. Figuring out piping for the turbo
8. Piping for the crossover - Had to "adjust" the driver's side a bit
9. When cleaning the crossmember the breather tube on the power steering let a bunch of junk in there and started leaking out the seals. So I decided to rebuild it. Got the wrong parts from RockAuto so just cleaned it and put it back together instead. Hope it holds. Showing how it all comes apart if anyone needs that info. The LS power steering pump hooked right up to the hoses, but I haven't tested it's usefulness yet.
10. Flipped manifolds meant that the stock plug wires wouldn't work. Found out from sloppymechanics that short nascar takeoffs on ebay loop around perfectly.
11. In for good with the 4L80E - Sits pretty low. I used the HD2 kit, but there are better options out there. Ordered a Jakes TC
12. Coolant hoses and fans run
13. 8.8 Rear cut and welded back together. Waiting on adjustable torque rods and fittings to build an adjustable panhard bar.
14. 3D printed Gauge Pod covers - Top just printed, middle sanded/primered, bottom is original cover.
15. Hood Fits with the 145 amp alternator
A few things - Because of the way I did it, I had to cut the tunnel on each side to fit trans lines and shifter linkage. If I got a different shifter, I probably wouldn't have needed to do that, but I should be able to just weld a bump on each side to cover that up. I used the Holley Terminator kit. Everything just plugged right in, but you do need the usb cable if you're going turbo. I also ordered a dakota digital pack to be able to use the stock tach, and speedo. Adding a few fittings to get the temp gauge to work. Had a friend weld on fittings to a new fuel sending unit to hook up AN lines.
Running the Intercooler lines was difficult because the alternator/idler pulley was in the way. I will try to get a pic of that later.
Not sure what else to provide. It fired up on the first crank of the starter. It was amazing, but I'm still working on getting the rear installed and a driveshafte made.
Old 04-08-2020, 11:47 AM   #25
Deacon07
- video of it running, but I doubt the link works
