Old 03-06-2017, 09:30 PM   #151
boxtoy
Anyone know the size and thread pitch of the sway bar link bottom bolt for the steel, not aluminum, control arm
boxtoy is offline   Reply With Quote
Old 03-18-2017, 03:20 PM   #152
Bricktothefuture
Looking for the specs on the bolts that hold 240 fenders to inner fender, front clip, etc - Looks like a coarse M6 flange bolt but haven't been able to find an exact match anywhere.
Bricktothefuture is offline   Reply With Quote
Old 03-23-2018, 07:38 PM   #153
yankee
yankee's Avatar
Default Well nut size for 240 roof rack
What is the Well nut size for 240 roof rack.. Thanks
The Fleet
1978 242 GT In Progress
1980 242 GT My son's ride
1984 242 TIC My ride
1985 245 TIC My ride
1994 940 N/A My DD
1994 940 N/A Surf Wagon SOLD
1995 940 Low boost Turbo (In Progress)
1968 122 Wagon (In Progress)
yankee is offline   Reply With Quote
Old 05-18-2018, 11:37 AM   #154
minusdarkslide
Motor mount thread specs? It was incomplete on the first page and nowhere in the post.
minusdarkslide is offline   Reply With Quote
Old 06-02-2018, 06:02 PM   #155
durk80
durk80's Avatar
Upper motor mount housing bolts which bolt to the block are 12mm head with M8 X 1.25 -these are the same size and length as the ball joint to strut housings bolts in a 240. The lower motor mounts are 17 mm. Sorry, I do not know the thread pitch for those.
durk80 is offline   Reply With Quote
Old 08-25-2018, 12:47 AM   #156
PeaceEngineered
Sarcastic Optimist
PeaceEngineered's Avatar
This thread is screwed (sux).
2013 Audi Q5
Sold- 2006 V70R
Old 12-09-2018, 06:00 PM   #157
durk80
durk80's Avatar
From a 91' 240--
The two Ignition lock cylinder bolts are M8-1.25 X 30mm (If you don't care about security)
Belly pan flange bolts: M6-1.0x 20mm. 1/4" washers will work in a pinch.
Old 01-17-2019, 02:12 AM   #158
Overkiller
Does anyone know the size of the distributor hold down bolt for a 240? I fumbled mine into the abyss.
Overkiller is offline   Reply With Quote
Old 01-17-2019, 11:48 PM   #159
It's M8-1.25 x 22mm grade 8.8. It's the same bolt as the ones used to hold the oil pump to the block.
Old 01-20-2019, 03:47 PM   #160
JW240
All idiot, no savant
JW240's Avatar
Automotive OCD alert.
Have been replacing some vacuum hose on 240/740/850/940.
Fpr has 5mm port
Evap canister ports on redblock throttle body has 4mm and 8mm diameter hoses.
850 uses plenty of 5mm vacuum hose too. Fpr, hose to boost gauge. Forgot the size I used for the turbo stuff, iirc the fittings are 6mm. Replaced those years and years ago and the original stuff was already in very ugly condition (2010?).
For OEM look and feel, Gates fuel hose with fabric braided cover works excellent. DIN 73379 typ B to be exact, the stuff found on carbs and diesel injection as leak line - I used half a millimeter smaller internal diameter for a snug fit. And to complete this little job some ABA 'mini W1' or 'mini W4' hose clamps are a nice finishing touch.
The flashy silicone stuff attracts rodents and one small tear and they rip in two. This stuff is much stronger and doesn't look out of place. Just my 0.02 € for what has proven to work for me.
240 | 1991 | 333K Km | B230F+T | Cosworth T3 60/63 | M90 | TrueTrack
Husaberg FE450 '12 mx/supermoto swapped
