Old 03-01-2014, 01:54 AM   #1
hunterkent
hunterkent's Avatar
Question 940 in-radiator temperature switch
so i have the factory electric fan in my 1991 940 removed and replaced with an after-market electric fan. it is hooked up to the factory wiring and i just connected the 2 wires that hook to the sensor in the radiator to each other so the fan always runs when the car is running.
My question is, do they make a sensor that kicks in at a lower temp? say around 180 degrees so that the fan doesn't run constantly ? i think it is set up to be an overheat fan and I think it will let it get to hot before the fan turns on.
R.I.P TrickMick 1946-2014.
hunterkent is offline   Reply With Quote
Old 03-01-2014, 01:58 AM   #2
Kjets On a Plane
Devoid of Luxury
Kjets On a Plane's Avatar
How PSI a stock can support?
Always Be Crushing!
Old 03-01-2014, 02:00 AM   #3
hunterkent
hunterkent's Avatar
im pretty sure my sensor screw into the radiator ? maybe not..so the cars with regina had a lower temperature sender ?
Old 03-01-2014, 02:00 AM   #4
hunterkent
hunterkent's Avatar
cause i have no clutch fan at all so i need it to kick in around operating temp
Old 03-01-2014, 09:49 PM   #5
hunterkent
hunterkent's Avatar
anyone?
Old 03-02-2014, 10:49 AM   #6
miguel.760ti
miguel.760ti's Avatar
http://www.fcpeuro.com/products/audi...h-251959481kmy
If your radiator has a threaded switch that one will work, otherwise you'll have to get one of those ****ty temp probe controllers or a coolant tee fitting from a later 80s saab 900 and use this switch in that fitting.
1988 760 Turbo - garage queen, everlasting project
also
2016 Ford Fiesta ST - size small daily
1995 Ford F150 - size large daily
miguel.760ti is offline   Reply With Quote
Old 03-02-2014, 01:01 PM   #7
Kjets On a Plane
Devoid of Luxury
Old 03-02-2014, 02:43 PM   #8
hunterkent
hunterkent's Avatar
ok i guess mine does push in...so there actually is a lower temperature rating sender i can press in there so the fan wont kick on till the cars is warm ?
Old 03-02-2014, 02:47 PM   #9
Kjets On a Plane
Devoid of Luxury
Old 03-02-2014, 02:49 PM   #10
hunterkent
hunterkent's Avatar
bitchin. i will grab one, idk why but i would really prefer that my fan only runs when it actually needs to.
Old 03-02-2014, 03:05 PM   #11
Kjets On a Plane
Devoid of Luxury
Old 07-05-2018, 09:05 PM   #12
iHateVolvoPeople
Correct. The regina e-fan cars use a temp switch in the radiator 1992+. I have one such sensor I bought new. I think it is a push-in type that pushes in that rubber bushing thing that is on the OE plastic radiators.
I'd guess 2manyturbos has a regina parts car, but whether he has a plug to plug the hole that removing that sensor from an otherwise perfectly good PITA to find when you need it e-fan radiator, I don't know, and that might kill the deal.
So to clarify, a Regina e-fan car (93 940) has the fan kicked on by an external switch in the radiator, but not the Regina ecu?
Feedback Thread
Current:
93' 244T m47
93' 245 m47
90' 744 AW70
94' M-Edition Miata, 93k
95' Camry auto, 246k
93' Camry auto, 278k
Past:
80' 242gt m46
88' 245T m47
92' 940 turbo AW71
94' 945T AW71(L?)
Old 07-07-2018, 01:16 PM   #13
iHateVolvoPeople
Upon further inspection of or 93 940 regina, it seems that the high speed (white/black) is only turned on by the push in temp switch in the radiator. Almost seems like an overheating switch to me because it’s nearly 220F.
Additionally, the low speed (blue/black) seems to be only triggered by the 'low pressure sensor' located in the ac condenser. So the fan will actually only come on low speed with the ac on after the compressor has run for a minute or so and built pressure. It will remain off on the highway.
I will need to look closer to see if Regina has anything to do with the fans or if it is only the external switches.
Old 07-07-2018, 02:29 PM   #14
bobxyz
bobxyz's Avatar
See page 1 of the '93 940 diagrams here: http://www.volvowiringdiagrams.com/?...ing%20Diagrams
The dashed box is LH2.4 only.
Old 07-07-2018, 02:31 PM   #15
oldnfast
I was wondering this same thing with my new to me 92 with regina,please follow up with what you find.thanks
oldnfast is offline   Reply With Quote
Old 07-07-2018, 03:12 PM   #16
iHateVolvoPeople
As posted above, and according to the wiring diagram, I believe all (both) speeds are controlled externally. The low speed (blue/black) is controlled only by the pressure switch in the radiator. So low speed will never come on without the ac on. Then high speed (black/white) is controlled by the temp switch in the passenger side of the rad. It comes on around maybe 216-220F. Far too high IMO so I’m adding a manual override switch to the low speed. I do not think they make a lower temp switch in the rad but I haven’t looked too hard.
@bobxyz I have already been studying the wiring diagram but they put Regina and lh2.4 cars on the same page. It makes it somewhat confusing.
Seems to me that the ecu controlled fans are only lh2.4. That’s why it says (ex Regina) next to it I guess. Perhaps this means “except Regina”.
Old 07-07-2018, 04:23 PM   #17
oldnfast
Thanks,I agree the 220F in the radiator is crazy high
Old 07-07-2018, 04:42 PM   #18
iHateVolvoPeople
All I did was tap into the low speed wire with a heat shrink butt connector and then run it to a switch in the cabin, then the other post of the switch goes to ground. Now it comes on when I say.
