Old 07-07-2018, 04:20 AM   #1
940Viking
Question Volvo 940 Missing when Idle
My Volvo 940 with a B230FK engine has started to miss when idle.
When driving it sound and feels fine.
I have narrowed a few things down so far:
It is the cylinder closest to the front which is missing
The plug that came out was black and sooty unlike rest ( I replaced this with a new one )
Replaced the distributor
Tested the leads for spark and are all good
The things I have changed on the Vehicle since I got it:
Swapped airbox for a cone filter with heat shield.
replaced spark plugs with new NGK's ( was Bosch plugs before )
replaced oil ( 10w-40 ) and oil filter
I am thinking of changing the ignition coil next, any ideas what this could be?
940Viking is offline   Reply With Quote
Old 07-07-2018, 11:21 AM   #2
John V, outside agitator
Look around..
If it's missing, it can't get far if it's just idling.
Sleezattle WA, USA
--> CALL (206) 431-9696<----
www.rallyrace.net/jvab
www.rallyanarchy.com
Vive le Prole-le-ralliat
— Don Marquis
Old 07-07-2018, 03:55 PM   #3
Nayo
Nayo's Avatar
removed your injectors probably dirty and is free to check
Nayo is offline   Reply With Quote
